DESCRIPTION Texas Instruments’ 13.56MHz Encapsulated Standard Transponder is compliant with the ISO/IEC 15693 and ISO/IEC 18000-3 global open standards. This product offers a user accessible memory of 256 bits, organized in 8 blocks and an optimized command set.
Designed for harsh environments such as garment tracking in laundries, each transponder has a 64bit factory programmed Read Only Number which is also laser engraved on the transponder housing. Prior to delivery, transponders undergo complete functional and parametric testing, in order to provide the high quality that customers have come to expect from TI.
The 13.56MHz Encapsulated Standard Transponders are well suited for a variety of applications including but not limited t Laundry garment tracking, process automation, product authentication, and asset management.
