在电子设计领域,高效、可靠的电源管理方案一直是工程师们追求的目标。今天,我们将深入探讨德州仪器(Texas Instruments)的LM3489,一款高性能的PFET开关稳压器控制器,及其演示板的设计与应用。
文件下载:LM3489EVAL.pdf
LM3489是一款高效的PFET开关稳压器控制器,适用于各种应用场景。它采用滞后控制架构,设计简单,无需担心控制环路稳定性问题,并且可以搭配多种外部组件使用。PFET架构不仅降低了组件数量,还实现了超低压差和100%占空比操作。此外,它在轻负载下也能保持高效运行,且不会增加输出纹波。其专用的使能引脚(未连接时默认启用)提供了关机模式,仅消耗7µA电流。
电流限制保护通过测量PFET的 (R_{DS(ON)}) 电压实现,无需使用感测电阻。通过单个电阻即可调整逐周期电流限制,确保在不同输出电流范围内安全运行。
LM3489演示板能够在7V至28V的宽输入电压范围内提供3.3V输出,标称负载能力为500mA,最大可达1A。该参考设计针对整体转换效率进行了优化。
| Label | Description | Manufacturer |
| CIN1 | Tantalum Capacitor 22µF 35V | Panasonic、Vishay |
| CIN2 | 0603 Ceramic Chip Capacitor 0.1µF 50V | Panasonic |
| COUT | Low ESR Capacitor, POSCAP 100µF 6.3V | Sanyo |
| CADJ | 0603 Ceramic Chip 1nF 50V | Panasonic、Vishay |
| Cff | 0805 Ceramic Chip 100pF 50V | Panasonic、Vishay |
| D1 | Schottky Diode 1A 40V | ON Semiconductor、Central Semi |
| L | Inductor 22µH | Murata |
| M1 | P-channel MOSFET 60V | Fairchild |
| R1 | 0805 Chip Resistor 33kΩ | Vishay、Panasonic |
| R2 | 0805 Chip Resistor 20kΩ | Vishay、Panasonic |
| RADJ | 0603 Chip Resistor 24kΩ | Vishay、Panasonic |
| RIS | 0603 Chip Resistor 270Ω | Vishay、Panasonic |
| U1 | Buck Controller With ENABLE PIN LM3489 | Texas Instruments |
演示板提供了详细的PCB布局,包括顶层覆盖图、顶层布局和底层布局。合理的PCB布局对于确保电路性能和稳定性至关重要。
| Step | Description | Notes |
| 1 | Connect power supply to VIN terminals | V IN range 7 V to 28V |
| 2 | Connect load to the VOUT terminals | I OUT range 0A to 500 mA |
| 3 | SD jumper should left open for normal operation -Short this jumper to shutdown | |
| 4 | Set V IN = 12V, with no load applied, check V OUT with voltmeter | 3.3 V ±100 mV |
| 5 | Apply 500 mA load and check V OUT again | 3.3 V ±100 mV |
| 6 | Short output terminals and check short circuit current with an ammeter | Nominal 1.4A |
| 7 | Short SD jumper to check for shutdown function |
| Description | Symbol | Condition | Min | Typical | Max | Unit |
| Input Voltage | V IN | 7 | 12 | 28 | V | |
| Output Voltage | V OUT | 3.2 | 3.3 | 3.4 | V | |
| Output Current | I OUT | 0 | 0.5 | 1 | A | |
| Output Voltage Ripple | V OUT(Ripple) | 20 MHz Bandwidth limit | - | - | 40 | mV P-P |
| Output Voltage Regulation | Δ V OUT | All V IN and IOUT conditions | 1.5 | 1.5 | % | |
| Efficiency | V IN = 7 V V IN = 28 V (I OUT = 100 mA to 500 mA) | 88 73 | 90 80 | % | ||
| Output Short Current Limit | I LIM-SC | 1.4 | A |
从这些性能数据可以看出,LM3489演示板在输入电压范围、输出电压稳定性、效率等方面都表现出色。
文档中虽未详细提及具体的设置方法,但我们知道通过调整相关电阻可以实现输出电压和电流限制的调整。这为工程师在不同应用场景下灵活配置电路提供了可能。
文档提供了在 (V{IN}=12V)、(V{OUT}=3.3V)、(T_{J}=25^{circ}C) 条件下的典型性能和波形,包括负载瞬态、使能瞬态、关机瞬态等。这些波形对于分析电路在不同工作状态下的性能非常有帮助。
德州仪器对其半导体产品和服务保留进行修正、改进等变更的权利,并对产品销售的条款和条件、保修政策、应用责任等方面做了详细说明。工程师在使用LM3489时,需要仔细阅读这些注意事项,确保设计的安全性和合规性。
总的来说,LM3489是一款功能强大、性能优越的开关稳压器控制器。通过其演示板,工程师可以快速搭建电路,验证设计方案。在实际应用中,我们需要根据具体需求合理选择组件,优化电路设计,以充分发挥LM3489的优势。大家在使用过程中遇到过哪些问题呢?欢迎在评论区分享交流。
