在汽车电子领域,CAN(Controller Area Network)总线作为一种广泛应用的通信协议,对于车辆各系统之间的数据传输和控制起着至关重要的作用。而CAN收发器则是实现CAN总线通信的关键组件,它负责将微控制器的数字信号转换为适合在CAN总线上传输的差分信号,以及将总线上的差分信号转换回数字信号供微控制器处理。今天,我们就来详细介绍一下德州仪器(TI)的TCAN1051-Q1系列CAN收发器。
文件下载:TCAN1051DRBTQ1.pdf
TCAN1051-Q1系列包括TCAN1051-Q1、TCAN1051V-Q1、TCAN1051H-Q1、TCAN1051HV-Q1、TCAN1051G-Q1、TCAN1051GV-Q1、TCAN1051HG-Q1和TCAN1051HGV-Q1等型号。这些收发器均符合AEC Q100标准,适用于汽车应用,工作温度范围为 -40°C至125°C。它们满足ISO 11898-2:2016和ISO 11898-5:2007物理层标准,并且具备功能安全能力,提供相关文档以辅助功能安全系统设计。
该系列收发器适用于高度负载的CAN网络,可用于汽车的各种电子系统,如发动机控制单元、车身电子系统、安全系统等。
符合ISO 11783标准,可用于重型机械的通信和控制。
TCAN1051-Q1系列收发器采用8引脚封装,包括SOIC(8)和VSON(8)两种封装形式。不同型号的引脚功能略有差异,例如,带有“V”后缀的型号在引脚5上具有(V_{IO})电源输入,用于I/O电平转换。
| PINS | NAME (H), (G), (HG) | (V), (GV), (HV), (HGV) | TYPE | DESCRIPTION |
| TXD | 1 | 1 | DIGITAL INPUT | CAN transmit data input (LOW for dominant and HIGH for recessive bus states) |
| GND(1) | 2 | 2 | GND | Ground connection |
| VCC | 3 | 3 | POWER | Transceiver 5-V supply voltage |
| RXD | 4 | 4 | DIGITAL OUTPUT | CAN receive data output (LOW for dominant and HIGH for recessive bus states) |
| NC | 5 | — | No Connect | |
| VIO | — | 5 | POWER | Transceiver I/O level shifting supply voltage (Devices with "V" suffix only) |
| CANL | 6 | 6 | BUS I/O | Low level CAN bus input/output line |
| CANH | 7 | 7 | BUS I/O | High level CAN bus lnput/output line |
| S | 8 | 8 | DIGITAL INPUT | Silent Mode control input (active high) |
| MIN | MAX | UNIT | |||
| V CC | 5-V Bus Supply Voltage Range | All Devices | –0.3 | 7 | V |
| V IO | I/O Level-Shifting Voltage Range | Devices with the "V" Suffix | –0.3 | 7 | V |
| V BUS | CAN Bus I/O voltage range (CANH, CANL) | Devices without the "H" Suffix | –58 | 58 | V |
| V (Diff) | Max differential voltage between CANH and CANL | Devices without the “H” suffix | –58 | 58 | V |
| V BUS | CAN Bus I/O voltage range (CANH, CANL) | Devices with the "H" Suffix | -70 | 70 | V |
| V (Diff) | Max differential voltage between CANH and CANL | Devices with the “H” suffix | –70 | 70 | V |
| V (Logic_Input) | Logic input terminal voltage range (TXD, S) | All Devices | –0.3 | +7 and V I ≤ V IO + 0.3 | V |
| V (Logic_Output) | Logic output terminal voltage range (RXD) | –0.3 | +7 and V I ≤ V IO + 0.3 | V | |
| I O(RXD) | RXD (Receiver) output current | –8 | 8 | mA | |
| T J | Virtual junction temperature range (see Section 6.5 ) | –55 | 150 | °C | |
| T STG | Storage temperature range (see Section 6.5 ) | –65 | 150 | °C |
| TEST CONDITIONS | VALUE | UNIT | |
| D (SOIC) Package | |||
| Human Body Model (HBM) ESD stress voltage | All terminals (1) | ±6000 | V |
| CAN bus terminals (CANH, CANL) to GND (2) | ±16000 | ||
| Charged Device Model (CDM) ESD stress voltage | All terminals (3) | ±1500 | V |
| Machine Model | All terminals (4) | ±200 | V |
| DRB (VSON) Package | |||
| V CC | 5-V Bus Supply Voltage Range | 4.5 | 5.5 | V |
| V IO | I/O Level-Shifting Voltage Range | 2.8 | 5.5 | V |
| I OH(RXD) | RXD terminal HIGH level output current | –2 | mA | |
| I OL(RXD) | RXD terminal LOW level output current | 2 | mA |
该系列设备设计工作在(V{CC})输入电源电压范围为4.5 V至5.5 V,部分设备的(V{IO})输出电平转换电源输入范围为3 V至5.5 V。两个电源输入都必须良好稳压,建议在CAN收发器的主(V{CC})电源输出附近放置一个4.7 μF的大容量电容,并在设备的(V{CC})和(V_{IO})电源端子附近放置一个0.1 μF的旁路电容,以减少开关电源输出的电压纹波,补偿PCB电源平面和走线的电阻和电感。
TCAN1051-Q1系列CAN收发器以其丰富的特性和良好的性能,为汽车和工业应用提供了可靠的CAN总线通信解决方案。其高速数据传输能力、强大的保护特性以及灵活的引脚配置,使得工程师在设计CAN网络时能够更加轻松地满足各种应用需求。在实际应用中,合理的电源供应和布局设计对于发挥该系列收发器的性能至关重要。希望通过本文的介绍,能够帮助电子工程师更好地了解和使用TCAN1051-Q1系列CAN收发器。
你在使用TCAN1051-Q1系列收发器时遇到过哪些问题?或者对于CAN总线设计有什么独特的见解?欢迎在评论区分享交流。
