在混合动力(HEV)和电动汽车(EV)牵引逆变器应用领域,功率模块的性能至关重要。今天,我们就来深入了解一下安森美(onsemi)的VE - Trac Dual Gen II NVG800A75L4DSB2功率模块。
NVG800A75L4DSB2是双侧冷却且占用空间紧凑的功率模块家族的一员,专为HEV和EV牵引逆变器应用而设计。该模块采用半桥配置,包含两个窄台面场截止(FS4)绝缘栅双极晶体管(IGBT)。其芯片组运用了新型窄台面IGBT技术,能提供高电流密度和强大的短路保护功能,同时具备更高的阻断电压,在EV牵引应用中表现出色。此外,还提供液冷散热器参考设计、损耗模型和CAD模型,以支持客户进行逆变器设计。
| Pin # | Pin | Pin Function Description |
| 1 | N | Low Side Emitter |
| 2 | P | High Side Collector |
| 3 | H/S COLLECTOR SENSE | High Side Collector Sense |
| 4 | H/S CURRENT SENSE | High Side Current Sense |
| 5 | H/S EMITTER SENSE | High Side Emitter Sense |
| 6 | H/S GATE | High Side Gate |
| 7 | H/S TEMP SENSE (CATHODE) | High Side Temp sense Diode Cathode |
| 8 | H/S TEMP SENSE (ANODE) | High Side Temp sense Diode Anode |
| 9 | ~ | Phase Output |
| 10 | L/S CURRENT SENSE | Low Side Current Sense |
| 11 | L/S EMITTER SENSE | Low Side Emitter Sense |
| 12 | L/S GATE | Low Side Gate |
| 13 | L/S TEMP SENSE (CATHODE) | Low Side Temp sense Diode Cathode |
| 14 | L/S TEMP SENSE (ANODE) | Low Side Temp sense Diode Anode |
| 15 | L/S COLLECTOR SENSE | Low Side Collector Sense |
| Symbol | Parameter | Rating | Unit |
| (V_{CES}) | Collector to Emitter Voltage | 750 | V |
| (V_{GES}) | Gate to Emitter Voltage | ±20 | V |
| (I_{CN}) | Implemented Collector Current | 550 (1) | A |
| (I_{C nom}) | Continuous DC Collector Current, (T{vJmax} = 175^{circ}C), (T{F} = 65^{circ}C), ref. heatsink | A | |
| (I_{CRM}) | Pulsed Collector Current @ (V{GE} = 15 V), (t{p} = 1 ms) | 1600 | A |
| (V_{RRM}) | Repetitive peak reverse voltage | 750 | V |
| (I_{FN}) | Implemented Forward Current | 800 | A |
| (I_{F}) | Continuous Forward Current, (T{v Jmax} = 175 ° C), (T{F} = 65 ° C), ref. heatsink | 420 (1) | A |
| (I_{FRM}) | Repetitive Peak Forward Current, (t_{p} = 1 ms) | 1600 | A |
| (I^{2}t) value | Surge current capability, (V{R} = 0 V), (t{p} = 10 ms), (T{v J} = 150 ° C) (T{VJ} = 175 ° C) | 20000 18000 | (A^{2}s) |
在 (T_{vj} = 25^{circ} C) (除非另有说明)的条件下,IGBT具有以下特性:
在 (T_{VJ}=25^{circ} C) (除非另有说明)的条件下,反向二极管的恢复电荷等参数也有相应的数值。
在 (T_{V J}=25^{circ} C) (除非另有说明)的条件下,传感器的相关参数也在文档中有详细记录。
文档中提供了一系列典型特性的图表,包括IGBT输出特性、传输特性、开关损耗与电流和电阻的关系、反向偏置安全工作区、瞬态热阻抗等。这些图表可以帮助工程师更好地了解模块在不同工作条件下的性能表现。
文档详细给出了Gen II DSC AHPM15 - CEC CASE MODHV的机械尺寸,包括各个部分的最小、标称和最大尺寸,为工程师进行产品的机械设计提供了准确的参考。
VE - Trac Dual Gen II NVG800A75L4DSB2功率模块凭借其双侧冷却、低损耗、高可靠性等特性,在HEV和EV牵引逆变器应用中具有很大的优势。电子工程师在设计相关系统时,可以充分利用该模块的特性,提高系统的性能和效率。同时,在使用过程中,需要根据实际应用需求,对模块的各项参数进行合理的选择和验证。大家在实际应用中有没有遇到过类似功率模块的使用问题呢?欢迎在评论区分享交流。
