89C51编程器,89c51 programmer
关键字:89C51编程器
#include "at89x52.h"
#include "stdio.h"
#include "intrins.h"
#include "ctype.h"
sbit rdy=P3^2;
sbit vpp=P3^3;
sbit p26=P3^4;
sbit p27=P3^5;
sbit p36=P3^6;
sbit p37=P3^7;
sbit prog=P2^7;
void init_serial()
 SCON=0x50; /*mode 1*/
 TMOD=0x20;
 TH1=0xfd;
 PCON=0x80;  /*38400bps*/
 TR1=1;   /*load tmr1*/
 TI=1;
 ES=1;}
void init_pro()
 p26=0;
 p27=0;
 p36=0;
 p37=0;
 vpp=1;
 prog=1;
void sendbyte(unsigned char da)        /*send a byte*/
 while(!TI);
 TI=0;
 SBUF=da;}
unsigned char IntToAscii(unsigned char a)     /*change DEC to ASCII HEX code*/
 if(a<10) return a+48;
 if(a>9) return a+55;}
unsigned int getadr()                        /*get 5 diti  DEC adr*/
 unsigned char i,a[5];
 for(i=0;i<5;i++)
  while(!RI);
  RI=0;
  a[i]=SBUF-48;
 return a[0]*10000+a[1]*1000+a[2]*100+a[3]*10+a[4];}
unsigned char getdata()                     /*get 2 diti  HEX data*/
 unsigned char d1,d2;
 while(!RI);
 RI=0;
 d1=toint(SBUF);
 while(!RI);
 RI=0;
 d2=toint(SBUF);
 return d1*16+d2;}
unsigned int detchip(int adr)
 P0=0xff;
 P1=adr%256;P2=adr/256;
 init_pro();
 _nop_();_nop_();_nop_();_nop_();_nop_();  /*delay 10 us*/
 return P0;}
void read()
 unsigned int adr,maxadr;
 unsigned char h,l;
 P0=0xff;
 maxadr=getadr();
 for(adr=0;adr {
   p26=0;
   p27=0;
   p36=1;
   p37=1;
   vpp=1;
   prog=1;
   h=IntToAscii(P0/16);
   sendbyte(h);
   l=IntToAscii(P0%16);
   sendbyte(l);}
 init_pro();}
unsigned int test(unsigned int nn)
 unsigned int adr,counter=0;
 P0=0xff;
 for(adr=0;adr {
  p26=0;
  p27=0;
  p36=1;
  p37=1;
  vpp=1;
  prog=1;
  if(P0!=0xff) counter++;}
  init_pro();
  return counter;}
unsigned char erase(unsigned int nn,unsigned int p)
 unsigned int i;
 P0=0xff;
 p26=1;
 p27=0;
 p36=0;
 p37=0;
 vpp=0;
 prog=1;
 for(i=0;i<50000;i++) _nop_();
 switch(p)
  case 0 : prog=0;
           prog=1;
           break;
  case 1 : prog=0;
           _nop_();
           prog=1;
           break;
  case 2 : prog=0;
           _nop_();_nop_();
           prog=1;
           break;
  case 3 : prog=0;
           prog=1;
           break;
  case 4 : prog=0;
           prog=1;
           break;
  case 5 : prog=0;
           prog=1;
           break;
  case 6 : prog=0;
           _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
           prog=1;
           break;
  case 7 : prog=0;
           _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
           prog=1;
           break;
  case 8 : prog=0;
           _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
           prog=1;
           break;
  default: prog=0;
           for(i=0;i
           prog=1;
           break;}
 vpp=1;
 for(i=0;i
 if(test(nn)==0) return 's';
 else return 'f';}
unsigned char write()
 unsigned int adr,d,i;
 p26=0;
 p27=1;
 p36=1;
 p37=1;
 vpp=0;
 prog=1;
 for(i=0;i<4000;i++) _nop_();
 adr=getadr();
 d=getdata();
 while(1)
  if(adr>50000) break;
  P1=adr%256;P2=(adr/256)|0x80;
  P0=d;
  TI=0;
  SBUF='s';
  prog=0;
  prog=1;
  adr=getadr();
  d=getdata();
  while(!rdy);}
  init_pro();
  return 'f';}
unsigned char lock(unsigned char level)
 unsigned int i;
 vpp=0;
 if(level==1) {p26=1;p27=1;p36=1;p37=1;}
 if(level==2) {p26=1;p27=1;p36=0;p37=0;}
 if(level==3) {p26=1;p27=0;p36=1;p37=0;}
 prog=1;
 prog=0;
 prog=1;
 while(!rdy);
 init_pro();
 return 'o';}
void main()
 unsigned char data c;
 unsigned int data adr,l,dx;
 init_pro();
 init_serial();
 while(1)
  init_pro();
  scanf("%c",&c);
  switch(c)
   case 'c' : printf("%c",'o');
              break;
   case 'd' : scanf("%x",&adr);
              printf("%x",detchip(adr));
              break;
   case 't' : scanf("%u",&dx);
              printf("%u",test(dx));
              break;
   case 'r' : read();
              break;
   case 'e' : scanf("%u,%u",&adr,&dx);
              printf("%c",erase(adr,dx));
              break;
   case 'w' : printf("%c",write());
              break;
   case 'l' : scanf("%u",&l);
              printf("%c",lock(l));
              break;
   case 'h' : printf("**********Er6y Programmer Help Window***********\n");
              break;
    default : break;}
  • 相关推荐
  • 热点推荐
