24C02读写汇编程序,24C02 read / write process
关键字:24C02读写汇编程序
24C02读写汇编程序
;简洁的24C02读写汇编程序
    I2C_SDA          EQU P1.6   ; PIN 5
    I2C_SCL          EQU P1.7   ; PIN 6
I2C_WRITE:  ;  WRITE 8 BYTES TO EEROM ; INPUT: A - A*8 = EEROM START ADDR
            ;                                  R0 - RAN START ADDR
            ;                            USE: C, A, R0, R6, R7
      ACALL I2C_START
      ACALL OUT
      MOV R6, #8
WR_LP:MOV A, @R0
      ACALL OUT
      INC R0
      DJNZ R6, WR_LP
      AJMP I2C_STOP
I2C_READ:   ;  READ 8 BYTES FROM EEROM ; INPUT: A - A*8 = EEROM START ADDR
      ACALL I2C_START
      ACALL OUT
      MOV R6, #8
      MOV A, #0A1H; #RDCMD
      ACALL OUTS
BRDLP:
          MOV R7, #8
          SETB I2C_SDA
INLP:     CLR  I2C_SCL
          ACALL DELAY6
          SETB  I2C_SCL
          NOP
          MOV C, I2C_SDA
          RLC A
          DJNZ R7, INLP
          CLR   I2C_SCL
          MOV @R0, A
          INC R0
   DJNZ R6, ACKLP
I2C_STOP:
          CLR I2C_SDA
          ACALL DELAY5
          SETB I2C_SCL
          ACALL DELAY5
          SETB I2C_SDA
DELAY6:
          NOP
DELAY5:
          NOP
          RET
I2C_START:
      SWAP A
      RR A
      MOV R6, A
      MOV A, #0A0H; #WTCMD
      ACALL OUTS
      MOV A, R6
      RET
ACKLP:
      CLR I2C_SDA
      SETB I2C_SCL
      ACALL DELAY5
      CLR I2C_SCL
      AJMP BRDLP
OUTS:
      SETB I2C_SDA
      SETB I2C_SCL
      ACALL DELAY5
      CLR I2C_SDA
      ACALL DELAY5
      CLR I2C_SCL
OUT:
      SETB C
      MOV R7, #9
OTLP: RLC A
      NOP
      MOV I2C_SDA, C
      NOP
      NOP
      SETB I2C_SCL
      ACALL DELAY5
      CLR  I2C_SCL
      DJNZ R7, OTLP
      RET
END
  • 相关推荐
  • 热点推荐
