NCP1271 19V,3.0A通用AC-DC适配器设计方案,NCP1271 DESIGN
1.3w人已加入
关键字:NCP1271,开关电源电路图
OnSemi公司的NCP1271是一款最新的固定频率电流模式PWM开关控制器,具有为低级声频噪声提供可调节的Soft-Skip待机操作模式,为节省待机功耗内部集成高压启动,过载故障检测定时器,内部锁保护功能特性。本文首先介绍NCP1271、基本特性、内部框图及应用领域,并给出相应设计方案的设计原理图、元器件列表及PCB元件布局图。
The NCP1271 represents a new, pin to pin compatible, generation of the successful 7−pin current mode NCP12XX product series.
The controller allows for excellent stand by power consumption by use of its adjustable Soft−Skip mode and integrated high voltage startup
FET. This proprietary Soft−Skip also dramatically reduces the risk of acoustic noise. This allows the use of inexpensive transformers and
capacitors in the clamping network. Internal frequency jittering,ramp compensation, timer−based fault detection and a latch input make
 this controller an excellent candidate for converters where ruggedness and component cost are the key constraints.
NCP1271主要特性:
• Fixed−Frequency Current−Mode Operation with Ramp Compensation and Skip Cycle in Standby Condition
• Timer−Based Fault Protection for Improved Overload Detection
• “Soft−Skip Mode” Technique for Optimal Noise Control in Standby
• Internal High−Voltage Startup Current Source for Lossless Startup
• _5% Current Limit Accuracy over the Full Temperature Range
• Adjustable Skip Level
• Internal Latch for Easy Implementation of Overvoltage and Overtemperature Protection
• Frequency Jittering for Softened EMI Signature
• +500 mA/−800 mA Peak Current Drive Capability
• Sub−100 mW Standby Power can be Achieved
• Pin−to−Pin Compatible with the Existing NCP120X Series
• This is a Pb−Free Device
NCP1271应用领域:
• AC−DC Adapters for Notebooks, LCD Monitors
• Offline Battery Chargers
• Consumer Electronic Appliances STB, DVD, DVDR
图1. NCP1271内部方框图
NCP1271ADAPGEVB方案介绍:
This evaluation board user’s manual presents an example circuit using the NCP1271 (65 kHz version) in a flyback topology.
The design steps and subsequent measurements are also included. An Excel based design worksheet is available at www.onsemi.com.
The measurements show that the 19 V, 3.0 A circuit delivers above 85% across a universal input (85 to 265 Vac).The no load standby
 consumption is 83 mW at 230 Vac and the light load operation is greater than 75% efficient.
NCP1271ADAPGEVB方案原理图:
图2. NCP1271ADAPGEVB方案原理图
NCP1271ADAPGEVB方案材料清单:
PCB元件布局图:
Top View
Bottom View
  • 相关推荐
