12V稳压电源(英文),Regulated 12 Volt Supply
关键字:12V稳压电源
Description
A basic regulated 12 Volt power supply
Circuit diagram
Notes:
This circuit above uses a 13 volt zener diode, D2 which provides the voltage regulation. Aprroximately 0.7 Volts are dropped across the transistors b-e junction, leaving a higher current 12.3 Volt output supply. This circuit can supply loads of up to 500 mA. This circuit is also known as an amplified zener circuit.
Author: Mick Devine
Email: mick_devine@yahoo.com
  • 相关推荐
  • 热点推荐
