在电子设备的设计与应用中,电源的选择至关重要,它直接影响着设备的性能和稳定性。RLE 的电源经过了严格测试,确保与旗下产品完美适配。下面为大家详细介绍 RLE 产品对应的电源信息。
文件下载:PSWA-DC-24.pdf
| Product | Input Voltage | Connection Type | Power Supply Options |
| BMS - 1WIRE | 24VDC | Terminal block | PSWA - DC - 24 - ST |
| BMS - LD3Z | 24VDC | Terminal block | PSWA - DC - 24 - ST |
| BMS - WiNG | 24VDC | Terminal block | PSWA - DC - 24 - ST |
| F200 | 5VDC | USB | Power supply included with product - no additional purchase necessary |
| FDS - PC | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24 (included with product), PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| FMS - 24 (1U) | 24VDC | Barrel connector & terminal block | PSWA - DC - 24 (included with product), PSWA - DC - 24 - ST |
| FMS - 24 (2U) | 24VDC | Barrel connector & terminal block | PSDT (included with product) |
| FMS - 48 | 36 - 72VDC | Hardwired | End user provides hardwired power |
| GD200 | 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| LD1000 | 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| LD1500 | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24, PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| LD2100 | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24, PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| LD310 | 5VDC | Terminal block | WA - DC - 5 - ST, PSWA - DC - 5 - ST, PSWA - DC - 5 - ST - KIT |
| LD5200 | 100 - 240 VAC | Hardwired | End user provides hardwired power |
| LDRA6 | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24, PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| MD3 | 12VDC | Terminal block | WA - DC - 12 (customer needs to strip barrel connector off) |
| RA1X2 | 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| RR10X20 | 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| RR10X20 - 48 | 48VAC/VDC | Hardwired | End user provides hardwired power |
| RR20X40 | 100/120/240VAC | Hardwired | End user provides hardwired power |
| SD - RO1 | 24VAC/VDC | Hardwired | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| SeaHawk 10K | 12 - 24VAC/VDC | Terminal block | PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| SMK | 24VDC | Terminal block | PSWA - DC - 24 - ST |
| WiNG - MGR | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24 (included with product), PSWA - DC - 24 - ST, WA - AC - 24 - ST |
| WiNG - MGR - 868 | 24VAC/VDC | Barrel connector & terminal block | PSWA - DC - 24 - KIT (included with product) |
| WiNG - RXT | 5VDC | Barrel connector | PSWA - DC - 5 (included with product) |
| WiNG - RXT - 868 | 5VDC | Barrel connector | PSWA - DC - 5 - ST (included with product) |
从这个表格中,我们可以清晰地看到不同产品所需的输入电压、连接类型以及对应的电源选项。大家在设计电路时,一定要根据产品的具体要求来选择合适的电源,否则可能会影响设备的正常运行。比如,如果给需要 24V 电源的产品接入 5V 电源,设备很可能无法启动。
| Power Supply | Voltage Conversion | Isolated | Connection Type | Wall Plug Type | Region | Compatible Products |
| WA - AC - 24 - ST | 120VAC to 24VAC, 500mA | Yes | Stripped and tinned | Type A fixed | Domestic | FDS - PC, GD200, LD1000, LD1500, LD2100, LDRA6, RA1x2, RR10x20, SD - RO1, SeaHawk 10K, WiNG - MGR |
| WA - DC - 5 - ST | 100 - 240V to 5VDC, 1.0A | No | Stripped and tinned | Type A fixed | Domestic | LD310 |
| WA - DC - 12 | 120VAC to 12VDC, 2.0A | No | Barrel connector (customer must strip) | - | - | MD3 |
| PSWA - DC - 5 | 100 - 240VAC to 5VDC, 1.6A | Yes | Barrel connector | Interchangeable - includes Type A blade | Domestic | WiNG - RXT |
| PSWA - DC - 5 - Kit | 100 - 240VAC to 5VDC, 1.6A | Yes | Barrel connector | Interchangeable - includes Type A, C, G, and I blades | International | WiNG - RXT - 868 |
| PSWA - DC - 5 - ST | 100 - 240VAC to 5VDC, 1.6A | Yes | Stripped and tinned | Interchangeable - includes Type A blades | Domestic | LD310 in domestic locations |
| PSWA - DC - 5 - ST - Kit | 100 - 240VAC to 5VDC, 1.6A | Yes | Stripped and tinned | Interchangeable - includes Type A, C, G, and I blades | International | LD310 in international locations |
| PSWA - DC - 24 | 100 - 240VAC to 24VDC, 1.0A | Yes | Barrel connector | Interchangeable - includes Type A blade | Domestic | FDS - PC, FMS - 24 (1U), LD1500, LD2100, LDRA6, WiNG - MGR |
| International | FDS - PC, FMS - 24 (1U), LD1500, LD2100, LDRA6, WiNG - MGR - 868 | |||||
| PSWA - DC - 24 - Kit | 100 - 240VAC to 24VDC, 1.0A | Yes | Barrel connector | Interchangeable - includes Type A, C, G, and I blades | - | - |
| PSWA - DC - 24 - ST | 100 - 240VAC to 24VDC, 1.0A | Yes | Stripped and tinned | Interchangeable - includes Type A blade | Domestic | FDS - PC, FMS - 24(1U), GD200, LD1000, LD1500, LD2100, LDRA6, RA1x2, RR10x20, SD - RO1, SeaHawk 10K, WiNG - MGR |
| PSDT | 85 - 264VAC, 3.0A | Yes | Barrel connector on 24VDC side, C13 power cord not included | - | Domestic and International | FMS - 24(2U) |
这里详细列出了每个电源的电压转换情况、是否隔离、连接类型、插头类型、适用地区以及兼容产品。对于一些需要在不同地区使用的产品,我们要特别注意选择带有合适插头类型的电源。比如在国际项目中,PSWA - DC - 5 - Kit 就提供了多种插头类型,能满足不同地区的使用需求。
在设计电子设备时,电源的选择是一个关键环节。RLE 为我们提供了丰富的电源选项,并且经过了严格测试,确保与产品的兼容性。大家在实际应用中,一定要仔细对照产品与电源的适配表,根据设备的输入电压、连接类型以及使用地区等因素,选择最合适的电源。你在电源选择过程中遇到过哪些问题呢?欢迎在评论区分享。
