FPGA学习系列:33. 设计一个简单的二选一数据选择器
设计背景:
频率计又称为频率计数器,是一种专门对被测信号频率进行测量的电子测量仪器。频率计主要由四个部分构成:时基(T)电路、输入电路、计数显示电路以及控制电路。
频率,即使信号周期的倒数,也就是说,信号每单位时间完成周期的个数,一般去一秒为基本单位时间。
设计原理:
本次的设计主要是一个简单的二选一数据选择器,我们的设计主频率=1s/T,T=高电平的时间+低电平的时间。时间=周期数*周期。占空比=(高电平的时间/周期)100%。我们的时间单位都是以ns来计算的,所以要把1s换成1_000_000_000ns,驱动时钟是50MHz的,周期为20ns。计算占空比的时候,我们把周期20ns全部省略了。所以计算公式如下:
freq = 1_000_000_000/(low_time * 20 + high_time * 20);
duty_cycle = (high_time * 100)/(high_time + low_time);
设计架构图:
设计代码:
设计模块
0module freq_meter (clk, rst_n, wave, freq, duty_cycle);  //端口列表
1
2 input clk;                   //时钟
3 input rst_n;                 //复位
4 input wave;                  //被测频率
5 output[25:0] freq;          //输出频率
6 output[6:0] duty_cycle; //输出占空比
7
8 reg[25:0] low_cnt;
9 reg[25:0] high_cnt;
10 reg[25:0] low_time;
11 reg[25:0] high_time;
12 reg state;
13
14 localparam high_state =1'b0;
15 localparam low_state =1'b1;
16
17 always@(posedge clk ornegedge rst_n)
18  begin
19   if(!rst_n)
20    begin
21    low_cnt <=26'd0;
22    high_cnt <=26'd0;
23    low_time <=26'd0;
24    high_time <=26'd0;
25    state <= high_state;
26    end
27   else
28   begin
29    case(state)
30     high_state :begin
31       if(wave ==1'b1)       //判断输入为高电平
32        begin
33         high_cnt <= high_cnt +1'b1;
34         state <= high_state;
35        end
36       else
37        begin
38         high_cnt <=26'd0;
39         high_time <= high_cnt;
40         state <= low_state;
41        end
42      end
43
44     low_state :begin
45       if(wave ==1'b0)  //判断输入为低电平
46        begin
47         low_cnt <= low_cnt +1'b1;
48         state <= low_state;
49        end
50       else
51        begin
52         low_cnt <=26'd0;
53         low_time <= low_cnt;
54         state <= high_state;
55        end
56      end
57     default: state <= low_state;
58     endcase
59   end
60  end
61
62 assign freq =1_000_000_000/(low_time *20+ high_time *20);  //求频率
63 assign duty_cycle =(high_time *100)/(high_time + low_time);  //求占空比
64
65endmodule
测试模块
0`timescale1ns/1ps
1module freq_meter_tb;
2 reg clk;
3 reg rst_n;
4 reg wave;
5 wire[25:0] freq;
6 wire[6:0] duty_cycle;
7
8 initialbegin
9  clk =1'b1;
10  rst_n =1'b0;
11
12  #200.1
13   rst_n =1'b1;
14  #1_000_000_0//仿真10ms
15   $stop;
16 end
17
18 always#10 clk =~clk;
19
20 initialbegin
21  wave =1'b1;
22  foreverbegin//产生占空比为60%,频率为1KHz的方波
23   #600_000
24    wave =1'b0;
25   #400_000
26    wave =1'b1;
27  end
28 end
29
30 freq_meter freq_meter_dut(
31  .clk(clk),
32  .rst_n(rst_n),
33  .wave(wave),
34  .freq(freq),
35  .duty_cycle(duty_cycle)
36 );
37
38endmodule
仿真图:
由于在前面没有测完一个周期出现了不稳定的因素,就出现了不准确的数值,当测试完一个周期以后,测到的数值就比较的准确,基本的没有什么误差。
相对的,如果测试的频率越大,测到的数值就越准确。
