出售ADCMT 8250A光功率计
今日头条
1152人已加入
The 8250A is a bench-type optical power meter, which is most suitable for R&D and production of LDs, optical pickups, and drives for optical disks.
It has 0.001dB resolution and 5 1/2-digit display and is also quipped with GPIB and USB interfaces as standard, allowing easy automated system establishment.
Nine kinds of optical sensors with various purpose (general-purpose/blue-violet/high-power/three-wavelength) and different shapes (thin-type/ cylindrical-type) are available. The three-wavelength optical sensors 82314B, 82324B and 82314BW are capable of measuring 405nm, 650nm, 780nm wavelength ranges. The blue-violet optical sensors 82312B and 82322B have realized a flat wavelength sensitivity characteristic and low dependency on an angle of incidence in the 405 nm range. The high-power optical sensors 82313B and 82323B enable high-power measurement of up to 200mW.
Furthermore, the optical sensors for the TQ8210/TQ8215 series are also usable.
Features
High resolution 0.001dB, 5 1/2-digit displayGPIB and USB interfacesVarious sensors available by use 1)three-wavelength optical sensor applicable to Blu-ray disk, DVD (650nm) and CD (780nm), most suitable for pick up evaluation (82314B/82324B/82314BW) Flat wavelength sensitivity characteristic and low dependency on an angle of incidence in the 405/650/780 nm bandsLow reflection; less measurement deviation due to multi reflection between the sensor and the pickup.2)Blue-violet optical sensor most suitable for Blu-ray disk in the 405nm band (82312B/82322B) Flat wavelength sensitivity characteristic and low incident-angle-dependency in the 405 nm bandLow reflection; less measurement deviation due to multi reflection between the sensor and the pickup3)High-power optical sensor of up to 200mW (82313B/82323B) The maximum light-receiving power of 200mW suitable for pickup measurement of high-speed rewritable CD/DVDIt is possible to measure high power density without saturation up to 200mW even at 0.1mmφ spot diameter.4)Low-price general-purpose optical sensor (82311B/82321B)Both thin-type and cylindrical-type optical sensors are available. Manual measurement and system built-in measurement can be performed easily.Sensor power calibration wavelength: 405/650/780nm Maximum three-wavelength power calibration is available on just one sensor by adding the calibration wavelength options. (405nm: OPT+21/650nm: OPT+22/780nm:OPT+23)The optical sensors for the TQ8210/TQ8215 series (82014A/82017A/82015/Q82018A) are also usable.
我公司主营测试仪器的回收、销售、维修、租赁等业务,欢迎来电咨询洽谈,联系方式如下:
法澜克仪器设备(深圳)有限公司
联系电话:0755-23357287
企业网址:http://www.falank.com
联系人:魏先生
手机:18689488394(微信同号)
地址:广东省深圳市宝安区石岩街道金三角商务大厦306
  • 相关推荐
