FreeRTOS启动流程
1. 创建空闲任务
xIdleTaskHandle = xTaskCreateStatic(	prvIdleTask,
										configIDLE_TASK_NAME,
										ulIdleTaskStackSize,
										( void * ) NULL, /*lint !e961.  The cast is not redundant for all compilers. */
										portPRIVILEGE_BIT, /* In effect ( tskIDLE_PRIORITY | portPRIVILEGE_BIT ), but tskIDLE_PRIORITY is zero. */
										pxIdleTaskStackBuffer,
										pxIdleTaskTCBBuffer ); /*lint !e961 MISRA exception, justified as it is not a redundant explicit cast to all supported compilers. */
2. 创建定时器任务
#if ( configUSE_TIMERS == 1 )
	if( xReturn == pdPASS )
		xReturn = xTimerCreateTimerTask();
	else
		mtCOVERAGE_TEST_MARKER();
#endif /* configUSE_TIMERS */
3. 关闭中断
/* Interrupts are turned off here, to ensure a tick does not occur
before or during the call to xPortStartScheduler().  The stacks of
the created tasks contain a status word with interrupts switched on
so interrupts will automatically get re-enabled when the first task
starts to run. */
portDISABLE_INTERRUPTS();
4. 初始化全局变量
xNextTaskUnblockTime = portMAX_DELAY;
xSchedulerRunning = pdTRUE;
xTickCount = ( TickType_t ) configINITIAL_TICK_COUNT;
5. 初始化MSP
6. 使能全局中断
7. 调用SVC指令启动第一个任务
__asm void prvStartFirstTask( void )
	PRESERVE8
	/* Use the NVIC offset register to locate the stack. */
	ldr r0, =0xE000ED08
	ldr r0, [r0]
	ldr r0, [r0]
	/* Set the msp back to the start of the stack. */
	msr msp, r0
	/* Clear the bit that indicates the FPU is in use in case the FPU was used
	before the scheduler was started - which would otherwise result in the
	unnecessary leaving of space in the SVC stack for lazy saving of FPU
	registers. */
	mov r0, #0
	msr control, r0
	/* Globally enable interrupts. */
	cpsie i
	cpsie f
	dsb
	isb
	/* Call SVC to start the first task. */
	svc 0
	nop
	nop
