在无线基站链路等应用中,高速、可靠的收发器至关重要。Finisar 的 FTLF1326P3BTL SFP+ 收发器凭借其出色的性能和丰富的特性,成为众多工程师的选择。下面我们就来详细了解这款产品。
文件下载:FTLF1326P3BTL.pdf
该收发器支持高达 6.144 Gb/s 的双向数据链路,能够满足高速数据传输的需求。无论是 2.457 Gb/s、4.915 Gb/s 还是 6.144 Gb/s 的 CPRI、OBSAI、LTE 等应用,它都能稳定工作。
采用热插拔的 SFP+ 封装,方便安装和更换。内置数字诊断功能,可以实时监测设备的工作参数,如温度、激光偏置电流、发射光功率、接收光功率和电源电压等,当参数超出正常范围时会发出警报和警告。
使用 1310nm 的 Fabry - Perot 激光发射器,配备双工 LC 连接器。在 9/125μm 的单模光纤上,6.144 Gb/s 速率下传输距离可达 2 km。
符合 RoHS 标准且无铅,采用金属外壳,可降低电磁干扰(EMI)。
工业级的工作温度范围为 -40°C 至 85°C,能适应各种恶劣环境。
仅需单一的 3.3V 电源供电,简化了设计。
适用于无线基站链路,可用于 2.457 Gb/s、4.915 Gb/s 和 6.144 Gb/s 的 CPRI、OBSAI、LTE 等无线应用。
| Pin | Symbol | Name/Description | Ref. |
| 1 | V EET | Transmitter Ground (Common with Receiver Ground) | 1 |
| 2 | T FAULT | Transmitter Fault. | 2 |
| 3 | T DIS | Transmitter Disable. Laser output disabled on high or open. | 3 |
| 4 | SDA | 2 - wire Serial Interface Data Line (MOD - DEF2) | 4 |
| 5 | SCA | 2 - wire Serial Interface Clock (MOD - DEF1) | 4 |
| 6 | MOD_ABS | Module Absent, connected to V EET or V EER | 4 |
| 7 | RS0 | Rx Rate Select: Open or Low = 4.915 to 6.144 Gb/s High = 4.915 to 6.144 Gb/s |
5 |
| 8 | LOS | Loss of Signal indication. Logic 0 indicates normal operation. | 6 |
| 9 | RS1 | Tx Rate Select: Open or Low = High = 4.915 to 6.144 Gb/s 4.915 to 6.144 Gb/s | 5 |
| 10 | V EER | Receiver Ground (Common with Transmitter Ground) | 1 |
| 11 | V EER | Receiver Ground (Common with Transmitter Ground) | 1 |
| 12 | RD - | Receiver Inverted DATA out. AC Coupled | |
| 13 | RD + | Receiver Non - inverted DATA out. AC Coupled | |
| 14 | V EER | Receiver Ground (Common with Transmitter Ground) | 1 |
| 15 | V CCR | Receiver Power Supply | |
| 16 | V CCT | Transmitter Power Supply | |
| 17 | V EET | Transmitter Ground (Common with Receiver Ground) | 1 |
| 18 | TD + | Transmitter Non - Inverted DATA in. AC Coupled. | |
| 19 | TD - | Transmitter Inverted DATA in. AC Coupled. | |
| 20 | V EET | Transmitter Ground (Common with Receiver Ground) | 1 |
在实际设计中,工程师需要根据这些引脚的功能进行合理的连接和配置。例如,T FAULT 引脚可用于监测发射器是否出现故障,当输出为高电平时表示发射器故障。
| Parameter | Symbol | Min | Typ | Max | Unit | Ref. |
| Supply Voltage | Vcc | 3.14 | 3.46 | V | 2 | |
| Supply Current | Icc | 300 | mA | 2 | ||
| Transmitter | ||||||
| Input differential impedance | R in | 100 | Ω | 3 | ||
| Single ended data input swing | Vin,pp | 90 | 350 | mV | ||
| Transmit Disable Voltage | V D | 2 | Vcc | V | ||
| Transmit Enable Voltage | V EN | Vee | Vee + 0.8 | V | 4 | |
| Receiver | ||||||
| Single ended data output swing | Vout,pp | 275 | 425 | mV | 5 | |
| Data output rise/fall time | t r, t f | 0.5 | UI | 6,7 | ||
| LOS Fault | V LOS fault | 2 | Vcc HOST | V | 8 | |
| LOS Normal | V LOS norm | Vee | Vee + 0.8 | V | 8 | |
| Power Supply Rejection | PSR | 100 | mVpp | 9 |
| Output Opt. Power | P O | -8.4 | -2.5 | +0.5 | dBm | 2 |
| Optical Wavelength | λ | 1260 | 1350 | nm | 4 | |
| Spectral Width | σ | nm | 4 | |||
| Optical Modulation Amplitude | OMA | 174 | μ W | 4,5 | ||
| Transmitter and Dispersion Penalty | TDP | 5.2 | dB | 6 | ||
| RIN | -128 | dB/Hz | ||||
| Receiver | ||||||
| Unstressed Receiver OMA Sensitivity, 6.144 Gb/s | R SENSr | 0.042 | mW | 7 | ||
| Unstressed Receiver OMA Sensitivity, 4.915 Gb/s | R SENS4 | 0.042 | mW | 7 | ||
| Average Received Power | Rx MAX | +0.5 | dBm | |||
| Optical Center Wavelength | λ C | 1260 | 1360 | nm | ||
| Return Loss | 12 | dB | ||||
| LOS De - Assert | LOS D | -19 | dBm | |||
| LOS Assert | LOS A | -30 | dBm | |||
| LOS Hysteresis | 0.5 | dB |
这些特性为工程师在设计系统时提供了重要的参考,例如在选择电源时,需要确保其输出电压在 3.14V 至 3.46V 之间。
该收发器支持 2 - 线串行通信协议,与 SFP MSA 标准兼容。通过标准的 SFP 串行 ID 可以获取收发器的各种信息,同时还提供了独特的增强型数字诊断监控接口,可实时访问设备的工作参数。当某些参数超出工厂设定的正常范围时,会触发警报和警告标志。
在实际应用中,工程师可以利用这个功能对设备进行实时监控,及时发现潜在的问题。那么,在你的项目中,你会如何利用这些数字诊断功能来保障系统的稳定运行呢?
FTLF1326P3BTL SFP+ 收发器符合 SFF - 8432 规范,具有良好的可插拔性。
通孔为未电镀的半径,过孔为底盘接地。在进行 PCB 布局时,需要注意一些细节,如最小间距等,同时不建议用于 PCI 扩展卡应用。
该产品是 1 类激光产品,符合美国 FDA 法规。经 TÜV 和 CSA 认证,满足 EN (IEC) 60825 的 1 类眼睛安全要求和 EN (IEC) 60950 的电气安全要求。
Finisar 的 FTLF1326P3BTL SFP+ 收发器以其高速、可靠、环保等特性,为无线基站链路等应用提供了优秀的解决方案。工程师在使用该产品时,需要充分了解其各项特性和参数,合理进行设计和配置,以确保系统的稳定运行。你在使用类似收发器时遇到过哪些问题呢?欢迎在评论区分享。
