在服务器硬件领域,ASMB - 782这款ATX服务器主板凭借其丰富的功能和出色的性能,成为众多电子工程师关注的焦点。今天,我们就来深入了解一下这款主板的详细信息。
文件下载:ASMB-782G4-00A1E.pdf
在开始安装ASMB - 782主板之前,我们要确保收到以下物品:
如果发现任何物品缺失或损坏,应立即联系经销商或销售代表。同时,查看PDF文件需要安装Acrobat Reader,可以从http://www.adobe.com/downloads/ 下载。
| 主板上有众多连接器,每个都有其特定的功能,如ATX24P_P1是ATX 24针主电源连接器(用于系统),ATX8P_P1是处理器电源连接器(用于CPU)等。详细的连接器功能可参考以下表格: | Label | Function |
| ATX24P_P1 | ATX 24 Pin main power connector (for System) | |
| ATX8P_P1 | Processor power connector(for CPU) | |
| SATA2~5 | SATAII (3Gb/s) | |
| SATA0~1 | SATA III (6Gb/s) | |
| USB78, USB910, USB1112 | USB 2.0 Port 7,8,9,10,11,12 (Header) | |
| USB13, USB14 | USB 2.0 Port 13, 14 (USB Type A) | |
| USB34 | USB 3.0 Port 3 4 (Header) | |
| USB12 | USB 3.0 Port 1 2 | |
| PCIE2, PCIE7 | PCIE x4 slot | |
| PCIE5,PCIE6 | PCIE x16 slots (x8 link) | |
| DIMMA0,DIMMA1, DIMMB0,DIMMB1 | DDR3 Slot | |
| CPUFAN1 | CPU FAN connector | |
| SYSFAN1,SYSFAN2, SYSFAN3,SYSFAN4 | System FAN connector | |
| LAN1_USB12, LAN2_USB56 | LAN1 / USB port 1, 2 stack connector LAN2 / USB port 5, 6 stack connector | |
| LAN34 | LAN 3,4 stack connector | |
| USB56 | USB 2.0 Port 5 6 | |
| VGA_COM1 | VGA+COM connector | |
| DVI1 | Pin header of DVI - D (optional) | |
| KBMS1 | PS/2 keyboard and mouse connector | |
| KBMS2 | External keyboard and mouse connector(6 pin) | |
| SPI1 | SPI socket | |
| SPI_CN1 | SPI flash card pin header | |
| LANLED1, LANLED2 | LAN LED extension connector | |
| SMBUS1 | SM Bus From PCH | |
| SNMP1 | SM Bus from HW Montior IC | |
| GPIO1 | GPIO header | |
| FPAUD1 | Audio front panel header | |
| LPT1 | Parallel port | |
| COM2 | Serial port: RS - 232 | |
| JFP1 | Front panel header | |
| PMBUS1 | PMBUS connector to communicate with power supply | |
| LPC1 | Low pin count connector for Advantech TPM LPC modules | |
| LANLED1 | LAN1/2 LED extension connector | |
| LANLED2 | LAN3/4 LED extension connector | |
| VOLT1 | Voltage Display |
| 主板上的跳线可以帮助我们配置系统以适应不同的应用。例如JCMOS1用于CMOS清除,JME1用于Intel ME禁用跳线以进行ME/BIOS更新等。以下是详细的跳线功能表格: | Label | Function |
| JCMOS1 | CMOS clear | |
| JME1 | Intel ME Disable Jumper for ME/ BIOS update | |
| JWDT1 | Watch Dog Reset | |
| JGREEN1 | Deep sleep Sx mode | |
| JUSB_1,JUSB_2 | USB port and KBMS power source switch between +5 VSB and +5 V | |
| CPUFAN_SEL1,SYSFAN_SEL1 | FAN PWM(1 - 2)/DC mode selection(2 - 3) | |
| PSON1 | AT(1 - 2) / ATX(2 - 3) |
同时,不同跳线的引脚闭合会产生不同的结果,如JCMOS1和JMECLR1,引脚1 - 2闭合时保留CMOS和ME数据,2 - 3闭合时清除CMOS和ME数据。
| JFP1的引脚定义需要特别注意,电源按钮引脚位于前面板连接器的引脚1和3。具体引脚信息如下: | Pin.1 | #PWR_SW |
| Pin.3 | GND | |
| Pin.2 | #RST_SW | |
| Pin.4 | GND |
CD光盘中包含驱动程序安装程序,它将引导我们完成各种设备驱动程序的安装,以充分发挥主板的性能。同时,计算机配备了电池供电的实时时钟电路,更换电池时要注意按照制造商的建议进行,否则有爆炸危险,使用过的电池也要按照制造商的说明进行处理。
该设备符合FCC规则第15部分的要求,但运行需满足两个条件:一是该设备不得造成有害干扰;二是该设备必须接受任何收到的干扰,包括可能导致不良操作的干扰。
ASMB - 782服务器主板在功能和性能上表现出色,对于电子工程师来说,深入了解其规格、跳线和连接器等信息,能够更好地发挥其优势,打造出稳定、高效的服务器系统。大家在实际使用过程中,有没有遇到过什么特别的问题呢?不妨在评论区分享一下。
