在电子工程领域,LED产品的性能和规格对于各类电子设备的设计至关重要。今天我们来深入了解ChromeLED的CDSX10系列产品,包括其规格、电气特性、光学特性以及焊接条件等方面。
文件下载:CDSA10G1W.pdf
CDSX10系列产品包括CDSA10和CDSC10两个子系列,具有RoHS合规性,采用Case mold type封装,封装尺寸为C/A1001X G/W。需要注意的是,所有尺寸单位为毫米(英寸),公差为± 0.25mm(0.01”),并且规格可能会随时变更,恕不另行通知。
| Part Number | Chip Material | Color of Emission | Lens Type | Description |
| CDSA10R1W | GaAsP | Red | White Segment | Common Anode |
| CDSC10R1W | GaAsP | Red | White Segment | Common Cathode |
| CDSA10RR1W | AlGaAs | Super Red | White Segment | Common Anode |
| CDSC10RR1W | AlGaAs | Super Red | White Segment | Common Cathode |
| CDSA10Y1W | GaAsP | Yellow | White Segment | Common Anode |
| CDSC10Y1W | GaAsP | Yellow | White Segment | Common Cathode |
| CDSA10G1W | GaP | Green | White Segment | Common Anode |
| CDSC10G1W | GaP | Green | White Segment | Common Cathode |
| CDSA10B1W | GaN | Blue | White Segment | Common Anode |
| CDSC10B1W | GaN | Blue | White Segment | Common Cathode |
从这些型号中我们可以看出,不同的芯片材料决定了发光颜色,而阳极和阴极的不同配置则为电路设计提供了更多的选择。大家在实际设计中,要根据具体的电路需求来选择合适的型号。
| Part Number | Wave- length (nm) | Absolute Maximum | Electro-Optical Characteristics | ||||||||
| Δλ nm | P d mW | I af mA | I pf (Peak) | V f (V) | I f | I v ( m cd) | |||||
| Min | Typ | Max | (Rec) | Min | Typ | ||||||
| CDSA10R1W | 625 | 45 | 50 | 30 | 100 | - | 3.7 | 5.0 | 10 | 4.7 | 16 |
| CDSC10R1W | 625 | 45 | 50 | 30 | 100 | - | 3.7 | 5.0 | 10 | 4.7 | 16 |
| CDSA10RR1W | 640 | 20 | 50 | 20 | 100 | - | 3.6 | 5.2 | 10 | 18 | 60 |
| CDSC10RR1W | 640 | 20 | 50 | 20 | 100 | - | 3.6 | 5.2 | 10 | 18 | 60 |
| CDSA10Y1W | 588 | 30 | 50 | 30 | 100 | - | 4.1 | 5.2 | 10 | 3 | 10.5 |
| CDSC10Y1W | 588 | 30 | 50 | 30 | 100 | - | 4.1 | 5.2 | 10 | 3 | 10.5 |
| CDSA10G1W | 568 | 30 | 40 | 25 | 100 | - | 4.1 | 5.2 | 10 | 8 | 24 |
| CDSC10G1W | 568 | 30 | 40 | 25 | 100 | - | 4.1 | 5.2 | 10 | 8 | 24 |
| CDSA10B1W | 470 | 30 | 65 | 25 | 100 | - | 6.6 | 7.6 | 10 | 6 | 7.5 |
| CDSC10B1W | 470 | 30 | 65 | 25 | 100 | - | 6.6 | 7.6 | 10 | 6 | 7.5 |
从这些数据中我们可以看到,不同型号的LED在波长、功率、电流和电压等方面存在差异。比如,红色LED(CDSA10R1W和CDSC10R1W)的波长为625nm,而超红色LED(CDSA10RR1W和CDSC10RR1W)的波长为640nm。在设计电路时,我们需要根据这些参数来选择合适的LED,以满足设计要求。
| Reverse Voltage | 5V | Spectral Line half-width (λ) | nm |
| Reverse Current (Vr = 5V) | 100μA | Power Dissipation ( P d ) | mW |
| Operating Temperature | -40˚C~+85˚C | Peak Forward Current (Duty 1/10, @ KHz) | mA |
| Storage Temperature | -40˚C~+85˚C | Recommended Operation Current ( I f Rec) | mA |
| Soldering Temperature | 250C~260C for 3 sec. | Average Luminous Intensity (I f =10) | μ A |
了解这些绝对最大额定值对于确保LED的正常工作和寿命非常重要。例如,反向电压不能超过5V,否则可能会损坏LED。大家在实际使用中一定要严格遵守这些额定值,避免因操作不当而导致产品损坏。
文档中给出了不同颜色(红色、超红色、黄色、绿色、蓝色)LED的光学特性曲线,包括正向电流与正向电压、相对强度与正向电流、正向电流与环境温度、发光强度与环境温度等关系曲线。这些曲线可以帮助我们更深入地了解LED在不同条件下的性能表现。比如,通过正向电流与正向电压曲线,我们可以了解LED的导通特性;通过发光强度与环境温度曲线,我们可以了解环境温度对LED发光强度的影响。在实际设计中,我们可以根据这些曲线来优化电路设计,提高LED的性能和稳定性。
焊接LED时,应距离环氧树脂灯泡底部至少3mm,建议在焊片底部以外进行焊接。
| Dip Soldering | |
| Pre-Heat | 100 ˚C Max |
| Pre-Heat Time | 60 Second Max |
| Solder Bath Temperature | 260 ˚C Max |
| Dippng Time | 5 Second Max |
| Dipping Position | No lower than 3mm from the base of the epoxy |
| Hand Soldering | 3mm Series | Others |
| Temperature | 300 ˚C Max | 350 ˚C Max |
| Soldering Time | 3 Second Max | 3 Second Max |
| Position | No closer than 3mm from the base of the epoxy | No closer than 3mm from the base of the epoxy |
正确的焊接条件和注意事项对于保证LED的焊接质量和性能至关重要。大家在焊接过程中一定要严格按照这些要求进行操作,避免因焊接不当而影响产品的性能和可靠性。
综上所述,ChromeLED的CDSX10系列产品在性能和规格上具有一定的优势,但在实际应用中,我们需要根据具体的设计需求,综合考虑其光电特性、光学特性和焊接条件等因素,以确保产品的正常工作和性能稳定。大家在使用过程中遇到任何问题,欢迎一起交流探讨。
