在电子设计领域,选择合适的LED产品对于实现理想的性能和功能至关重要。今天,我们就来深入了解一下ChromeLED的CDSX30系列产品,看看它们有哪些特点和优势。
文件下载:CDSA30G1W.pdf
CDSX30系列产品采用了Case mold type设计,具有低功耗的显著特点。该系列包含CDSA30和CDSC30两个子系列,适用于多种电子设备的显示需求。
CDSX30系列的封装尺寸有明确规定,所有尺寸单位为毫米(英寸),除非特别说明,公差为± 0.25mm(0.01”)。需要注意的是,产品规格可能会在不另行通知的情况下发生变化。
| Part Number | Chip Material | Color of Emission | Lens Type | Description |
| CDSA30R1W | GaAsP | Red | White Segment | Common Anode |
| CDSC30R1W | GaAsP | Red | White Segment | Common Cathode |
| CDSA30RR1W | AlGaAs | Super Red | White Segment | Common Anode |
| CDSC30RR1W | AlGaAs | Super Red | White Segment | Common Cathode |
| CDSA30Y1W | GaAsP | Yellow | White Segment | Common Anode |
| CDSC30Y1W | GaAsP | Yellow | White Segment | Common Cathode |
| CDSA30G1W | GaP | Green | White Segment | Common Anode |
| CDSC30G1W | GaP | Green | White Segment | Common Cathode |
| CDSA30B1W | GaN | Blue | White Segment | Common Anode |
| CDSC30B1W | GaN | Blue | White Segment | Common Cathode |
从这些型号中我们可以看出,不同的芯片材料和颜色组合满足了多样化的设计需求。大家在设计时可以根据实际需要选择合适的型号。
| 在Ta = 25°C的条件下,各型号的光电特性如下: | Part Number | length (nm) | Δλ nm | P d mW | I af | I pf | V f (V) | I f | I v ( μ cd) | |||
| mA | (Peak) | Min | Typ | Max | (Rec) | Min | Typ | |||||
| CDSA30R1W | 625 | 45 | 75 | 30 | 100 | 1.7 | 1.85 | 2.5 | 10 | 1200 | 6400 | |
| CDSC30R1W | 625 | 45 | 75 | 30 | 100 | 1.7 | 1.85 | 2.5 | 10 | 1200 | 6400 | |
| CDSA30RR1W | 640 | 20 | 72 | 20 | 100 | 1.6 | 1.75 | 2.4 | 10 | 12000 | 26000 | |
| CDSC30RR1W | 640 | 20 | 72 | 20 | 100 | 1.6 | 1.75 | 2.4 | 10 | 12000 | 26000 | |
| CDSA30Y1W | 588 | 35 | 75 | 30 | 100 | 1.7 | 2.1 | 2.8 | 10 | 800 | 3000 | |
| CDSC30Y1W | 588 | 35 | 75 | 30 | 100 | 1.7 | 2.1 | 2.8 | 10 | 800 | 3000 | |
| CDSA30G1W | 568 | 30 | 65 | 30 | 100 | 1.7 | 2.1 | 2.8 | 10 | 1900 | 8000 | |
| CDSC30G1W | 568 | 30 | 65 | 30 | 100 | 1.7 | 2.1 | 2.8 | 10 | 1900 | 8000 | |
| CDSA30B1W | 470 | 30 | 120 | 30 | 100 | 3.0 | 3.5 | 4.0 | 10 | 4500 | 8500 | |
| CDSC30B1W | 470 | 30 | 120 | 30 | 100 | 3.0 | 3.5 | 4.0 | 10 | 4500 | 8500 |
这些数据对于评估产品在不同场景下的性能非常重要,大家不妨思考一下,如何根据这些光电特性来优化我们的电路设计呢?
| 在Ta = 25°C时,产品的绝对最大额定值如下: | Reverse Voltage | 5V | Spectral Line half-width (λ) | nm |
| Reverse Current (Vr = 5V) | 100μA | Power Dissipation ( P d ) | mW | |
| Operating Temperature | -40˚C~+85˚C | Peak Forward Current (Duty 1/10, @ KHz) | mA | |
| Storage Temperature | -40˚C~+85˚C | Recommended Operation Current ( I f Rec) | mA | |
| Soldering Temperature | 250C~260C for 3 sec. | Average Luminous Intensity (I f =10) | μ A |
了解这些额定值有助于我们确保产品在安全的范围内工作,避免因超出额定值而导致产品损坏。
该系列产品提供了不同颜色(红、超红、黄、绿、蓝)的光学特性曲线,包括Forward Current vs. Forward Voltage、Relative Intensity vs. Forward Current、Forward Current vs. Ambient Temperature、Luminous Intensity vs. Ambient Temperature等。这些曲线直观地展示了产品在不同条件下的性能表现,对于工程师进行性能评估和优化设计具有重要参考价值。大家在实际应用中,可以结合这些曲线来更好地把握产品的特性。
| 3mm Series | Others | |
| Temperature | 300 ˚C Max | 350 ˚C Max |
| Soldering Time | 3 Second Max | 3 Second Max |
| Position | No closer than 3mm from the base of the epoxy | No closer than 3mm from the base of the epoxy |
同时,还需要注意一些焊接时的注意事项,如不要对引脚施加应力,焊接后不要重新定位LED,焊接后要保护环氧树脂灯泡免受机械冲击或振动等。大家在焊接过程中一定要严格按照这些要求操作,以确保产品的可靠性。
综上所述,ChromeLED的CDSX30系列产品具有丰富的型号选择、明确的光电特性和详细的焊接指导,为电子工程师提供了可靠的设计方案。在实际应用中,我们需要根据具体的设计需求,综合考虑产品的各项特性,以实现最佳的设计效果。大家在使用该系列产品的过程中遇到过哪些问题呢?欢迎在评论区分享交流。
