在电子工程领域,LED(发光二极管)是一种常见且重要的电子元件。今天我们来详细了解一下ChromeLED Corp.的CDSX56系列LED产品,它在显示应用中有着广泛的用途。
文件下载:CDSA56RR1W.pdf
CDSX56系列涵盖了多种颜色的LED产品,包括红色、超红色、黄色、绿色和蓝色等,适用于不同的显示需求,如时钟显示、点阵显示等。
所有尺寸单位为毫米(英寸),公差为± 0.25mm(0.01”),除非另有说明。同时,规格可能会随时变更,恕不另行通知。
| Part Number | Chip Material | Color of Emission | Lens Type | Description |
| CDSA56R1W | GaAsP | Red | White Segment | Common Anode |
| CDSC56R1W | GaAsP | Red | White Segment | Common Cathode |
| CDSA56RR1W | AlGaAs | Super Red | White Segment | Common Anode |
| CDSC56RR1W | AlGaAs | Super Red | White Segment | Common Cathode |
| CDSA56Y1W | GaAsP | Yellow | White Segment | Common Anode |
| CDSC56Y1W | GaAsP | Yellow | White Segment | Common Cathode |
| CDSA56G1W | GaP | Green | White Segment | Common Anode |
| CDSC56G1W | GaP | Green | White Segment | Common Cathode |
| CDSA56B1W | GaN | Blue | White Segment | Common Anode |
| CDSC56B1W | GaN | Blue | White Segment | Common Cathode |
从上述表格可以看出,不同型号的产品在芯片材料、发光颜色、透镜类型以及阳极类型上有所不同,工程师可以根据实际需求进行选择。
| Part Number | Wave- length (nm) | Absolute Maximum | Electro-Optical Characteristics | ||||||||
| Δλ nm | P d mW | I af mA | I pf (Peak) | V f (V) | I f | I v ( mcd) | |||||
| Min | Typ | Max | (Rec) | Min | Typ | ||||||
| CDSA56R1W | 625 | 45 | 75 | 30 | 100 | 1.7 | 1.85 | 2.5 | 10 | 3 | 8 |
| CDSC56R1W | 625 | 45 | 75 | 30 | 100 | 1.7 | 1.85 | 2.5 | 10 | 3 | 8 |
| CDSA56RR1W | 640 | 20 | 72 | 20 | 100 | 1.6 | 1.75 | 2.4 | 10 | 5 | 18 |
| CDSC56RR1W | 640 | 20 | 72 | 20 | 100 | 1.6 | 1.75 | 2.4 | 10 | 5 | 18 |
| CDSA56Y1W | 588 | 35 | 75 | 30 | 100 | 1.7 | 2.1 | 2.8 | 10 | 1.9 | 4.7 |
| CDSC56Y1W | 588 | 35 | 75 | 30 | 100 | 1.7 | 2.1 | 2.8 | 10 | 1.9 | 4.7 |
| CDSA56G1W | 568 | 30 | 65 | 30 | 100 | 1.7 | 2.1 | 2.8 | 10 | 3 | 10.5 |
| CDSC56G1W | 568 | 30 | 65 | 30 | 100 | 1.7 | 2.1 | 2.8 | 10 | 3 | 10.5 |
| CDSA56B1W | 470 | 30 | 120 | 30 | 100 | 3.0 | 3.5 | 4.0 | 10 | 1.9 | 8.5 |
| CDSC56B1W | 470 | 30 | 120 | 30 | 100 | 3.0 | 3.5 | 4.0 | 10 | 1.9 | 8.5 |
这些数据对于工程师设计电路时非常重要,例如,正向电压(Vf)和正向电流(If)的参数会影响到LED的驱动电路设计。不同颜色的LED在波长、功率损耗、正向电流等方面存在差异,工程师需要根据具体应用场景来选择合适的型号。
| Reverse Voltage | 5V | Spectral Line half-width (λ) | nm |
| Reverse Current (Vr = 5V) | 100μA | Power Dissipation ( P d ) | mW |
| Operating Temperature | -40˚C~+85˚C | Peak Forward Current (Duty 1/10, @ KHz) | mA |
| Storage Temperature | -40˚C~+85˚C | Recommended Operation Current ( I f Rec) | mA |
| Soldering Temperature | 250C~260C for 3 sec. | Average Luminous Intensity (I f =10) | μ A |
了解这些绝对最大额定值可以确保LED在安全的工作范围内运行,避免因超过额定值而损坏。
文档中给出了不同颜色LED的光学特性曲线,包括正向电流与正向电压、相对强度与正向电流、正向电流与环境温度、发光强度与环境温度等关系曲线。这些曲线能够帮助工程师更好地了解LED在不同工作条件下的性能表现,例如,通过正向电流与正向电压曲线可以确定LED的导通特性,从而优化驱动电路的设计。
焊接LED时,距离环氧灯泡底部不得小于3mm,建议在连接条底部以外进行焊接。
| 浸焊 | Pre-Heat | 100 ˚C Max |
| Pre-Heat Time | 60 Second Max | |
| Solder Bath Temperature | 260 ˚C Max | |
| Dippng Time | 5 Second Max | |
| Dipping Position | No lower than 3mm from the base of the epoxy |
| 手工焊接 | 3mm Series | Others | |
| Temperature Soldering Time Position | 300 ˚C Max 3 Second Max No closer than 3mm from the base of the epoxy | 350 ˚C Max 3 Second Max No closer than 3mm from the base of the epoxy |
这些焊接条件和注意事项对于保证LED的焊接质量和长期稳定性至关重要。工程师在实际操作中必须严格遵守,以避免因焊接不当而导致的产品故障。
综上所述,CDSX56系列LED产品在设计和应用中需要综合考虑封装尺寸、型号特性、光电特性、绝对最大额定值、光学特性曲线以及焊接条件等多个方面。作为电子工程师,在使用这些产品时,要充分了解其规格和特性,结合具体的应用场景进行合理的设计和选择。大家在实际应用中有没有遇到过类似LED产品的问题呢?欢迎在评论区分享。
