在电子设计领域,选择合适的多路复用器对于实现高效、稳定的电路至关重要。今天我们就来详细探讨一下ON Semiconductor推出的MC74LCX157,这是一款高性能的四通道2输入多路复用器,具有诸多出色的特性,能为电子工程师们带来更多的设计便利。
文件下载:MC74LCX157DTG.pdf
MC74LCX157可在2.3 - 3.6V的电源电压下工作,高阻抗的TTL兼容输入显著降低了输入驱动的电流负载,同时TTL兼容输出提升了开关噪声性能。其输入电压(V_{I})规格为5.5V,这意味着它能够安全地由5V设备驱动,大大增强了其与其他设备的兼容性。
| Pins | Function |
| I0n | Source 0 Data Inputs |
| I1n | Source 1 Data Inputs |
| E | Enable Input |
| S | Select Input |
| Zn | Outputs |
| Inputs | Outputs | |||
| E | S | I0n | I1n | Zn |
| H | X | X | X | L |
| L | H | X | L | L |
| L | H | X | H | H |
| L | L | L | X | L |
| L | L | H | X | H |
这里的H表示高电压电平,L表示低电压电平,X表示高或低电压电平。需要注意的是,为了(I_{CC})的原因,不要让输入浮空。
| Symbol | Parameter | Value | Condition | Units |
| (V_{CC}) | DC Supply Voltage | -0.5 to +7.0 | V | |
| (V_{I}) | DC Input Voltage | -0.5 ≤ (V_{I}) ≤ +7.0 | V | |
| (V_{O}) | DC Output Voltage | -0.5 ≤ (V{O}) ≤ (V{CC}) + 0.5 | (Note 1) | V |
| (I_{IK}) | DC Input Diode Current | -50 | (V_{I}) < GND | mA |
| (I_{OK}) | DC Output Diode Current | -50 | (V_{O}) < GND | mA |
| +50 | (V{O}) > (V{CC}) | mA | ||
| (I_{O}) | DC Output Source/Sink Current | ± 50 | mA | |
| (I_{CC}) | DC Supply Current Per Supply Pin | ± 100 | mA | |
| (I_{GND}) | DC Ground Current Per Ground Pin | ± 100 | mA | |
| (T_{STG}) | Storage Temperature Range | -65 to +150 | °C | |
| MSL | Moisture Sensitivity | Level 1 |
最大额定值是指超过该值可能会导致设备损坏的数值。这些值是单独的应力极限值,并非正常工作条件,且不能同时适用。如果超过这些极限,设备的功能操作无法保证,可能会造成损坏并影响可靠性。
| Symbol | Parameter | Min | Typ | Max | Units |
| (V_{CC}) | Supply Voltage Operating Data Retention Only | 2.0 / 1.5 | 3.3 / 3.3 | 3.6 / 3.6 | V |
| (V_{1}) | Input Voltage | 0 | 5.5 | V | |
| (V_{o}) | Output Voltage (HIGH or LOW State) | 0 | (V_{CC}) | V | |
| (I_{0H}) | HIGH Level Output Current, (V_{CC}) = 3.0V - 3.6V | -24 | mA | ||
| (I_{0L}) | LOW Level Output Current, (V_{CC}) = 3.0 V - 3.6 V | 24 | mA | ||
| (I_{OH}) | HIGH Level Output Current, (V_{CC}) = 2.7 V - 3.0 V | -12 | mA | ||
| (I_{0L}) | LOW Level Output Current, (V_{CC}) = 2.7V - 3.0V | 12 | mA | ||
| (T_{A}) | Operating Free-Air Temperature | -40 | +85 | °C | |
| (At/AV) | Input Transition Rise or Fall Rate, (V{IN}) from (0.8 V) to (2.0 V), (V{CC})=3.0V | 0 | 10 | ns/V |
| 在(T_{A}) = -40°C 到 +85°C的温度范围内,其直流电气特性如下: | Symbol | Characteristic | Condition | Min | Max | Units |
| (V_{IH}) | HIGH Level Input Voltage (Note 2) | 2.7 V ≤ (V_{CC}) ≤ 3.6 V | 2.0 | V | ||
| (V_{IL}) | LOW Level Input Voltage (Note 2) | 2.7 V ≤ (V_{CC}) ≤ 3.6 V | 0.8 | V | ||
| (V_{OH}) | HIGH Level Output Voltage | 2.7 V ≤ (V{CC}) ≤ 3.6 V; (I{OH}) = -100 μA | (V_{CC}) - 0.2 | V | ||
| (V{CC}) = 2.7 V; (I{OH}) = -12 mA | 2.2 | V | ||||
| (V{CC}) = 3.0 V; (I{OH}) = -18 mA | 2.4 | V | ||||
| (V{CC}) = 3.0 V; (I{OH}) = -24 mA | 2.2 | V | ||||
| (V_{OL}) | LOW Level Output Voltage | 2.7 V ≤ (V{CC}) ≤ 3.6 V; (I{OL}) = 100 μA | 0.2 | V | ||
| (V{CC}) = 2.7 V; (I{OL}) = 12 mA | 0.4 | V | ||||
| (V{CC}) = 3.0 V; (I{OL}) = 16 mA | 0.4 | V | ||||
| (V{CC}) = 3.0 V; (I{OL}) = 24 mA | 0.55 | V | ||||
| (I_{OFF}) | Power Off Leakage Current | (V{CC}) = 0, (V{IN}) = 5.5 V or (V_{OUT}) = 5.5 V | 10 | μA | ||
| (I_{IN}) | Input Leakage Current | (V{CC}) = 3.6 V, (V{IN}) = 5.5 V or GND | ±5 | μA | ||
| (I_{CC}) | Quiescent Supply Current | (V{CC}) = 3.6 V, (V{IN}) = 5.5 V or GND | 10 | μA | ||
| (I{CC}) Increase in (I{CC}) per Input | 2.3 ≤ (V{CC}) ≤ 3.6 V; (V{IH}) = (V_{CC}) - 0.6 V | 500 | μA |
| 在(t{R}=t{F}=2.5 ns) ,(C{L}=50 pF) ,(R{L}=500 Ω)的条件下,其交流特性如下: | Symbol | Parameter | Waveform | (V_{CC}) = 3.0 V to 3.6 V | (V_{CC}) = 2.7 V | Units | |
| Min | Max | Max | |||||
| (t_{PLH}) | Propagation Delay In to Zn | 1 | 1.5 | 1.5 | 5.8 | 6.3 | ns |
| (t_{PHL}) | 5.8 | 6.3 | ns | ||||
| (t_{PLH}) | Propagation Delay S to Zn | 1,2 | 1.5 | 1.5 | 7.0 | 8.0 | ns |
| (t_{PHL}) | 7.0 | 8.0 | ns | ||||
| (t_{PLH}) | Propagation Delay E to Zn | 2 | 1.5 | 1.5 | 7.0 | 8.0 | ns |
| (t_{OSHL}) | Output−to−Output Skew (Note 3) | 1.0 | 1.0 | ns | |||
| (t_{OSLH}) | ns |
这里的偏斜定义为同一器件的任意两个独立输出的实际传播延迟之间的差值的绝对值。该规范适用于任何同向切换的输出,无论是高到低((t{OSHL}))还是低到高((t{OSLH})),此参数通过设计保证。
| 在(T_{A}) = +25°C的条件下,其动态开关特性如下: | Symbol | Characteristic | Condition | Min | Typ | Max | Units |
| (V_{OLP}) | Dynamic LOW Peak Voltage (Note 4) | (V{CC}) = 3.3 V, (C{L}) = 50 pF, (V{IH}) = 3.3 V, (V{IL}) = 0 V | 0.8 | V | |||
| (V_{OLV}) | Dynamic LOW Valley Voltage (Note 4) | (V{CC}) = 3.3 V, (C{L}) = 50 pF, (V{IH}) = 3.3 V, (V{IL}) = 0 V | 0.8 | V |
| Symbol | Parameter | Condition | Typical | Units |
| (C_{IN}) | Input Capacitance | (V{CC}) = 3.3 V, (V{I}) = 0 V or (V_{CC}) | 7 | pF |
| (C_{OUT}) | Output Capacitance | (V{CC}) = 3.3 V, (V{I}) = 0 V or (V_{CC}) | 8 | pF |
| (C_{PD}) | Power Dissipation Capacitance | 10 MHz, (V{CC}) = 3.3 V, (V{I}) = 0 V or (V_{CC}) | 25 | pF |
MC74LCX157有SOIC - 16和TSSOP - 16两种封装形式,文档中详细给出了这两种封装的机械尺寸和焊接尺寸等信息。在实际设计中,工程师需要根据具体的应用场景和电路板布局来选择合适的封装。
| Device | Shipping † |
| MC74LCX157DR2G | 2500 Tape & Reel |
| MC74LCX157DTG | 96 Units / Rail |
| MC74LCX157DTR2G | 2500 Tape & Reel |
对于磁带和卷轴规格的信息,包括零件方向和磁带尺寸等,可参考Tape and Reel Packaging Specifications Brochure, BRD8011/D。
MC74LCX157凭借其宽电压工作范围、5V容忍输入、良好的兼容性、强大的电流驱动能力和低静态功耗等特性,成为电子工程师在设计多路复用电路时的一个不错选择。在实际应用中,工程师们需要根据具体的电路需求,结合其电气特性和封装信息,合理使用该器件,以实现最佳的电路性能。你在使用类似多路复用器的过程中遇到过哪些问题呢?欢迎在评论区分享交流。
