在电力电子领域,高效可靠的栅极驱动解决方案至关重要。Infineon的EVAL - 1ED3124Mx12H评估板,搭配1ED3124MU12H或1ED3124MC12H栅极驱动IC,为工程师们提供了一个绝佳的平台,来深入了解和评估Infineon EiceDRIVER Compact系列栅极驱动IC的功能和特性。
文件下载:EVAL1ED3124MX12HTOBO1.pdf
EVAL - 1ED3124Mx12H评估板专为评估Infineon EiceDRIVER™ Compact 1ED3124MU12H或1ED3124MC12H在应用电路中的产品特性而设计。它采用半桥配置,配备两个栅极驱动IC,可驱动如IGBT和SiC MOSFET等功率开关。该板还具备隔离过流反馈信号功能,能将高压侧的信号反馈到逻辑控制侧。此外,板上使用了快速运算放大器作为过流检测比较器。
评估板尺寸为(85 × 55 × 15 mm^{3})(未组装功率开关),非常适合进行双脉冲测试。不过,在连续运行时,需要额外考虑热和功率负载,建议在高压电源处添加一个高压直流阻断电容。其低压接口可由脉冲发生器、微控制器或其他数字电路控制,并且为了确保安全运行,还实现了快速过流检测和保护电路,通过电隔离反馈路径将信息反馈到低压输入侧。
| 评估板上的所选组件和栅极驱动IC都有最大额定值和工作条件,以避免损坏各个部件和整个评估板。以下是一些关键参数: | Pin/parameter name | Abs. Max. | Unit | Note |
| +15V_IN | -0.2 … 20 | V | input, support supply voltage | |
| VCC1 | -0.2 … 5.3 | V | input, gate driver IC supply voltage | |
| FAULT | -0.2 … VCC1 + 0.2 | V | output, digital signal | |
| RST | -0.2 … VCC1 + 0.2 | V | input, digital signal | |
| IN_HS | -0.2 … VCC1 + 0.2 | V | input, digital signal | |
| IN_LS | -0.2 … VCC1 + 0.2 | V | input, digital signal | |
| VCC2_HS , VCC2_LS | -0.2 … 40 | V | overall isolated secondary supply with reference to VEE2_HS / VEE2_LS | |
| VCC2_HS , VCC2_LS | -0.2 … 25 | V | positive secondary supply voltage with reference to GND2_HS / GND2_LS | |
| GND2_HS , GND2_LS | -0.2 … 25 | V | gate reference supply pin with reference to VEE2_HS / VEE2_LS | |
| V - HV | -0.2 … 1200 | V | input, high - voltage supply, for voltages above 42 V, special high voltage lab environment is strongly recommended | |
| Phase peak current | 25 | A | phase peak current for double pulse tests | |
| t pulse | 100 | µs | maximum ON pulse length for double - pulse tests | |
| f sw | 100 | kHz | maximum switching frequency for continuous operation, careful consideration of power dissipation required |
| Pin name | Min. | Typ. | Max. | Unit | Note |
| +15V_IN | 15.5 | 16 | 16.5 | V | input, support supply voltage |
| VCC1 | 3.2 | 3.3 | 3.4 | V | input, gate driver IC supply voltage |
| FAULT | -0.1 | 3.3 | VCC1 + 0.1 | V | output, digital signal |
| RST | -0.1 | 3.3 | VCC1 + 0.1 | V | input, digital signal |
| IN_HS | -0.1 | 3.3 | VCC1 + 0.1 | V | input, digital signal |
| IN_LS | -0.1 | 3.3 | VCC1 + 0.1 | V | input, digital signal |
| VCC2_HS , VCC2_LS | 12 | 15 | 30 | V | overall isolated secondary supply with reference to VEE2_HS / VEE2_LS |
| GND2_HS , GND2_LS | 0 | 15 | V | gate reference supply pin with reference to VEE2_HS / VEE2_LS | |
| V - HV | 25 | 600 | V | input, high voltage supply, for voltages above 42 V, special high voltage lab environment is strongly recommended |
评估板实现了过流保护功能,以保护板和组件免受大电流的损害。电流通过测量分流电阻R19两端的电压来确定,该电压可在两个测试点TP14和TP16处获取。
检测电路测量R19两端的电压,将信号通过低通滤波器R18和C18,然后与比较器U5的参考电压进行比较。参考电压由分压器R12和R20定义,跳闸点约为32 A,可以通过更改R19和/或调整参考分压器R12和R20来适应应用需求。
输出信号通过U3传输到低压域,触发触发器并存储过流事件。一旦触发器被触发,它将通过ENABLE信号关闭两个栅极驱动IC。此外,它还会将过流事件作为FAULT信号报告给数字接口连接器,并点亮LED7。
要恢复正常运行,需要按下S1复位触发器,作为反馈,LED7将熄灭,LED6将再次亮起。
| Connector | Pin | Marking/ function | Note |
| J1 | 1, 2 | V - HV | High voltage power supply |
| J2 | 1, 2 | PHASE | |
| J3 | 1 | SENSE | |
| J3 | 2 | HV_GND | |
| J4, J9 | 1 | VEE2_HS | High side negative gate driver supply |
| J4, J9 | 2 | GND2_HS | High side gate driver supply reference |
| J4, J9 | 3 | VCC2_HS | High side positive gate driver supply |
| J5, J10 | 1 | VEE2_LS | Low side negative gate driver supply |
| J5, J10 | 2 | GND2_LS | Low side gate driver supply reference |
| J5, J10 | 3 | VCC2_LS | Low side positive gate driver supply |
| J6, J7, J8, J11, J12, J13 | 1 | GND | Logic side ground reference |
| J6, J12 | 2 | VCC1 | Logic side supply voltage, 3.3 V or 5 V |
| J7 | 2 | IN_HS | Logic PWM input high side gate driver |
| J8 | 2 | IN_LS | Logic PWM input low side gate driver |
| J11 | 2 | +15V | 15 V for external power supply without protection diode |
| J11 | 3 | PWM_PSU | PWM output for external power supply from J14.9 |
| J13 | 2 | +15V_IN | 15 V input supply voltage for external power supply |
| J14 | 1, 2 | n.c. | not connected |
| J14 | 3 | VCC1 | Logic side supply voltage, 3.3 V or 5 V |
| J14 | 4 | GND | Logic side ground reference |
| J14 | 5 | RST | Reset input for overcurrent flip - flop, connected to S1 |
| J14 | 6 | FAULT | Fault feedback signal |
| J14 | 7 | IN_HS | Logic PWM input high side gate driver |
| J14 | 8 | IN_LS | Logic PWM input low side gate driver |
| J14 | 9 | PWM_PSU | PWM input for external power supply to J11.3 |
| J14 | 10 | +15V | 15 V for external power supply without protection diode |
EVAL - 1ED3124Mx12H评估板为工程师提供了一个全面的平台,用于评估Infineon EiceDRIVER Compact系列栅极驱动IC的性能。其丰富的功能和特性,如过流保护、半桥配置等,使其成为设计功率电子设备,如逆变器的理想选择。在使用过程中,工程师需要严格按照启动步骤和参数要求进行操作,以确保评估板的正常运行和测试结果的准确性。你在使用类似评估板时,有没有遇到过什么特别的问题呢?欢迎在评论区分享你的经验。
