在电机驱动应用的领域中,评估板的性能和功能对于工程师来说至关重要。今天,我们就来详细探讨一下Infineon的EVAL - M1 - 05F804R评估板,它是iMOTION™模块化应用设计套件的一部分,为电机控制提供了全面的解决方案。
EVAL - M1 - 05F804R评估板属于iMOTION™模块化应用设计套件(iMOTION™ MADK),主要用于电机控制。它通过20针的iMOTION™ MADK - M1接口连接器,能轻松与不同的控制板进行连接,适用于各种功率级别的应用。
该评估板旨在为CIPOS™ Nano功率部分提供易于理解的解决方案,具有直流输入和三相输出,包含用于电流感应的单分流器和用于直流母线电压测量的分压器。不过需要注意的是,该产品未根据汽车电子委员会的AEC Q100或AEC Q101文件进行认证,且评估板仅用于实验室条件下的评估和测试,并非商业化产品。
这款评估板是一个完整的功率评估板,配备三相智能功率模块(IPM),充分展示了Infineon的电机驱动IPM技术。CIPOS™ Nano智能功率模块IRSM005 - 800MH具有以下主要特性:
| IRSM005 - 800MH的绝对最大额定值如下: | Symbol | Description | Min | Max | Unit |
| V DS | MOSFET drain - to - source voltage | -- | 40 | V | |
| I O | Maximum DC current per MOSFET @ T C = 25 °C (Note 1) | -- | 80 | A | |
| P d | Maximum power dissipation per MOSFET @ T C =100 °C | -- | 13 | W | |
| T J (MOSFET & IC) | Operating junction temperature | -- | 150 | °C | |
| T S | Storage temperature range | -40 | 150 | °C | |
| V B | High - side floating supply voltage | -0.3 | V S +20 | V | |
| V S | High - side floating supply offset voltage | V B -20 | V B +0.3 | V | |
| V CC | Low - side fixed supply voltage | -0.3 | 20 | V | |
| V IN | Low input voltage of LIN, HIN | -0.3 | V CC +0.3V | V |
| Parameters | Values | Conditions / Comments |
| Input | ||
| Voltage | 6 - 30 V rms | Lower DC input, less motor power output |
| Input current | 10.5 A rms | Input 24 V DC, T a =25 C |
| Output | ||
| Power (3 - phase) | 240 W | Input 24 V DC, f PWM =9 kHz, T a =25°C, T case = 100°C Without heat sink |
| Current per phase | 10.2 A rms | Input 24 V DC, F PWM =9 kHz, T a =25°C, T case = 100°C without heat sink |
| DC bus voltage | ||
| Maximum DC bus voltage | 32 V | |
| Current feedback | ||
| Inverter current sensing resistor R16 | 2.7 mΩ | |
| Protections | ||
| Output current trip level | 18 A peak | Level by external comparator circuit |
| Temperature trip level | 100°C | Users need to consider the temperature gap by NTC sensor; it is recommended to set at 105°C or less |
| On - board power supply | ||
| 15 V | 15 V ± 5 %, max. 50 mA | Used for IPM and 3.3 V DC/DC |
| 3.3 V | 3.3 V ± 5 %, max. 120 mA | Used for IMC controller and protection circuits |
| PCB characteristics | ||
| Material | FR4, 2 oz. | 2 layers |
| Dimensions | 91 mm × 69 mm x 1.6 mm | |
| System environment | ||
| Ambient temperature | From 0 to 50°C | Non - condensing, maximum RH of 75% |
评估板的功能模块包括直流输入(J1)、三相输出(J2)、直流电容、带有温度传感器的CIPOS Nano IPM、电流感应、PWM保护、辅助电源和M1连接器。
| 连接器 | 引脚 | 名称 | 详情 |
| J1 - DC输入连接器 | 1 | DC+ | DC + 连接器 |
| 2 | DC - | DC - 连接器 | |
| J2 - 电机侧连接器 | 1 | U | 连接到电机U相 |
| 2 | V | 连接到电机V相 | |
| 3 | W | 连接到电机W相 | |
| J3 - iMOTION™ MADK - M1 20针接口连接器 | 1 | PWMUH | 3.3 V兼容逻辑输入,用于U相高端栅极驱动器 |
| 2 | GND | 接地 | |
| 3 | PWMUL | 3.3 V兼容逻辑输入,用于U相低端栅极驱动器 | |
以EVAL - M1 - 101T为例,系统连接步骤如下:
iMOTION™开发工具(MCEDesigner和MCEWizard)的安装程序可从Infineon iMOTIONTM网站下载。板载隔离调试器提供PC与目标iMOTION™设备之间的USB到UART桥接,具有1kV直流电气隔离。
安装MCEWizard后,在Windows桌面上会出现快捷方式。打开MCEWizard后,可从下拉列表中选择MADK控制板或功率板。若最新的功率板未预配置,可选择相似的功率板并手动输入特定参数。回答完所有问题后,点击“Calculate Parameters”和“Export to Designer File (.txt)”保存参数文件。
安装MCEDesigner后,打开“IMC101T_xx.irc”文件。将驱动系统参数文件编程到IMC101控制器后,MCEDesigner可用于启动/停止电机、显示电机电流轨迹、更改电机速度等。若要编程新固件和驱动系统参数,可通过“Tools” > “Programmer”进行操作。
MCEDesigner具有跟踪功能,可捕获系统运行期间的参数变化,有助于调试系统和检查PCB布局/参数。
在Ta = 25°C、24 VDC的条件下,不同载波频率下模块的Tc与输出电流的关系如图所示。
EVAL - M1 - 05F804R有三种冷却选项:
逆变器部分采用CIPOS™ Nano实现,使用三个半桥模块作为三相逆变器桥部分,每个半桥模块包含两个功率MOSFET和一个半桥栅极驱动器。同时还包括分流电阻部分,三个电容器C4、C5和C6用作自举电容器,分别提供必要的浮动电源电压VBU、VBV和VBW。
评估板上的电源电路包括LM5163用于从直流母线生成+3.3 V,LMR64010用于从+3.3 V生成15 V。15 V连接到CIPOS™ Nano内部的栅极驱动器,LED1用于指示板是否通电。15 V和+3.3 V也出现在20针接口连接器J3上,为控制板上的电路供电。
连接器J3的引脚14可访问直流母线电压,有三种可能的反馈情况。R42是连接器打开时连接端口的安全电阻,直流母线感应的低端电阻为R48//R1(EVAL - M1 - 101T),即13.13 kΩ。
EVAL - M1 - 05F804R的电流反馈通过R16进行信号分流感应,其阻值为5 mΩ。电流输出IU +和IU -连接到J3。LPF由R20/R23/C14/C15组成,用于去除R16的EMC噪声。电流放大器由R18/R19/R20/R22/R23/C13 U1A组成,具有较低的噪声和比例放大功能。
电流信号传输到控制板时,会经过衰减和增益调整。总增益为13.29,总灵敏度为66.4 mV/A,电流偏移为1.06 V。由于控制板ADC范围为3.3 V,需将控制板的内部增益设置为“1”。
U11B设置为高速施密特比较器,过流阈值为1.98 V,反射过流阈值为17.2 A,响应时间为100 nS。
当发生过流时,U11B引脚7输出“0”,C23迅速放电,U12B输出逻辑“0”信号,作为所有PWM输入的关闭信号和通知控制板停止PWM输出的门控信号。关闭的总延迟时间为1.6 us。过流消除后,U11B变为逻辑“1”,C23通过R36充电,充电时间常数为220 us。
对于EVAL - M1 - 101T,内部比较器的默认阈值为1.8 V(对应17 A)。可根据公式Vref = Voffset + Vshunt2 × IOC P / 1000计算MCEWizard的过流保护阈值。
评估板的SPWM输入和功率输出呈现典型的无刷电机正弦电流波形。
| EVAL - M1 - 05F804R上的NTC(R50)用于测量U2顶部的Tc,用于过热保护。温度值通过J3发送到EVAL - M1 - 101T。不同温度下NTC的电阻和输出电压如下表所示: | Temperature ( °C ) | Resistance ( kΩ) | V out (J3 open)(mV) | V out (J3 connected)(mV) |
| 25 | 100 | 1650 | 3154 | |
| 50 | 33.195 | 822 | 2895 | |
| 60 | 22.224 | 600 | 2730 | |
| 70 | 15.184 | 435 | 2527 | |
| 80 | 10.566 | 315 | 2292 | |
| 90 | 7.481 | 230 | 2036 | |
| 100 | 5.384 | 169 | 1772 | |
| 110 | 3.934 | 125 | 1513 | |
| 120 | 2.916 | 94 | 1273 | |
| 125 | 2.522 | 81 | 1161 |
评估板的PCB铜布局和覆盖层设计有助于优化电路性能。
| 完整的物料清单可在Infineon主页的下载部分获取,登录后即可下载。部分关键组件如下表所示: | Comment | Designator | Qty | Description | Footprint | Manufacturer | Part number |
| 1000u 63V | C1, C2 | 2 | Electrolytic capacitor | WCAP - AT1H_18x25 | Wurth Elektronik | 860010780024 | |
| 220u 25V | C26 | 1 | Electrolytic capacitor | CAP - E_6.3x2.5x11 mm | Wurth Elektronik | 860010473011 | |
目前,功率板可小批量订购,PCB和Gerber详情在达成合适协议后可与客户共享。客户若要进行测试,建议订购EVAL - M1 - 05F804R,可通过www.infineon.com.com/MADK在线购买。
同时,Infineon的产品注册现在可以在线完成。注册步骤如下:
总之,EVAL - M1 - 05F804R评估板为电机驱动应用提供了丰富的功能和特性,工程师们在使用过程中需仔细阅读文档,确保正确操作和使用。大家在实际应用中是否遇到过类似评估板的问题呢?欢迎在评论区分享交流。
