Fairchild Semiconductor已成为ON Semiconductor的一部分。由于ON Semiconductor产品管理系统无法处理带有下划线(_)的部件命名,Fairchild部分可订购的部件编号中的下划线将改为破折号(-)。文档中可能仍包含带有下划线的器件编号,大家可以去ON Semiconductor官网(www.onsemi.com)核实更新后的器件编号。若有关于系统集成的问题,可发邮件至Fairchild_questions@onsemi.com。
文件下载:FJP5027-D.pdf
FJP5027是一款NPN硅晶体管,具备高电压和高可靠性的特点,还拥有高速开关和宽安全工作区(SOA)的优势。其引脚分别为1.基极、2.集电极、3.发射极。
| 在 $T_{C}=25^{circ} C$(除非另有说明)的条件下,FJP5027的绝对最大额定值如下: | Symbol | Parameter | Value | Units |
| V CBO | Collector-Base Voltage | 1100 | V | |
| V CEO | Collector-Emitter Voltage | 800 | V | |
| V EBO | Emitter-Base Voltage | 7 | V | |
| I C | Collector Current (DC) | 3 | A | |
| I CP | Collector Current (Pulse) | 10 | A | |
| I B | Base Current | 1.5 | A | |
| P C | Collector Dissipation ( T C =25 ° C) | 50 | W | |
| T J | Junction Temperature | 150 | ° C | |
| T STG | Storage Temperature | - 55 ~ 150 | ° C |
这些参数为我们在设计电路时提供了安全边界,大家在使用时一定要确保各项参数不超过这些额定值,否则可能会对晶体管造成损坏。
| 同样在 $T_{C}=25^{circ} C$(除非另有说明)的条件下,FJP5027的电气特性如下: | Symbol | Parameter | Test Condition | Min. | Typ. | Max. | Units |
| BV CBO | Collector-Base Breakdown Voltage | I C = 1mA, I E = 0 | 1100 | V | |||
| BV CEO | Collector-Emitter Breakdown Voltage | I C = 5mA, I B = 0 | 800 | V | |||
| BV EBO | Emitter-Base Breakdown Voltage | I E = 1mA, I C = 0 | 7 | V | |||
| V CEX (sus) | Collector-Emitter Sustaining Voltage | I C = 1.5A, I B1 = -I B2 = 0.3A L = 2mH, Clamped | 800 | V | |||
| I CBO | Collector Cut-off Current | V CB = 800V, I E = 0 | 10 | µ A | |||
| I EBO | Emitter Cut-off Current | V EB = 5V, I C = 0 | 10 | µ A | |||
| h FE1 h FE2 | DC Current Gain | V CE = 5V, I C = 0.2A V CE = 5V, I C = 1A | 10 8 | 40 | |||
| V CE (sat) | Collector-Emitter Saturation Voltage | I C = 1.5A, I B = 0.3A | 2 | V | |||
| V BE (sat) | Base-Emitter Saturation Voltage | I C = 1.5A, I B = 0.3A | 1.5 | V | |||
| C ob | Output Capacitance | V CB = 10V, I E = 0, f = 1MHz | 60 | pF | |||
| f T | Current Gain Bandwidth Product | V CE = 10V, I C = 0.2A | 15 | MHz | |||
| t ON | Turn On Time | V CC = 400V I C = 5I B1 = -2.5I B2 = 2A R L = 200 Ω | 0.5 | µ s | |||
| t STG | Storage Time | 3 | µ s | ||||
| t F | Fall Time | 0.3 | µ s |
这些电气特性参数是我们在设计电路时进行性能评估和参数匹配的重要依据。比如,在设计开关电路时,开关时间($t{ON}$、$t{STG}$、$t_{F}$)就非常关键,它会直接影响电路的响应速度。大家思考一下,在不同的应用场景中,这些参数会如何影响电路的性能呢?
| Classification | R | O |
| h FE1 | 15 ~ 30 | 20 ~ 40 |
hFE分类为我们在选择合适的晶体管时提供了更多的参考,不同的hFE值适用于不同的电路需求。
文档中还给出了FJP5027的典型特性图,包括静态特性、直流电流增益、基极 - 发射极饱和电压与集电极 - 发射极饱和电压、基极 - 发射极导通电压、开关时间、安全工作区、电阻负载开关特性、功率降额等。这些典型特性图可以帮助我们更直观地了解晶体管在不同工作条件下的性能表现。大家在实际应用中,可以根据这些特性图来优化电路设计,提高电路的性能和稳定性。
ON Semiconductor对产品有一些重要声明。产品参数可能会在不同应用中有所变化,实际性能也可能随时间改变,所有工作参数(包括“典型值”)都需要客户的技术专家针对每个客户应用进行验证。此外,ON Semiconductor产品不设计、不打算也未获授权用于生命支持系统、FDA 3类医疗设备或类似分类的医疗设备以及人体植入设备。如果购买或使用产品用于非预期或未授权的应用,买方需承担相关责任。
大家在使用FJP5027晶体管进行电路设计时,一定要仔细参考这些参数和说明,确保设计出的电路稳定可靠。同时,也要关注ON Semiconductor官网的最新信息,以便获取最准确的产品数据。希望这篇文章能对大家的设计工作有所帮助,大家在实际应用中有什么问题,欢迎一起交流探讨。
