在电子工程师的设计工作中,压控振荡器(VCO)是一个关键的组件,它的性能直接影响到整个系统的稳定性和可靠性。今天,我们就来深入了解一下HMC529LP5 / 529LP5E这款MMIC VCO,看看它有哪些独特的优势和应用场景。
文件下载:110227-HMC529LP5.pdf
HMC529LP5 / 529LP5E是GaAs InGaP异质结双极晶体管(HBT)MMIC VCO,集成了谐振器、负阻器件、变容二极管,具备半频和四分频输出功能。其工作频率范围为12.4 - 13.4 GHz,半频输出范围为6.2 - 6.7 GHz,典型功率输出为+8 dBm。
这款VCO适用于多种领域,包括:
提供Fo = 12.4 - 13.4 GHz和Fo / 2 = 6.2 - 6.7 GHz的双输出,满足不同的应用需求。
典型相位噪声为 -110 dBc/Hz @ 100 kHz,在温度、冲击和工艺变化时仍能保持出色的相位噪声性能,这得益于其单片结构。
简化了设计,减少了外部元件的使用,降低了成本和电路板空间。
采用32引脚5x5mm SMT封装,尺寸仅为25mm²,适合对空间要求较高的应用。
| 在 (T_{A}=+25^{circ} C) ,Vcc1, (Vcc 2=+5 ~V) 的条件下,其主要电气规格如下: | Parameter | Min. | Typ. | Max. | Units |
| Frequency Range (Fo) | 12.4 - 13.4 | GHz | |||
| Frequency Range (Fo/2) | 6.2 - 6.7 | GHz | |||
| Power Output (RFOUT) | +4 | +10 | dBm | ||
| Power Output (RFOUT/2) | +6 | +11 | dBm | ||
| Power Output (RFOUT/4) | -9 | -3 | dBm | ||
| SSB Phase Noise @ 100 kHz Offset, Vtune= +5V @ RFOUT | -110 | dBc/Hz | |||
| Tune Voltage | 2 | 13 | V | ||
| Supply Current (Icc1 & Icc2) | 220 | 260 | 300 | mA | |
| Tune Port Leakage Current (Vtune= 13V) | 10 | µA | |||
| Output Return Loss | 8 | dB | |||
| Harmonics/Subharmonics (1/2) | 25 | dBc | |||
| Harmonics/Subharmonics (3/2) | 34 | dBc | |||
| Harmonics/Subharmonics (2nd) | 18 | dBc | |||
| Harmonics/Subharmonics (3rd) | 35 | dBc | |||
| Pulling (into a 2.0:1 VSWR) | 5 | MHz pp | |||
| Pushing @ Vtune= 5V | 6 | MHz/V | |||
| Frequency Drift Rate | 1.2 | MHz/°C |
| 为了确保设备的安全和可靠性,使用时需要注意以下绝对最大额定值: | Parameter | Value |
| Vcc1, Vcc2 | +5.5 Vdc | |
| Vtune | 0 to +15V | |
| Junction Temperature | 135 °C | |
| Continuous Pdiss (T=85 °C) (derate 37 mW/C above 85 °C) | 1.85 W | |
| Thermal Resistance (junction to ground paddle) | 27 °C/W | |
| Storage Temperature | -65 to +150 °C | |
| Operating Temperature | -40 to +85 °C | |
| ESD Sensitivity (HBM) | Class 1A |
| Part Number | Package Body Material | Lead Finish | MSL Rating | Package Marking [3] |
| HMC529LP5 | Low Stress Injection Molded Plastic | Sn/Pb Solder | MSL3 [1] | H529 XXXX |
| HMC529LP5E | RoHS-compliant Low Stress Injection Molded Plastic | 100% matte Sn | MSL3 [2] | H529 XXXX |
[1] Max peak reflow temperature of 235 °C [2] Max peak reflow temperature of 260 °C [3] 4-Digit lot number XXXX
| Pin Number | Function | Description |
| 1 - 3, 7 - 10, 13 - 18, 20, 22 - 28, 30 - 32 | N/C | No Connection. These pins may be connected to RF/ DC ground. Performance will not be affected. |
| 4 | RFOUT/4 | Divide-by-4 Output. |
| 6 | Vcc1 | Supply Voltage for prescaler. If prescaler is not required, this pin may be left open to conserve 65 mA of current. |
| 12 | RFOUT/2 | Half frequency output (AC coupled). |
| 19 | RF OUT | RF output (AC coupled). |
| 21 | Vcc2 | Supply Voltage, +5V |
| 29 | VTUNE | Control Voltage and Modulation Input. Modulation bandwidth dependent on drive source impedance. |
| 5, 11, Paddle | GND | Package bottom has an exposed metal paddle that must be connected to RF/DC ground. |
| 在实际应用中,该VCO的电路设计需要采用RF电路设计技术,信号线路应具有50欧姆阻抗,封装接地引脚和背面接地焊盘应直接连接到接地平面。评估电路板可向Hittite申请获取,其材料清单如下: | Item | Description |
| J1 - J4 | PCB Mount SMA RF Connector | |
| J5 - J6 | 2 mm DC Header | |
| C1 - C3 | 100 pF Capacitor, 0402 Pkg. | |
| C4 | 1,000 pF Capacitor, 0402 Pkg. | |
| C5 - C7 | 2.2 µF Tantalum Capacitor | |
| U1 | HMC529LP5(E) VCO | |
| PCB [2] | 110225 Eval Board |
[1] Reference this number when ordering complete evaluation PCB [2] Circuit Board Material: Arlon 25FR
HMC529LP5 / 529LP5E MMIC VCO以其高性能、小型封装和丰富的输出功能,为电子工程师在设计高频电路时提供了一个优秀的选择。在实际应用中,我们需要根据具体的需求和条件,合理选择和使用这款VCO,以确保系统的稳定性和可靠性。大家在使用过程中遇到过哪些问题呢?欢迎在评论区分享交流。
