在电子设计中,电压监测是确保系统稳定运行的关键环节。ADM1184作为一款 ±0.8%精确的四通道电压监测器,为我们提供了可靠的电压监测解决方案。而EVAL - ADM1184评估套件则是我们深入了解和应用ADM1184的重要工具。今天,就让我们一起来详细了解这个评估套件。
文件下载:EVAL-ADM1184EBZ.pdf
该评估套件配备了LED灯,能清晰直观地显示设备的运行状态。无论是主电源电压、四个被监测的电压轨,还是四个输出(OUT1到OUT3)以及系统电源正常信号(PWRGD),都能通过LED灯一目了然地呈现出来。这对于工程师快速判断设备状态非常有帮助,你是否在实际设计中也经常使用LED来指示状态呢?
套件设有专用的电源开关和启用/禁用开关,方便工程师对设备进行控制。同时,板载的测试点允许对ADM1184的运行情况进行检查,为调试和测试提供了便利。
套件包含ADM1184主评估板,这是整个评估的核心部分。
还提供了2个ADM1184样品,方便工程师进行测试和验证。如果评估板上没有焊接芯片,在通电前将一个样品放入标记为U6的插座即可。
| Pin | Name | Function |
| J1 J3 | Power connector Terminal block | J1 - 1: Connects the positive terminal of the bench power supply to the evaluation board J1 - 2: Connects the ground terminal of the bench power supply to the evaluation board J3 - 1: Connects a 9 V power supply to the evaluation board |
| J3 - 2: Connects a 9 V power supply to ground |
通过J1可以连接台式电源,J3可以连接9V电源,为评估板提供不同的供电方式。
| Switch | Description | Position | Function |
| S0 | Switch for powering board on/off | 9 V V CC | Set to this position when powering the board via J3 Set to this position when powering the board via J1 |
| S1 | Switch for turning on/off the 3.3 V rail which is monitored by the VIN1 pin | On position Off position | Enables Regulator U1 Disables Regulator U1 |
| S2 | Switch for turning on/off the 2.5 V rail which is monitored by the VIN2 pin | On position Off position | Enables Regulator U2 Disables Regulator U2 |
| S3 | Switch for turning on/off the 1.8 V rail which is monitored by the VIN3 pin | On position Off position | Enables Regulator U3 Disables Regulator U3 |
| S4 | Switch for turning on/off the 1.5 V rail which is monitored by the VIN4 pin | On position Off position | Enables Regulator U4 Disables Regulator U4 |
| VR1 | Rotary switch | N/A | Reduces the 3.3 V supply level when the switch is turned clockwise |
| VR2 | Rotary switch | N/A | Reduces the 2.5 V supply level when the switch is turned clockwise |
| VR3 | Rotary switch | N/A | Reduces the 1.8 V supply level when the switch is turned clockwise |
| VR4 | Rotary switch | N/A | Reduces the 1.5 V supply level when the switch is turned clockwise |
这些开关可以方便地控制各个电压轨的开启和关闭,以及调节电压水平。你在设计中如何选择合适的开关来满足不同的控制需求呢?
| Jumper | Description | Default |
| J2 | Connects J1 - 1 to J3 - 1 | Not inserted |
| J5 | Connects VR2 to the feedback pin of Regulator U2 | Inserted |
| J6 | Connects VR3 to the feedback pin of Regulator U3 | Inserted |
| J8 | Connects VR1 to the feedback pin of Regulator U1 | Inserted |
| J12 | Connects VR4 to the feedback pin of Regulator U4 | Inserted |
跳线的设置可以改变电路的连接方式,从而实现不同的功能。
| LED | Name | Function |
| D1 | VCC | A red LED indicates that the board is powered on |
| D2 | 3.3 V (VIN1) | A yellow LED indicates the status of the 3.3 V supply voltage |
| D3 | 2.5 V (VIN2) | A yellow LED indicates the status of the 2.5 V supply voltage |
| D4 | 1.8 V (VIN3) | A yellow LED indicates the status of the 1.8 V supply voltage |
| D5 | 1.5 V (VIN4) | A yellow LED indicates the status of the 1.5 V supply voltage |
| D6 | OUT1 | A green LED indicates when the OUT1 output is asserted |
| D7 | OUT2 | A green LED indicates when the OUT2 output is asserted |
| D8 | OUT3 | A green LED indicates when the OUT3 output is asserted |
| D9 | PWRGD | A green LED indicates when the PWRGD output is asserted |
LED灯的状态可以实时反映设备的运行情况,为工程师提供直观的反馈。
| Test Point | Function |
| 1_5V | Connected to the 1.5 V rail |
| 1_8V | Connected to the 1.8 V rail |
| 2_5V | Connected to the 2.5 V rail |
| 3_3V | Connected to the 3.3 V rail |
| GND | Connected to ground |
| GND1 | Connected to ground |
| GND2 | Connected to ground |
| GND3 | Connected to ground |
| OUT1 | Connected to the OUT1 pin of the ADM1184 device |
| OUT2 | Connected to the OUT2 pin of the ADM1184 device |
| OUT3 | Connected to the OUT3 pin of the ADM1184 device |
| PWRGD | Connected to the PWRGD pin of the ADM1184 device |
| VIN1 | Connected to VIN1 pin of the ADM1184 device |
| VIN2 | Connected to VIN2 pin of the ADM1184 device |
| VIN3 | Connected to VIN3 pin of the ADM1184 device |
| VIN4 | Connected to VIN4 pin of the ADM1184 device |
测试点可以方便工程师对各个电压轨和输出信号进行测量和监测。
评估板有两种供电方式:通过J3连接9V电源或通过J1连接台式电源。使用9V电源时,需将S2置于9V位置;使用台式电源时,将S2调整到VCC位置。
ADM1184监测四个独立的电压轨,VIN1、VIN2、VIN3和VIN4引脚外部的电阻网络设置了被监测电压轨(3.3V、2.5V、1.8V和1.5V)的触发点。输出OUT1到OUT3仅取决于其关联的输入。当VINx输入电压达到0.6V时,经过30μs延迟后,相应的OUTx输出被置位。当所有四个被监测电源超过其编程阈值时,系统电源正常信号(PWRGD)被置位,该输出有190ms的内部延迟。如果任何一个被监测电源低于其编程阈值,相应的OUTx输出和PWRGD输出将被复位。
将四个旋转开关完全逆时针旋转,然后通过切换相关的专用开关S1到S4将四个电压轨上电,上电顺序可以任意。黄色LED(D2、D3、D4和D5)显示四个电压轨的状态,绿色LED(D6、D7、D8和D9)显示OUT1到OUT3输出和系统PWRGD信号的置位情况。可以很容易观察到电源正常信号置位的190ms延迟。
通过四个旋转开关VR1到VR4可以模拟故障条件。顺时针旋转旋转开关会降低关联的输入电压。当VINx输入引脚的电压低于0.6V时,OUTx输出接地,PWRGD输出也立即复位。
评估板的原理图详细展示了电路的连接方式,为工程师深入了解电路原理和进行调试提供了重要依据。
| Qty | Reference Designator | Description | Part No. 1 |
| 2 | C1, C16 | 0.1 μF, 0603 capacitor | FEC 432210 |
| 8 | C2, C4, C5, C7, C9, C10, C11, C13 | 1 μF, 0603 capacitor | FEC 3188840 |
| 4 | C3, C6, C8, C12 | 470 pF, 0402 capacitor | FEC 3019366 |
| 2 | C14, C15 | 10 μF, 0603 capacitor | FEC 9753893 |
| 1 | D1 | 0805 red LED | FEC 1021302 |
| 4 | D2, D3, D4, D5 | 0805 yellow LED | FEC 1318247 |
| 4 | D6, D7, D8, D9 | 0805 green LED | FEC 1318243 |
| 1 | J1 | 2 - pin terminal block, connector/power | FEC 151789 |
| 5 | J2, J5, J6, J8, J12 | Jumper, SIP - 2P | FEC 1022247 |
| 1 | J3 | DC barrel power connector, connectorbarrel | FEC 224959 |
| 8 | Q1, Q2, Q3, Q4, Q5, Q6, Q7, Q8 | NPD SMD transistor, SOT - 23 | FEC 1081239 |
| 21 | R1, R2, R3, R8, R14, R17, R25, R26, R27, R28, R29, R30, R31, R32, R33, R36, R40, R41, R49, R53, R54 | 1 kΩ, 0805 resistor | FEC 9332383 |
| 1 | R4 | 162 kΩ, 0805 resistor | FEC 1160272 |
| 2 | R5, R7 | 36 kΩ, 0805 resistor | FEC 1108905 |
| 1 | R6 | 115 kΩ, 0805 resistor | FEC 1140356 |
| 1 | R9 | 76.8 kΩ, 0805 resistor | FEC 1141007 |
| 2 | R10, R21 | 140 kΩ, 0805 resistor | FEC 1160268 |
| 1 | R11 | 390 kΩ, 0805 resistor | FEC 9333185 |
| 2 | R12, R48 | 200 kΩ, 0805 resistor | FEC 9332782 |
| 3 | R13, R19, R52 | 100 kΩ, 0805 resistor | FEC 9332405 |
| 2 | R15, R20 | 110 kΩ, 0805 resistor | FEC 9332464 |
| 1 | R16 | 470 kΩ, 0805 resistor | FEC 9333282 |
| 1 | R18 | 150 kΩ, 0805 resistor | FEC 9332626 |
| 1 | R22 | 75 kΩ, 0603 resistor | FEC 9331522 |
| 1 | R23 | 620 kΩ, 0805 resistor | FEC 9333444 |
| 1 | R24 | 39 kΩ, 0805 resistor | FEC 9333177 |
| 1 | R43 | 220 kΩ, 0805 resistor | FEC 9332839 |
| 1 | R44 | 62 kΩ, 0805 resistor | FEC 9333436 |
| 1 | R46 | 910 kΩ, 0805 resistor | FEC 9333657 |
| 1 | R47 | 1.8 kΩ, 0805 resistor | FEC 9332715 |
| 5 | S0, S1, S2, S3, S4 | SPDT slide switch, SW - SPDT - SLIDE | FEC 1123875 |
| 4 | VR1, VR2, VR3, VR4 | Trimmer potentiometer, 1 M, VRES_ROTARY | FEC 9608290 |
| 16 | 1_5V, 1_8V, 2_5V, 3_3V, GND, GND1, GND2, GND3, OUT1, OUT2, OUT3, PWRGD, VIN1, VIN2, VIN3, VIN4 | Testpoint | FEC 8731144 |
| 4 | U1, U2, U3, U4 | ADP3334ARM adjustable LDO regulator, MS08 | Free issue by Analog Devices |
| 1 | U5 | ADM1184 quad voltage monitor MS010 | Free issue by Analog Devices |
| 1 | U6 | 10 - pin MSOP socket, MS010 - SKT | Abrel Products 6560102211 |
| 1 | U7 | 3 - terminal 0.1 A positive voltage regulator, TO - 92 | FEC 9489444 |
| Model | Description |
| EVAL - ADM1184EBZ 1 | ADM1184 Evaluation Kit |
该设备对静电放电(ESD)敏感,尽管产品具有专利或专有保护电路,但高能量ESD仍可能对设备造成损坏。因此,在操作时应采取适当的ESD预防措施,以避免性能下降或功能丧失。
总之,EVAL - ADM1184评估套件为我们提供了一个全面了解和应用ADM1184四通道电压监测器的平台。通过对该套件的深入研究和使用,我们可以更好地掌握电压监测技术,为电子设计提供更可靠的保障。你在使用类似评估套件时遇到过哪些问题呢?欢迎在评论区分享你的经验。
