在电子设备的设计中,显示屏是人机交互的重要组成部分。MOP - AV202C并行显示屏作为一款采用行业标准通信接口的产品,为各类新老应用提供了低成本的显示解决方案。接下来,我们将深入探讨这款显示屏的特性、硬件、操作指令等关键内容。
文件下载:MOP-AV202C-BNNN-01J-3IN.pdf
MOP - AV202C属于Matrix Orbital并行显示系列,具备以下显著特性:
有MOP - AV204A的机械图纸可供参考,虽然文档未详细展示图纸内容,但它对于硬件安装和设计布局具有重要指导意义。
| 显示控制引脚: | Pin | Symbol | Description |
| 1 | VSS | Ground | |
| 2 | VCC | Supply Voltage | |
| 3 | NC | No Connect | |
| 4 | RS | Register Select | |
| 5 | R/W | Read/Write | |
| 6 | E | Enable |
| 并行数据引脚: | Pin | Symbol | Description |
| 7 | DB0 | * Data bit 0 | |
| 8 | DB1 | * Data bit 1 | |
| 9 | DB2 | * Data bit 2 | |
| 10 | DB3 | * Data bit 3 | |
| 11 | DB4 | Data bit 4 | |
| 12 | DB5 | Data bit 5 | |
| 13 | DB6 | Data bit 6 | |
| 14 | DB7 | Data bit 7 |
注:在4位模式下,DB0 - DB3不使用。
MOP系列使用标准的HD44780兼容控制器进行控制。通过拉高芯片使能(E)引脚来启用显示屏,使用读/写(R/W)输入控制与设备的通信,通过寄存器选择(RS)线选择两个可用的8位寄存器之一。当执行指令寄存器(IR)操作时,显示屏会将数据总线的最高有效位DB7拉高,此时忙标志(BF)置位,发送到设备的任何指令都将被忽略。通过对指令寄存器执行读操作,可以随时获取该标志的状态和地址计数器(AC)的当前位置。
| RS | R/W | Operation |
| 0 | 0 | IR write as an internal operation (display clear, etc.) |
| 0 | 1 | Read busy flag (DB7) and address counter (DB0 to DB6) |
| 1 | 0 | Write data to DDRAM or CGRAM (DR to DDRAM or CGRAM) |
| 1 | 1 | Read data from DDRAM or CGRAM (DDRAM or CGRAM to DR) |
| Instruction | Instruction Code | Description | ||||||||||
| RS | R/W | DB7 | DB6 | DB5 | DB4 | DB3 | DB2 | DB1 | DB0 | |||
| Clear Display | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | Write “20H” to all DDRAM locations, set DDRAM address to “00H”, return cursor to its original position, and set I/D to “1”. | |
| Return Home | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | - | cursor to its original position if shifted. The contents of DDRAM are not changed. Set DDRAM address to “00H” and return | |
| Entry Mode Set | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | I/D | SH | to shift affecting only DDRAM. Assign cursor moving direction and enable the opposite is true when reset to “0”. Setting SH to “1” causes the entire display CRAM addresses are incremented and cursor moves right when I/D is set to “1”, the shift of entire display. DDRAM and | |
| Display ON/OFF Control | 0 | 0 | 0 | 0 | 0 | 0 | 1 | D | - | B | on/off control bit. Setting D or B to “1” will cause the display or blinking cursor to Set display (D), and blinking of cursor (B) turn on; the opposite is true for reset. | |
| Cursor or Display Shift | 0 | 0 | 0 | 0 | 0 | 1 | S/C | R/L | - | - | altered. Set cursor moving and display shift control bit, and the direction, without changing of will move the cursor through all screen positions. Setting R/L to “1” will shift right DDRAM data. Setting S/L to “1” will shift the screen horizontally while the opposite immediately. AC and DDRAM are not | |
| Function Set | 0 | 0 | 0 | 0 | 1 | DL | - | - | - | - | Set interface data length. Setting DL to “1” specifies 8 - bit mode, “0” 4 - bit. | |
| Set Brightness | 1 | 0 | - | - | - | - | - | - | BR1 | BR0 | BR1 BR0 0 0 0 1 1 0 1 1 | Brightness 100% (Default) 75% 50% 25% |
| Set CGRAM Address | 0 | 0 | 0 | 1 | AC5 | AC4 | AC3 | AC2 | AC1 | AC0 | Set CGRAM address in address counter. | |
| Set DDRAM Address | 0 | 0 | 1 | AC6 | AC5 | AC4 | AC3 | AC2 | AC1 | AC0 | Set DDRAM address in address counter. | |
| Read Busy Flag and Address | 0 | 1 | BF | AC6 | AC5 | AC4 | AC3 | AC2 | AC1 | AC0 | Read the status of the display controller through the BF Bit. The contents of address counter can also be read. | |
| Write Data to RAM | 1 | 0 | D7 | D6 | D5 | D4 | D3 | D2 | D1 | D0 | Write data into internal RAM (DDRAM/CGRAM), location is determined by the AC. AC and display shift are adjusted as specified. | |
| Read Data from RAM | 1 | 1 | D7 | D6 | D5 | D4 | D3 | D2 | D1 | D0 | previous to this. Only AC is adjusted. Read data from internal RAM (DDRAM/CGRAM), location is determined by the AC, set command is recommended |
字符发生器ROM可存储多达256个5×7点阵字符模式,前16个字符保留给CGRAM中保存的自定义字符。
CGRAM允许创建多达8个5×7字符模式。每个字符地址分配7个字节,其最低有效5位代表5个像素列,第8个字节代表跨越所有5列的下划线。通过将CGRAM中相应位置的位设置为“1”来激活像素。每个字符在CGRAM中有8个地址,对应其8个像素行。最高3位代表DDRAM中的字符地址,最低3位代表从顶部开始的行位置。每个字符可以通过其8位字符代码在DDRAM中引用并写入屏幕,且每个字符可由两个代码寻址。
文档给出了写时序波形和读时序波形的相关参数,如RS、E、R/W、D0 - D7等信号的最小时间要求,这些参数对于确保正确的通信和显示至关重要。在设计电路时,需要严格按照这些时序要求进行信号控制,否则可能会导致数据传输错误或显示异常。
在开始任何应用之前,建议对所有显示设置进行初始化。文档提供了8位和4位通信模式下的初始化算法。在第一个等待条件之前,需让Vcc上升到2.7V并等待40ms。在随后的三个功能设置命令期间,忙标志无法检查,直到最后一个块才可用。在4位模式下,要注意发送的总位数为8位。最后一个初始化块将根据指定设置行数和字符字体,关闭显示,发出显示清除命令,并最终设置所需的输入模式。
| Item | Symbol | Min | Typ | Max | Unit |
| Supply Voltage For Logic | VCC | 4.75 | 5.0 | 5.25 | V |
| Input Logic High Voltage | VIH | 2.0 | - | VCC | V |
| Input Logic Low Voltage | VIL | 0 | - | 0.8 | V |
| Supply Current (Display OFF) | ICC | - | 2 | 10 | mA |
| Supply Current (Display ON) | ICC | - | 130 | 200 | mA |
| Supply Current (Initial Inrush) | ICC | - | 260 | 400 | mA |
| Item | Dimension | Unit |
| Number of Characters | 20 Characters x 2 Lines | - |
| Module dimension | 116.0 x 37.0 x 16.0 | mm |
| Active area | 70.8 x 11.5 | mm |
| Character size | 2.40 x 4.70 | mm |
| Character pitch | 3.60 x 6.10 | mm |
| Dot size | 0.40 x 0.50 | mm |
| Dot pitch | 0.50 x 0.70 | mm |
| Luminance | 350 | cd/m² |
| Colour of Illumination | Green (Blue - Green) |
| Item | Symbol | Min | Max | Unit |
| Operating Temp. | Top | -40 | 85 | ℃ |
| Storage Temp. | Tstr | -50 | 85 | ℃ |
注:最大相对湿度为80%,无冷凝。
| V | 2 | C |
| 3 | 5 | 6 |
| B | ||
| 7 |
| # | Designator | Options |
| 1 | Product Line | MOP: Matrix Orbital Parallel Display |
| 2 | Display Type | A: Alphanumeric |
| 3 | Screen Type | V: Vacuum Florescent Display |
| 4 | Display Columns | 16: Sixteen Character Columns 20: Twenty Character Columns |
| 5 | Display Rows | 2: Two Character Rows 4: Four Character Rows |
| 6 | Display Form Factor | A: A Form Factor C: C Form Factor |
| 7 | IC Package | B: Chip on Board |
| 8 | LCD Glass Type | N: Not Applicable |
| 9 | Polarizer Style | N: Not Applicable |
| 10 | Backlight Colour | N: Not Applicable |
| 11 | Viewing Angle | 0: Not Applicable |
| 12 | Controller | 1: HD44870 Compatible |
| 13 | Character Set | J: Japanese |
| 14 | Input Voltage | 3: 5.0V |
| 15 | Temperature Range | I: Industrial |
| 16 | Negative Voltage Generation | N: None Provided |
| Sales | Support | Online |
| Phone: 403.229.2737 | Phone: 403.204.3750 | Purchasing: www.matrixorbital.com |
| Email: sales@matrixorbital.ca | Email: support@matrixorbital.ca | Support: www.matrixorbital.ca |
通过以上对MOP - AV202C并行显示屏的详细介绍,相信电子工程师们对该产品有了更深入的了解。在实际设计中,我们应充分考虑其特性、规格和注意事项,以确保显示屏的正常运行和良好性能。大家在使用过程中遇到过哪些问题呢?欢迎在评论区分享交流。
