在电力电子领域,功率模块的性能、效率和可靠性对于各种应用至关重要。今天,我们就来深入了解一款由MICROCHIP公司推出的boost chopper 1200 V/254 A全碳化硅(SiC)功率模块——MSCSM120DAM11CT3AG。
MSCSM120DAM11CT3AG是一款专为特定应用设计的升压斩波功率模块。其电气原理图和引脚位置有明确规定,如Pins 25到28、Pins 13到16、Pins 18/19/20/22必须分别短接在一起。同时需要注意,所有额定值在 (T_{J}=25^{circ} C) 条件下给出,并且该器件对静电放电敏感,使用时要遵循正确的处理程序。
该模块适用于感应加热和焊接、太阳能逆变器以及不间断电源等应用场景,展现了其在不同领域的通用性和适应性。
| Symbol | Parameter | Max Ratings | Unit |
| VDSS | Drain - source voltage | 1200 | V |
| ID (TC = 25 °C) | Continuous drain current | 254 | A |
| ID (TC = 80 °C) | Continuous drain current | 202 | A |
| IDM | Pulsed drain current | 500 | A |
| VGS | Gate - source voltage | –10/25 | V |
| RDSon | Drain - source ON resistance | 10.4 | mΩ |
| PD (TC = 25 °C) | Power dissipation | 1067 | W |
需要注意的是,虽然这是SiC MOSFET器件的规格,但由于功率连接器的尺寸限制,输出电流必须受到限制。
| Symbol | Characteristic | Test Conditions | Min | Typ | Max | Unit |
| IDSS | Zero gate voltage drain current | VGS = 0 V; VDS = 1200 V | 30 | 300 | µA | |
| RDS(on) (VGS = 20 V, TJ = 25 °C) | Drain - source on resistance | ID = 120 A | 8.4 | 10.4 | mΩ | |
| RDS(on) (TJ = 175 °C) | Drain - source on resistance | ID = 120 A | 13.4 | mΩ | ||
| VGS(th) | Gate threshold voltage | VGS = VDS, ID = 3 mA | 1.8 | 2.8 | V | |
| IGSS | Gate - source leakage current | VGS = 20 V, VDS = 0 V | 300 | nA |
| Ciss | Input capacitance | f = 1 MHz, VGS = 0 V, VDS = 1000 V | 9060 | pF | ||
| Coss | Output capacitance | 810 | pF | |||
| Crss | Reverse transfer capacitance | 75 | pF | |||
| Qg | Total gate charge | ID = 120 A, VGS = –5 V/20 V, VBus = 800 V | 696 | nC | ||
| Qgs | Gate - source charge | 123 | nC | |||
| Qgd | Gate - drain charge | 150 | nC | |||
| Td(on) | Turn - on delay time | ID = 150 A, VGS = –5 V/20 V, VBus = 600 V | 30 | ns | ||
| Tr | Rise time | 30 | ns | |||
| Td(off) | Turn - off delay time | RGon = 2.7 Ω; RGoff = 1.6 Ω | 50 | ns | ||
| Tf | Fall time | 25 | ns | |||
| Eon | Turn on energy | Inductive switching, TJ = 150 °C, VBus = 600 V, VGS = –5 V/20 V, ID = 150 A, RGon = 2.7 Ω, RGoff = 1.6 Ω | 3.0 | mJ | ||
| Eoff | Turn off energy | Inductive switching, TJ = 150 °C, VBus = 600 V, VGS = –5 V/20 V, ID = 150 A, RGon = 2.7 Ω, RGoff = 1.6 Ω | 2.0 | mJ | ||
| RGint | Internal gate resistance | 2.0 | Ω | |||
| RthJC | Junction - to - case thermal resistance | 0.141 | °C/W |
| VSD (VGS = 0 V; ISD = 120 A) | Diode forward voltage | 4.0 | V | |||
| VSD (VGS = –5V ; ISD = 120 A) | Diode forward voltage | 4.2 | V | |||
| trr | Reverse recovery time | ISD = 120 A; VGS = –5 V, VR = 800 V; diF/dt = 3000 A/μs | 90 | ns | ||
| Qrr | Reverse recovery charge | 1650 | nC | |||
| Irr | Reverse recovery current | 40.5 | A |
| VRRM | Peak repetitive reverse voltage | 1200 | V | |||
| IRM (TJ = 25 °C) | Reverse leakage current | VR = 1200 V | 60 | 1200 | μA | |
| IRM (TJ = 175 °C) | Reverse leakage current | VR = 1200 V | 900 | μA | ||
| IF (TC = 100 °C) | DC forward current | 180 | A | |||
| VF (TJ = 25 °C) | Diode forward voltage | IF = 180 A | 1.5 | 1.8 | V | |
| VF (TJ = 175 °C) | Diode forward voltage | IF = 180 A | 2.1 | V | ||
| Qc | Total capacitive charge | VR = 600 V | 780 | nC | ||
| C (f = 1 MHz, VR = 400 V) | Total capacitance | 846 | pF | |||
| C (f = 1 MHz, VR = 800 V) | Total capacitance | 630 | pF | |||
| RthJC | Junction - to - case thermal resistance | 0.175 | °C/W |
| Symbol | Characteristic | Min | Max | Unit |
| VISOL | RMS isolation voltage, any terminal to case (t = 1 min, 50 Hz/60 Hz) | 4000 | V | |
| TJ | Operating junction temperature range | –40 | 175 | °C |
| TJOP | Recommended junction temperature under switching conditions | –40 | TJmax – 25 | °C |
| TSTG | Storage temperature range | –40 | 125 | °C |
| TC | Operating case temperature | –40 | 125 | °C |
| Torque | Mounting torque (To heatsink, M4) | 2 | 3 | N.m |
| Wt | Package weight | 110 | g |
| Symbol | Characteristic | Min | Typ | Max | Unit |
| R25 | Resistance at 25 °C | 50 | kΩ | ||
| ∆R25/R25 | 5 | % | |||
| B25/85 (T25 = 298.15 K) | 3952 | K | |||
| ∆B/B (TC = 100 °C) | 4 | % |
其电阻计算公式为 [R{T}=frac{R{25}}{exp left[B{25 / 85}left(frac{1}{T{25}}-frac{1}{T}right)right]}] ,其中T为热敏电阻温度,(R_{T}) 为T时的电阻值。
文档中还给出了典型的SiC MOSFET和SiC二极管性能曲线,包括最大热阻抗、输出特性、归一化 (R_{DS(on)}) 与温度关系、开关能量与 (Rg) 和电流的关系、电容与漏源电压关系、栅极电荷与栅源电压关系、体二极管特性、第三象限特性以及工作频率与漏极电流关系等曲线。这些曲线有助于工程师更直观地了解模块在不同条件下的性能表现。
模块的封装规格通过轮廓图展示,尺寸以毫米为单位。同时,可参考www.microsemi.com上的应用笔记1906获取SP3F功率模块的安装说明。
MSCSM120DAM11CT3AG功率模块凭借其出色的特性和性能,在感应加热、太阳能逆变器和不间断电源等领域具有广阔的应用前景。其SiC技术的应用带来了高速开关、低损耗等优势,同时良好的热性能和封装设计也为实际应用提供了便利。
作为电子工程师,在使用这款模块时,需要根据具体的应用需求,结合其电气规格和性能曲线进行合理设计。例如,如何根据模块的热阻和散热要求设计合适的散热系统,如何根据开关特性选择合适的驱动电路等。大家在实际应用中是否遇到过类似功率模块的设计难题呢?又是如何解决的呢?欢迎在评论区分享你的经验和见解。
