在电子设计领域,液晶显示模块是人机交互的重要组成部分。今天我们来深入了解Newhaven Display International公司的NHD字符液晶显示模块,看看它的各项特性和技术参数。
文件下载:NHD-0108BZ-FSY-YBW-33V3.pdf
这份产品规格书涵盖了NHD字符液晶显示模块的多个方面,包括文档修订历史、功能特性、机械图纸、引脚描述、驱动信息、电气和光学特性、命令表、时序特性、内置字体表、初始化程序以及质量信息等内容。
该模块具有1行8字符的显示能力,内置ST7066U或等效控制器,采用+3.3V电源供电,具备1/8 duty、1/4 bias的特性,并且符合RoHS标准。
机械图纸详细标注了模块的尺寸,单位为毫米,采用第三角度投影。标准公差线性为±0.3mm,模块尺寸如长、宽等都有明确的规定。同时,还给出了引脚分配,包括VDD、VSS、V0、RS、RW、E以及DB0 - DB7等引脚。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for Logic and Backlight (+3.3V) |
| 3 | V0 | Adj. Power Supply | Supply Voltage for contrast (approx. 0V) |
| 4 | RS | MPU | Register Select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. Not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
推荐使用2.54mm间距的引脚作为LCD连接器。
内置ST7066U控制器,可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载其规格说明。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | TOP | Absolute Max | - 20 | - | + 70 | ⁰C |
| Storage Temperature Range | TST | Absolute Max | - 30 | - | + 80 | ⁰C |
| Supply Voltage | VDD | - | 3.1 | 3.3 | 3.5 | V |
| Supply Current | IDD + ILED | VDD = 3.3V | 31 | 36 | 46 | mA |
| Supply for LCD (contrast) | VLCD | TOP = 25°C | 3.0 | 3.3 | 3.6 | V |
| “H” Level input | VIH | - | 0.7 * VDD | - | VDD | V |
| “L” Level input | VIL | - | VSS | - | 0.6 | V |
| “H” Level output | VOH | - | 0.75 * VDD | - | VDD | V |
| “L” Level output | VOL | - | VSS | - | 0.2 * VDD | V |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | ||
| Optimal Viewing Angles | Top | ϕY+ | Cr ≥ 2 | - | 40 | - | ⁰ | |
| Bottom | ϕY - | - | 60 | - | ⁰ | |||
| Left | θX - | - | 60 | - | ⁰ | |||
| Right | θX+ | - | 60 | - | ⁰ | |||
| Contrast Ratio | Cr | - | 2 | 5 | - | - | ||
| Response Time | Rise | Tr | TOP = 25°C | - | 150 | 250 | ms | |
| Fall | Tf | - | 200 | 300 | ms |
模块提供了一系列命令,如清屏、返回主页、设置输入模式、显示开关控制等。每个命令都有对应的指令代码和执行时间。例如,清屏命令(Clear Display)的指令代码为0000000001,执行时间为1.52ms。
包含了从MPU向ST7066U写入数据和从ST7066U向MPU读取数据的时序要求,如使能周期时间、地址建立时间、地址保持时间等。
提供了8位和4位两种初始化方式的示例代码。以8位初始化为例,通过一系列命令和延时操作,完成模块的唤醒、功能设置、光标设置等操作。
对模块进行了多项质量测试,包括高温存储、低温存储、高温运行、低温运行、高温高湿运行、热冲击抗性、振动测试和静电测试等。每个测试都有明确的测试条件和注意事项。
对于电子工程师来说,深入了解这些特性和参数,有助于在实际设计中更好地应用该液晶显示模块。大家在使用过程中有没有遇到过类似模块的兼容性问题呢?欢迎在评论区分享你的经验。
