在电子设备的设计中,显示屏是至关重要的组件之一。今天我们来详细了解Newhaven Display的NHD TFT液晶显示屏,这款产品具备诸多特性,适用于多种应用场景。
文件下载:NHD-0108BZ-RN-YBW-33V.pdf
Newhaven Display的NHD TFT液晶显示屏,具体型号为NHD - 0108BZ - RN - YBW - 33V,具有1行8字符的显示能力,内置ST7066U或等效控制器,采用+3.3V电源供电,支持1/8 duty、1/4 bias,并且符合RoHS标准。
由于搜索出现超时错误,未能获取到相关扩充内容,以下继续为你呈现产品的详细信息。
该显示屏的机械绘图包含了详细的尺寸信息,单位为毫米,采用第三角投影。标准公差方面,线性尺寸公差为±0.3mm。其驱动为1/8 Duty、1/4 Bias,电压方面,VDD和VLCD均为3.3V,显示模式为STN Positive / Yellow - Green / Reflective 6:00,驱动IC为ST7066U 8/4 - Bit MPU Interface。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for logic (+3.3V) |
| 3 | V0 | Adj. Power Supply | Supply Voltage for contrast (approx. 0.0V) |
| 4 | RS | MPU | Register Select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
推荐的LCD连接器为2.54mm间距引脚,不过文档中未提及背光连接器及匹配信息。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | TOP | Absolute Max | - 20 | - | + 70 | ⁰C |
| Storage Temperature Range | TST | Absolute Max | - 30 | - | + 80 | ⁰C |
| Supply Voltage | VDD | - | 3.1 | 3.3 | 3.5 | V |
| Supply Current | IDD | VDD = 3.3V | 0.3 | 0.5 | 1.5 | mA |
| Supply for LCD (contrast) | VLCD | Ta = 25°C | 3.1 | 3.3 | 3.5 | V |
| “H” Level input | VIH | - | 0.7 * VDD | - | VDD | V |
| “L” Level input | VIL | - | VSS | - | 0.6 | V |
| “H” Level output | VOH | - | 0.75 * VDD | - | VDD | V |
| “L” Level output | VOL | - | VSS | - | 0.2 * VDD | V |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | ||
| Optimal Viewing Angles | Top | ϕY+ | CR ≥ 2 | - | 40 | - | ⁰ | |
| Bottom | ϕY - | - | 60 | - | ⁰ | |||
| Left | θX - | - | 60 | - | ⁰ | |||
| Right | θX+ | - | 60 | - | ⁰ | |||
| Contrast Ratio | CR | - | 2 | 5 | - | - | ||
| Response Time | Rise | TR | TOP = 25°C | - | 150 | 250 | ms | |
| Fall | TF | - | 200 | 300 | ms |
文档中给出了一系列指令,包括清屏、返回主页、设置输入模式、显示开关控制等指令,每个指令都有对应的执行时间和详细描述。例如,清屏指令(0 0 0 0 0 0 0 0 0 1)执行时间为1.52ms,其作用是将“20H”写入DDRAM并将DDRAM地址设置为“00H”。
分为MPU向ST7066U写入数据和从ST7066U向MPU读取数据两种模式,每种模式都有相应的时序参数,如使能周期时间、使能脉冲宽度、地址建立时间等。
文档展示了内置字体表,但内容较为简略,可能需要进一步结合实际应用来理解其具体用途。
提供了8位和4位两种初始化方式的示例程序,详细说明了如何进行指令发送、数据写入以及初始化步骤。例如,8位初始化中,先进行多次唤醒操作,然后设置功能、光标、显示等参数。
对显示屏进行了多项测试,包括高温存储、低温存储、高温运行、低温运行、高温高湿运行、热冲击抗性、振动测试和静电测试等。不同测试有不同的条件和注意事项,如高温存储测试条件为+80⁰C、48小时,低温存储测试条件为 - 30⁰C、48小时等。
Newhaven Display的NHD TFT液晶显示屏在设计上考虑了多方面的因素,从机械尺寸到电气特性、光学特性等都有明确的参数。其丰富的指令集和详细的初始化程序为工程师的开发提供了便利。在实际应用中,工程师可以根据这些信息进行合理的设计和调试,以确保显示屏能够稳定、高效地工作。大家在使用这款显示屏时,有没有遇到过一些特殊的问题呢?欢迎在评论区分享。
