在电子设备的设计中,显示模块是用户与设备交互的重要界面。今天,我们将深入探讨Newhaven Display国际公司的NHD字符液晶显示模块,它具有多种特性和功能,能满足不同场景的需求。
NHD字符液晶显示模块采用内置ST7066U控制器,支持1行16字符显示,电源供应为+5.0V,具备1/16 duty、1/5 bias的驱动方式,并且符合RoHS标准,环保又可靠。
很遗憾,在搜索相关信息时出现了超时问题,未能获取到更多关于NHD字符液晶显示模块特点的内容。不过,我们可以继续基于文档中的信息进行分析。
模块的机械设计包含详细的尺寸信息,采用第三视角投影,尺寸单位为毫米。其显示类型为FSTN/Positive/Transflective/6:00视角,工作温度范围在 -20°C至70°C,存储温度范围为 -30°C至80°C。同时,该模块还提供了清晰的引脚分配图,方便工程师进行连接。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for logic (+5.0V) |
| 3 | V0 | Adj Power Supply | Power supply for contrast (approx. 0.5V) |
| 4 | RS | MPU | Register select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write |
| 6 | E | MPU | Operation enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED+ | Power Supply | Power supply for LED Backlight (+5.0V via on - board resistor) |
| 16 | LED- | Power Supply | Ground for Backlight |
推荐使用2.54mm间距的引脚作为LCD连接器。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | -20 | - | +70 | ⁰C |
| Storage Temperature Range | Tst | Absolute Max | -30 | - | +80 | ⁰C |
| Supply Voltage | VDD | 4.7 | 5.0 | 5.5 | V | |
| Supply Current | IDD | Ta = 25°C, VDD = 5.0V | - | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | VDD - V0 | Ta = 25°C | - | 4.5 | - | V |
| “H” Level input | Vih | 0.7 VDD | - | VDD | V | |
| “L” Level input | Vil | 0 | - | 0.6 | V | |
| “H” Level output | Voh | 3.9 | - | - | V | |
| “L” Level output | Vol | - | - | 0.4 | V | |
| Backlight Supply Voltage | Vled | - | - | 5.0 | - | V |
| Backlight Supply Current | Iled | Vled = 5.0V | - | 30 | - | mA |
这些电气参数为工程师在设计电路时提供了重要的参考依据,确保模块能够稳定工作。
| Viewing Angle – Vertical (top) | AV | Cr ≥ 3 | - | 20 | - | ⁰ |
| Viewing Angle – Vertical (bottom) | AV | Cr ≥ 3 | - | 50 | - | ⁰ |
| Viewing Angle – Horizontal (left) | AH | Cr ≥ 3 | - | 30 | - | ⁰ |
| Viewing Angle – Horizontal (right) | AH | Cr ≥ 3 | - | 30 | - | ⁰ |
| Contrast Ratio | Cr | 3 | 5 | - | - | |
| Response Time (rise) | Tr | - | - | 150 | 250 | ms |
| Response Time (fall) | Tf | - | - | 150 | 250 | ms |
良好的光学特性使得模块在不同角度下都能提供清晰的显示效果,响应时间也能满足大多数应用场景的需求。
模块提供了丰富的指令集,用于控制显示内容和操作。例如,Clear Display指令可将DDRAM写入“20H”并将DDRAM地址设置为“00H”;Return Home指令可将DDRAM地址设置为“00H”并将光标返回原位。这些指令的执行时间也有明确规定,方便工程师进行程序设计。
内置字体表包含了多种字符的显示编码,工程师可以根据需要选择合适的字符进行显示。这为设计多样化的显示界面提供了便利。
文档中提供了8位和4位初始化程序示例,通过这些程序可以对模块进行初始化设置,使其正常工作。例如,在8位初始化程序中,通过一系列的命令和延时操作,实现模块的唤醒、功能设置、光标设置等操作。
又一次搜索超时了,未能获取到NHD字符液晶显示模块初始化程序优化方法的相关内容。不过我们可以继续总结模块的质量信息。
该模块经过了多项严格的测试,包括高温存储、低温存储、高温操作、低温操作、高温高湿操作、热冲击抗性、振动测试和静电测试等。这些测试确保了模块在不同环境条件下的可靠性和稳定性。
例如,高温存储测试在+80⁰C下进行48小时,低温存储测试在 -30⁰C下进行48小时。在进行某些测试时还有额外的注意事项,如部分测试需在25⁰C、0%RH下存储4小时后进行,振动测试需对产品本身进行,而非在容器内进行。
NHD字符液晶显示模块以其丰富的功能、良好的性能和可靠的质量,为电子工程师在设计显示界面时提供了一个优秀的选择。通过深入了解其机械设计、引脚说明、电气特性、光学特性、指令表、内置字体表和初始化程序等关键信息,工程师可以更好地将该模块应用到实际项目中。同时,严格的质量测试也保证了模块在各种复杂环境下的稳定运行。大家在实际应用中,是否遇到过类似模块的使用问题呢?又有哪些解决方法呢?欢迎一起交流探讨。
