在电子设备的设计中,液晶显示模块是不可或缺的一部分,它为用户提供了直观的信息交互界面。今天我们就来深入了解一下Newhaven Display公司的NHD - 0116GZ - FSPG - FBW字符液晶显示模块,看看它有哪些特点和优势。
NHD - 0116GZ - FSPG - FBW是一款1行×16字符的液晶显示模块,内置了SPLC780D或ST7066U控制器,采用+5.0V电源供电。它具有1/16 duty、1/5 bias的驱动方式,属于FSTN正性、半透反射型显示,视角为6:00,工作温度范围在 - 20°C至+70°C之间,并且符合RoHS标准。
从产品型号NHD - 0116GZ - FSPG - FBW可以了解到很多信息:
| 该模块共有16个引脚,各引脚功能如下: | Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground | |
| 2 | VDD | Power Supply | Supply Voltage for logic (+5.0V) | |
| 3 | V0 | Adj Power Supply | Power supply for contrast (approx. 0.5V) | |
| 4 | RS | MPU | Register select signal. RS = 0: Command, RS = 1: Data | |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read, R/W = 0: Write | |
| 6 | E | MPU | Operation enable signal. Falling edge triggered. | |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. Not used during 4 - bit operation. | |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. | |
| 15 | LED+ | Power Supply | Power supply for LED Backlight (+5.0V via on - board resistor) | |
| 16 | LED - | Power Supply | Ground for Backlight |
推荐使用2.54mm间距的引脚作为LCD连接器,不过文档中未提及背光连接器的具体信息。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | - 20 | - | +70 | °C |
| Storage Temperature Range | Tst | Absolute Max | - 30 | - | +80 | °C |
| Supply Voltage | VDD | 4.7 | 5.0 | 5.5 | V | |
| Supply Current | IDD | Ta = 25°C, VDD = 5.0V | - | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | VDD - V0 | Ta = 25°C | - | 4.5 | - | V |
| “H” Level input | Vih | 2.2 | - | VDD | V | |
| “L” Level input | Vil | 0 | - | 0.6 | V | |
| “H” Level output | Voh | 2.4 | - | - | V | |
| “L” Level output | Vol | - | - | 0.4 | V | |
| Backlight Supply Voltage | Vled | - | - | 5.0 | - | V |
| Backlight Supply Current | Iled | Vled = 5.0V | - | 30 | - | mA |
| Viewing Angle – Vertical (top) | AV | Cr ≥3 | - | 20 | - | ° |
| Viewing Angle – Vertical (bottom) | AV | Cr ≥3 | - | 50 | - | ° |
| Viewing Angle – Horizontal (left) | AH | Cr ≥3 | - | 30 | - | ° |
| Viewing Angle – Horizontal (right) | AH | Cr ≥3 | - | 30 | - | ° |
| Contrast Ratio | Cr | 3 | 5 | - | - | |
| Response Time (rise) | Tr | - | - | 150 | 250 | ms |
| Response Time (fall) | Tf | - | - | 150 | 250 | ms |
该模块内置了SPLC780D和ST7066U控制器,其规格文档可分别从http://www.newhavendisplay.com/app_notes/SPLC780D.pdf和http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载。
显示位置与DDRAM地址有对应关系,例如显示位置从1到16,对应的DDRAM地址分别为00、01、02……47 。
文档中给出了内置字体表,但部分内容可能需要进一步解读,它包含了不同字符对应的编码信息。
代码通过一系列的指令设置,完成模块的初始化,包括唤醒、功能设置、显示和光标设置等操作。例如,通过发送0x30指令进行唤醒,发送0x38指令进行8位/2行功能设置等。
与8位初始化类似,但数据传输采用4位方式,需要对数据进行移位处理,分两次传输4位数据。
该模块经过了多项质量测试,包括高温存储、低温存储、高温操作、低温操作、高温高湿操作、热冲击、振动和静电测试等,以确保其在不同环境下的可靠性。
使用LCD/LCM时需要注意一些事项,具体可参考www.newhavendisplay.com/specs/precautions.pdf。同时,关于保修信息和条款可访问http://www.newhavendisplay.com/index.php?main_page=terms。
总的来说,NHD - 0116GZ - FSPG - FBW字符液晶显示模块具有多种特性和功能,在实际应用中,电子工程师需要根据具体需求合理使用该模块,并注意相关的使用和测试要求。大家在使用过程中遇到过哪些问题呢?欢迎在评论区分享交流。
