在电子设备的设计中,液晶显示模块是人机交互的重要组成部分。Newhaven Display的NHD字符液晶显示模块以其稳定的性能和丰富的功能,在众多电子应用场景中得到广泛应用。本文将详细解析NHD模块的各项特性、参数及使用方法,为电子工程师在设计中提供参考。
文件下载:NHD-0108CZ-RN-GBW-33V.pdf
NHD字符液晶显示模块具有1行8字符的显示能力,内置ST7066U控制器,采用+3.3V电源供电,具备1/8 duty、1/4 bias的驱动方式,并且符合RoHS标准,环保可靠。
机械图纸明确了模块的尺寸、引脚分配等信息。引脚分配包括VSS(接地)、VDD(逻辑电源+3.3V)、V0(对比度调节电源)等。标准公差为线性±0.3mm,采用第三角投影,尺寸单位为毫米。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | V SS | Power Supply | Ground |
| 2 | V DD | Power Supply | Supply Voltage for Logic (+3.3V) |
| 3 | V 0 | Adj. Power Supply | Supply Voltage for Contrast (approx. 0.1V) |
| 4 | RS | MPU | Register Select signal. RS=0: Command, RS=1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W=1: Read R/W: =0: Write |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. |
| 7 - 10 | DB4 – DB7 | MPU | Four high order bi-directional three-state data bus lines. |
| 11 - 14 | DB0 – DB3 | MPU | Four low order bi-directional three-state data bus lines. These four are not used during 4-bit operation. |
| A | NC | - | No Connect |
| K | NC | - | No Connect |
推荐使用2.54mm间距的引脚作为LCD连接器,不过文档中未提及背光连接器相关信息。
模块内置ST7066U控制器,其详细规格可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载。
| DDRAM地址分布如下: | Location | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
| Address (Hex) | 00 | 01 | 02 | 03 | 04 | 05 | 06 | 07 |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | T OP | Absolute Max | -20 | - | +70 | ⁰C |
| Storage Temperature Range | T ST | Absolute Max | -30 | - | +80 | ⁰C |
| Supply Voltage | V DD | - | 3.1 | 3.3 | 3.5 | V |
| Supply Current | I DD | V DD = 5.0V | 0.5 | 1.0 | 2.5 | mA |
| Supply for LCD (contrast) | V LCD | T OP = 25°C | 3.1 | 3.3 | 3.5 | V |
| “H” Level input | V IH | - | 0.7 * V DD | - | V DD | V |
| “L” Level input | V IL | - | V SS | - | 0.6 | V |
| “H” Level output | V OH | - | 0.75 * V DD | - | V DD | V |
| “L” Level output | V OL | - | V SS | - | 0.2 * V DD | V |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | ||
| Optimal Viewing Angles | Top | ϕY+ | CR ≥ 2 | - | 40 | - | ° | |
| Bottom | ϕY- | - | 60 | - | ° | |||
| Left | θX- | - | 60 | - | ° | |||
| Right | θX+ | - | 60 | - | ° | |||
| Contrast Ratio | CR | - | 2 | 5 | - | - | ||
| Response Time | Rise | T R | T OP = 25°C | - | 150 | 250 | ms | |
| Fall | T F | - | 200 | 300 | ms |
模块提供了丰富的指令集,用于控制显示、光标移动等操作。例如,Clear Display指令可将“20H”写入DDRAM并将DDRAM地址设置为“00H”,执行时间为1.52ms。
包括MPU向ST7066U写入数据和从ST7066U读取数据的时序要求。例如,写入数据时,Enable Cycle Time(Tc)为1200ns,Enable Pulse Width(Tpw)为460ns等。
内置字体表规定了字符的显示编码,方便工程师进行字符显示的编程。
提供了8位和4位初始化程序示例,帮助工程师快速实现模块的初始化操作。例如,8位初始化程序中,先进行多次唤醒操作,然后设置功能、显示和光标等参数。
模块经过多项质量测试,包括高温存储、低温存储、高温运行、低温运行、高温高湿运行、热冲击抗性、振动测试和静电测试等。各项测试都有明确的条件和时间要求,确保产品在不同环境下的可靠性。
Newhaven Display的NHD字符液晶显示模块具有丰富的功能和良好的性能,通过对其机械设计、电气特性、光学特性、指令集和初始化程序等方面的详细了解,电子工程师可以更好地将其应用到实际设计中。在使用过程中,需要注意各项参数的设置和测试条件,以确保模块的正常运行。各位工程师在实际应用中遇到过哪些关于液晶显示模块的问题呢?欢迎在评论区分享交流。
