在电子设计领域,液晶显示模块是人机交互的重要组成部分。今天我们来详细解读Newhaven Display的NHD字符液晶显示模块的产品规格,了解它的各项特性和技术细节。
Newhaven Display的NHD字符液晶显示模块具有2行8字符的显示能力,内置ST7066U控制器,采用+5.0V电源供电,具备1/16 duty、1/5 bias的驱动模式,并且符合RoHS标准。
机械绘图展示了模块的尺寸和引脚分配等信息。引脚分配包括VSS(接地)、VDD(逻辑电源+5.0V)、V0(对比度调节电源约0.6V)等。标准公差线性为±0.3mm,采用第三角投影,尺寸单位为毫米。驱动为1/16 Duty、1/5 Bias,5.0V VDD,4.5V VLCD,STN正性/黄绿/反射型,最佳视角为6:00,驱动IC为ST7066U,具备8/4 - Bit MPU接口。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | V SS | Power Supply | Ground |
| 2 | V DD | Power Supply | Supply Voltage for logic (+5.0V) |
| 3 | V 0 | Adj Power Supply | Supply Voltage for contrast (approx. 0.6V) |
| 4 | RS | MPU | Register Select s ignal. RS=0: Command, RS=1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W=1: Read R/W: =0: Write |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. Not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| A | NC | - | No Connect |
| K | NC | - | No Connect |
推荐的LCD连接器为2.54mm间距引脚,背光连接器未提及相关信息。
模块内置ST7066U控制器,可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载其规格文档。
| DDRAM地址分布如下: | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 |
| 00 01 02 03 04 05 06 07 | ||||||||
| 40 41 42 43 44 45 46 47 |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | T OP | Absolute Max | -20 | - | +70 | ⁰C |
| Storage Temperature Range | T ST | Absolute Max | -30 | - | +80 | ⁰C |
| Supply Voltage | V DD | - | 4.8 | 5.0 | 5.2 | V |
| Supply Current | I DD | V DD = 5.0V | 0.5 | 1.0 | 2.5 | mA |
| Supply for LCD (contrast) | V LCD | T OP = 25°C | 4.2 | 4.4 | 4.6 | V |
| “H” Level input | V IH | - | 0.7 * V DD | - | V DD | V |
| “L” Level input | V IL | - | V SS | - | 0.6 | V |
| “H” Level output | V OH | - | 3.9 | - | V DD | V |
| “L” Level output | V OL | - | V SS | - | 0.4 | V |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | ||
| Optimal Viewing Angles | Top | ϕY+ | CR ≥ 2 | - | 40 | - | ° | |
| Bottom | ϕY- | - | 60 | - | ° | |||
| Left | θX- | - | 60 | - | ° | |||
| Right | θX+ | - | 60 | - | ° | |||
| Contrast Ratio | CR | - | 2 | 5 | - | - | ||
| Response Time | Rise | T R | T OP = 25°C | - | 150 | 250 | ms | |
| Fall | T F | - | 200 | 300 | ms |
模块提供了一系列指令,如清屏、返回主页、设置显示模式等,不同指令有对应的执行时间和功能描述。例如,清屏指令(0 0 0 0 0 0 0 0 0 1)执行时间为1.52ms,功能是将“20H”写入DDRAM并将DDRAM地址设置为“00H”。
包括MPU向ST7066U写入数据和从ST7066U读取数据的时序要求,如使能周期时间、使能脉冲宽度、地址建立时间等。
展示了模块内置的字体编码信息。
提供了8位和4位初始化的示例代码,方便工程师进行开发。
对模块进行了多项质量测试,包括高温存储、低温存储、高温运行、低温运行、高温高湿运行、热冲击抵抗、振动测试和静电测试等,并给出了相应的测试条件和注意事项。
Newhaven Display的NHD字符液晶显示模块具有丰富的功能和良好的性能。在实际设计中,工程师可以根据这些规格信息合理使用该模块,确保系统的稳定性和可靠性。大家在使用过程中是否遇到过类似模块的兼容性问题呢?欢迎在评论区分享你的经验。
