在电子设计领域,显示模块是人机交互的重要组成部分。今天,我们将深入探讨 Newhaven Display 推出的 NHD - 0216AW - IB3 字符 OLED 显示模块,了解其特性、参数及使用方法。
文件下载:NHD-0216AW-IB3.pdf
NHD - 0216AW - IB3 是一款具有 2 行 16 字符显示能力的 OLED 模块。从型号上看:
| Pin No. | Symbol | External Connection | Function Description |
| 1 | GND | Power Supply | 接地 |
| 2 | VDD_SEL | Power Supply | 逻辑操作供电电压选择,5V 操作时必须不连接,低电压操作时 VDD_SEL = 2.8V |
| 3 | VDDIO | Power Supply | 逻辑 I/O 供电电压,5V 操作时 VDDIO = 5V,低电压操作时 VDDIO = 2.8V |
| 4 | SA0 | MPU | 从地址选择信号(LOW = 3C,HIGH = 3D) |
| 5 | SCL | MPU | 串行时钟信号 |
| 6 | SDA | MPU | 串行数据线 |
| 7 | /RES | MPU | 低电平有效复位信号 |
| Jumper Name | 2.8V Logic | 5V Logic |
| SJ1 | Open (default) | Short |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | -40 | - | +85 | ⁰C |
| Storage Temperature Range | Tst | Absolute Max | -40 | - | +90 | ⁰C |
| Supply Voltage for Logic | VDD | 2.4 | 2.8 | VDDIO | V | |
| Supply Voltage for I/O Pins | VDDIO | (2.8V I/O Application) | 2.4 | 2.8 | 3.6 | V |
| Supply Voltage for I/O Pins | VDDIO | (5V I/O Application) | 4.4 | 5.0 | 5.5 | V |
| Supply Current | IDD | - | - | 10 | 40 | mA |
| Sleep Mode Current | IDD SLEEP | - | - | 0.05 | 1 | mA |
| “H” Level input | Vih | 0.8 * VDD | - | - | V | |
| “L” Level input | Vil | - | - | 0.2 * VDD | V | |
| “H” Level output | Voh | 0.9 * VDD | - | - | V | |
| “L” Level output | Vol | - | - | 0.1 * VDD | V |
| Viewing Angle – Top | - | Cr ≥ 10,000:1 | 80 | - | - | ⁰ |
| Viewing Angle – Bottom | - | 80 | - | - | ⁰ | |
| Viewing Angle – Left | - | 80 | - | - | ⁰ | |
| Viewing Angle – Right | - | 80 | - | - | ⁰ | |
| Contrast Ratio | Cr | - | 10,000:1 | - | - | - |
| Response Time (rise) | Tr | - | - | 10 | - | us |
| Response Time (fall) | Tf | - | - | 10 | - | us |
| Brightness | - | 50% checkerboard | 60 | 80 | - | cd/m² |
| Lifetime | - | Ta = 25°C, 50% checkerboard | 25,000 | - | - | Hrs |
这里需要注意的是,典型温度下的寿命是基于加速高温操作测试得出的,测试时平均 50% 的像素处于开启状态,寿命以达到半亮度所需的小时数来衡量。使用显示关闭命令可以延长显示模块的使用寿命,同时要注意避免出现残影(烧屏)现象,应确保每个像素均匀发光。
该模块提供了三种命令集:
涵盖了清除显示、返回主页、设置输入模式、控制显示开关等基本操作。例如,清除显示命令会将 “20H” 写入 DDRAM 并将 DDRAM 地址设置为 “00H”;返回主页命令会将 DDRAM 地址设置为 “00H” 并将光标返回原始位置(如果已移动),但不改变 DDRAM 的内容。
用于选择字符 ROM、启用或禁用内部 VDD 调节器等功能。例如,通过设置不同的参数可以选择不同的字符集和调节显示效果。
主要用于设置对比度、显示时钟分频比、相位长度等 OLED 相关的参数。例如,设置对比度控制命令可以在 256 个对比度级别中选择,值越大对比度越高。
void init()
RES = 1; //reset HIGH – inactive
delayms(1);
command(0x2A); //function set (extended command set)
command(0x71);
data(0x00); // disable internal VDD regulator (2.8V I/O). data(0x5C) = enable regulator (5V I/O)
command(0x28); //function set (fundamental command set)
command(0x08); //display off, cursor off, blink off
command(0x79); //OLED command set enabled
command(0xD5); //set display clock divide ratio/oscillator frequency
command(0x70);
command(0x78); //set display clock divide ratio/oscillator frequency //OLED command set disabled
command(0x08);
command(0x06);
command(0x72);
data(0x00);
command(0x2A); //extended function set (2-lines) //ROM CGRAM selection //function set (extended command set) //COM SEG direction //function selection B
command(0xDA);
command(0x00); //set SEG pins hardware configuration //set SEG pins hardware configuration
command(0xDC);
command(0x00); //function selection C //function selection C
command(0x81); //set contrast control
command(0x7F);
command(0xD9); //set phase length //set contrast control
command(0xF1);
command(0xDB); //set phase length //set VCOMH deselect level
command(0x40); //set VCOMH deselect level
command(0x78); //OLED command set disabled
command(0x01); //clear display
command(0x80); //set DDRAM address to 0x00
command(0x0C);
delayms(100); //display ON //delay
可以访问 GitHub 仓库 获取示例代码,方便开发者快速上手。
| 该模块经过了多项质量测试,包括高温存储、低温存储、高温操作、低温操作、高温高湿操作、热冲击抗性、振动测试和静电测试等。测试条件和注意事项如下: | Test Item | Content of Test | Test Condition | Note |
| High Temperature storage | Test the endurance of the display at high storage temperature. | +90⁰C, 240hrs | 2 | |
| Low Temperature storage | Test the endurance of the display at low storage temperature. | -40⁰C, 240hrs | 1,2 | |
| High Temperature Operation | Test the endurance of the display by applying electric stress (voltage & current) at high temperature. | +85⁰C, 240hrs | 2 | |
| Low Temperature Operation | Test the endurance of the display by applying electric stress (voltage & current) at low temperature. | -40⁰C, 240hrs | 1,2 | |
| High Temperature / Humidity Operation | Test the endurance of the display by applying electric stress (voltage & current) at high temperature with high humidity. | +60⁰C, 90% RH, 240hrs | 1,2 | |
| Thermal Shock resistance | Test the endurance of the display by applying electric stress (voltage & current) during a cycle of low and high temperatures. | -40⁰C, 30min -> 25⁰C, 5min -> 85⁰C, 30min = 1 cycle 100 cycles | ||
| Vibration test | Test the endurance of the display by applying vibration to simulate transportation and use. | 10 - 22Hz, 15mm amplitude. 22 - 500Hz, 1.5G 30min in each of 3 directions X,Y,Z | 3 | |
| Static electricity test | Test the endurance of the display by applying electric static discharge. | VS = 800V, RS = 1.5kΩ, CS = 100pF One time |
此外,使用 OLEDs/LCDs/LCMs 时的注意事项可参考 相关文档,保修信息和条款可访问 官方网站 了解。
综上所述,NHD - 0216AW - IB3 字符 OLED 显示模块具有丰富的功能和良好的性能,适用于多种电子设备的显示需求。电子工程师在设计过程中,可以根据实际需求合理使用该模块,并严格遵循相关的使用和测试要求,以确保设备的稳定性和可靠性。你在使用类似显示模块时遇到过哪些问题呢?欢迎在评论区分享交流。
