在电子设备的设计中,液晶显示模块是不可或缺的一部分。今天,我们就来深入了解一下Newhaven Display推出的字符液晶显示模块NHD - 0216HZ - FL - YBW - C。
NHD - 0216HZ - FL - YBW - C是一款2行16字符的液晶显示模块,其型号中的各个字母都有特定含义:
该产品符合REACH和RoHS标准,为环保设计提供了保障。
这份产品文档有详细的修订历史,从2008年10月23日的初始版本发布,到2021年12月14日机械图纸的更新,期间经历了多次修订,内容涉及用户指南格式调整、背光信息更新、光学特性更新等多个方面。这反映了产品在不断优化和改进,以满足市场和用户的需求。
机械图纸展示了产品的详细尺寸和结构。产品采用ST7066U作为LCD驱动IC,接口为4/8位并行,电源要求为5.0V,背光同样为5.0V/85mA。光学特性方面,采用STN正性、黄/绿色、半反半透设计。推荐使用1x16针脚、2.54mm间距的连接器。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | V SS | Power Supply | Ground |
| 2 | V DD | Power Supply | Supply Voltage for Logic (+5.0V) |
| 3 | DNC | DNC | Do No Connect (Contrast Voltage is internally controlled) |
| 4 | RS | MPU | Register Select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED - A | Power Supply | Backlight Anode (+5.0V) |
| 16 | LED - K | Power Supply | Backlight Cathode (Ground) |
推荐使用2.54mm间距的引脚作为LCD连接器,内置ST7066U控制器,其规格说明书可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载。
DDRAM地址分为两行,第一行地址从00H到0FH,第二行从40H到4FH,这为数据的存储和显示提供了明确的地址映射。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | T OP | Absolute Max | - 20 | - | +70 | ⁰C |
| Storage Temperature Range | T ST | Absolute Max | - 30 | - | +80 | ⁰C |
| Supply Voltage | V DD | - | 4.7 | 5.0 | 5.3 | V |
| Supply Current | I DD | V DD = 5.0V | 0.5 | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | V LCD | T OP = 25°C | 4.2 | 4.4 | 4.6 | V |
| “H” Level input | V IH | - | 0.7*V DD | - | V DD | V |
| “L” Level input | V IL | - | V SS | - | 0.6 | V |
| “H” Level output | V OH | - | 3.9 | - | V DD | V |
| “L” Level output | V OL | - | V SS | - | 0.4 | V |
| Backlight Supply Voltage | V LED | - | 4.8 | 5.0 | 5.2 | V |
| Backlight Supply Current | I LED | V LED = 5.0V | 40 | 85 | 120 | mA |
这些电气特性为产品的正常工作提供了明确的参数范围,工程师在设计电路时需要严格遵循这些参数。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | ||
| Optimal Viewing Angles | Top | ϕY+ | CR ≥ 2 | - | 40 | - | ⁰ | |
| Bottom | ϕY - | - | 60 | - | ⁰ | |||
| Left | θX - | - | 60 | - | ⁰ | |||
| Right | θX+ | - | 60 | - | ⁰ | |||
| Contrast Ratio | CR | - | 2 | 5 | - | - | ||
| Response Time | Rise | T R | T OP = 25°C | - | 150 | 250 | ms | |
| Fall | T F | - | 200 | 300 | ms |
光学特性决定了产品的显示效果,如最佳视角、对比度和响应时间等,这些参数对于用户体验至关重要。
该模块提供了一系列命令,用于控制显示内容和操作,如清屏、返回主页、设置显示模式等。每个命令都有对应的指令代码和执行时间,例如清屏命令(Clear Display)的指令代码为000000000001,执行时间为1.52ms。这些命令为工程师实现各种显示功能提供了便利。
包括从MPU向ST7066U写入数据和从ST7066U向MPU读取数据的时序特性,如使能周期时间、使能脉冲宽度、数据建立时间等。这些时序参数对于确保数据的正确传输和处理至关重要。
内置字体表定义了字符的显示样式,为显示文本提供了基础。
文档提供了8位和4位初始化程序示例,详细展示了如何对模块进行初始化设置,包括发送命令和数据的具体步骤。这些示例代码可以帮助工程师快速上手,实现模块的正常显示。
产品进行了多项质量测试,包括高温存储、低温存储、高温操作、低温操作、高温高湿操作、热冲击抗性、振动测试和静电测试等。这些测试确保了产品在不同环境条件下的可靠性和稳定性。
在实际设计中,电子工程师需要综合考虑以上各个方面的因素,根据具体的应用场景和需求,合理选择和使用该液晶显示模块。你在使用这类液晶显示模块时,有没有遇到过什么特别的问题呢?欢迎在评论区分享你的经验。
