在电子设备的设计中,液晶显示模块(LCM)是不可或缺的人机交互界面组件。今天我们要深入探讨的是Newhaven Display公司的NHD - 0216HZ - FSW - FBW - 33V3CH字符液晶显示模块,它具备诸多特性,适用于各种需要显示信息的电子设备。
文件下载:NHD-0216HZ-FSW-FBW-33V3CH.pdf
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for LCD and Logic (+3.3V) |
| 3 | NC | NC | No Connect |
| 4 | RS | MPU | Register Select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal. R/W = 1: Read, R/W = 0: Write |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. Not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED+ | Power Supply | Backlight Anode (+3.0V) |
| 16 | LED - | Power Supply | Backlight Cathode (Ground) |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | - 20 | - | +70 | ⁰C |
| Storage Temperature Range | Tst | Absolute Max | - 30 | - | +80 | ⁰C |
| Supply Voltage | VDD | - | 3.3 | - | V | |
| Supply Current | IDD | Ta = 25°C, VDD = 3.3V | - | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | VDD - V0 | Ta = 25°C | - | 3.2 | - | V |
| “H” Level input | Vih | 0.7 * VDD | - | VDD | V | |
| “L” Level input | Vil | 0 | - | 0.6 | V | |
| “H” Level output | Voh | 0.75 * VDD | - | - | V | |
| “L” Level output | Vol | - | - | 0.2 * VDD | V | |
| Backlight Supply Voltage | Vled | - | - | 3.0 | V | |
| Backlight Supply Current | Iled | Vled = 3.0V | - | 15 | - | mA |
| Viewing Angle – Top | - | Cr ≥ 3 | - | 20 | - | ⁰ |
| Viewing Angle – Bottom | - | - | 50 | - | ⁰ | |
| Viewing Angle – Left | - | - | 30 | - | ⁰ | |
| Viewing Angle – Right | - | - | 30 | - | ⁰ | |
| Contrast Ratio | Cr | 3 | 5 | - | - | |
| Response Time (rise) | Tr | - | - | 150 | 250 | ms |
| Response Time (fall) | Tf | - | - | 150 | 250 | ms |
该模块内置ST7066U控制器,其详细规格可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载。
| Instruction | Instruction code | Description | 270 KHZ Execution time (fosc =) | |||||||
| RS | ||||||||||
| Clear Display | 0 0 0 0 0 0 0 0 0 1 | Write “20H” to DDRA and set DDRAM address to “00H” from AC | 1.53ms | |||||||
| Return Home | 0 0 0 0 0 0 0 0 1 - | Set DDRAM address to “00H” From AC and return cursor to Its original position if shifted. The contents of DDRAM are not changed. | 1.53ms | |||||||
| Entry mode Set | 0 0 0 0 0 0 0 1 I/D SH | Assign cursor moving direction And blinking of entire display | 39us | |||||||
| Display ON/ OFF control | 0 0 0 0 0 0 1 D C B | Set display (D), cursor (C), and Blinking of cursor (B) on/off Control bit. | ||||||||
| Cursor or Display shift | 0 0 0 0 0 1 S/C R/L - - | Set cursor moving and display Shift control bit, and the Direction, without changing of DDRAM data. | 39us | |||||||
| Function set | 0 0 0 0 1 DL N F - - | Set interface data length (DL: 8 - Bit/4 - bit), numbers of display Line (N: = 2 - line/1 - line) and, Display font type (F: 5x11/5x8) | 39us | |||||||
| Set CGRAM Address | 0 0 0 1 | AC5 AC4 AC3 AC2 AC1 AC0 | Set CGRAM address in address counter. | 39us | ||||||
| Set DDRAM Address | 0 0 1 | AC6 AC5 AC4 AC3 AC2 AC1 AC0 | Set DDRAM address in address counter. | 39us | ||||||
| Read busy Flag and Address | 0 1 BF | AC6 AC5 AC4 AC3 AC2 AC1 AC0 | Whether during internal Operation or not can be known By reading BF. The contents of Address counter can also be read. | 0us | ||||||
| Write data To Address | 1 0 D7 D6 D5 D4 D3 D2 D1 D0 | Write data into internal RAM (DDRAM/CGRAM). | 43us | |||||||
| Read data From RAM | 1 1 D7 D6 D5 D4 D3 D2 D1 D0 | Read data from internal RAM (DDRAM/CGRAM). | 43us |
void command(char i)
P1 = i; //put data on output Port
D_I = 0; //D/I = LOW : send instruction
RW = 0; //R/W = LOW: Write
E = 1;
Delay(1); //enable pulse width >= 300ns
E = 0; //Clock enable: falling edge
void write(char i) {
D_I = 1; //D/I = HIGH : send data
RW = 0; //R/W = LOW : Write
E = 1;
void init() {
Delay(100); //Wait >40 msec after power is applied
command(0x30); //command 0x30 = Wake up
Delay(30); //must wait 5ms, busy flag not available
command(0x30); //command 0x30 = Wake up #2
Delay(10); //must wait 160us, busy flag not available
command(0x30); //command 0x30 = Wake up #3
command(0x38); //Function set: 8 - bit/2 - line
command(0x10); //Set cursor
command(0x0c); //Display ON; Cursor ON
command(0x06); //Entry mode set
void command(char i) {
RW = 0;
Nybble(); //Send lower 4 bits
i = i < < 4; //Shift over by 4 bits
Nybble(); //Send upper 4 bits
RW = 0;
Nybble(); //Clock lower 4 bits
Nybble(); //Clock upper 4 bits
void Nybble() {
E = 1;
void init() {
P1 = 0; P3 = 0;
P1 = 0x30; //put 0x30 on the output port
Nybble(); //command 0x30 = Wake up
Nybble(); //command 0x30 = Wake up #2
Nybble(); //command 0x30 = Wake up #3
Delay(10);
P1 = 0x20; //put 0x20 on the output port
Nybble(); //Function set: 4 - bit interface
command(0x28); //Function set: 4 - bit/2 - line
command(0x0F); //Display ON; Blinking cursor
command(0x06); //Entry Mode set
| Test Item | Content of Test | Test Condition | Note |
| High Temperature storage | Endurance test applying the high storage temperature for a long time. | +80⁰C , 96hrs | 2 |
| Low Temperature storage | Endurance test applying the low storage temperature for a long time. | - 30⁰C , 96hrs | 1,2 |
| High Temperature Operation | Endurance test applying the electric stress (voltage & current) and the high thermal stress for a long time. | +70⁰C, 96hrs | 2 |
| Low Temperature Operation | Endurance test applying the electric stress (voltage & current) and the low thermal stress for a long time. | - 20⁰C , 96hrs | 1,2 |
| High Temperature / Humidity Operation | Endurance test applying the electric stress (voltage & current) and the high thermal with high humidity stress for a long time. | +40⁰C , 90% RH , 96hrs | 1,2 |
| Thermal Shock resistance | Endurance test applying the electric stress (voltage & current) during a cycle of low and high thermal stress. | 0⁰C,30min -> 25⁰C,5min -> 50⁰C,30min = 1 cycle 10 cycles | |
| Vibration test | Endurance test applying vibration to simulate transportation and use. | 10 - 55Hz , 15mm amplitude. 60 sec in each of 3 directions X,Y,Z For 15 minutes | 3 |
| Static electricity test | Endurance test applying electric static discharge. | VS = 800V, RS = 1.5kΩ, CS = 100pF One time |
NHD - 0216HZ - FSW - FBW - 33V3CH液晶显示模块具有良好的显示性能、宽温度范围和可靠性,适用于多种电子设备。在设计过程中,我们需要根据其电气特性、引脚定义进行硬件电路设计,同时依据指令集和初始化程序进行软件编程。大家在实际应用中,是否遇到过类似模块的兼容性问题呢?又有哪些解决经验可以分享呢?欢迎在评论区交流。
