在电子设计领域,液晶显示模块是人机交互中不可或缺的组件。今天,我们就来详细剖析一款名为NHD - 0216K1Z - FSA - FBW - L的字符液晶显示模块,看看它有哪些特点和优势。
文件下载:NHD-0216K1Z-FSA-FBW-L.pdf
NHD - 0216K1Z - FSA - FBW - L是Newhaven Display International公司推出的一款字符液晶显示模块。从型号来看,它包含了丰富的信息:
该模块能够清晰显示2行,每行16个字符,满足基本的文本显示需求。
模块内置了SPLC780D或ST7066U控制器,为显示提供了稳定的控制支持。你可以通过访问http://www.newhavendisplay.com/app_notes/SPLC780D.pdf 和 http://www.newhavendisplay.com/app_notes/ST7066U.pdf 下载这两款控制器的详细规格。
采用 +5.0V 电源供电,驱动条件为1/16 duty,1/5 bias,并且符合RoHS标准,环保又可靠。
| 从机械图纸来看,该模块有明确的尺寸规格。同时,其引脚分配也有详细说明: | Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground | |
| 2 | VDD | Power Supply | Supply Voltage for logic (+5.0V) | |
| 3 | V0 | Adj Power Supply | Power supply for contrast (approx. 0.5V) | |
| 4 | RS | MPU | Register select signal. RS = 0: Command, RS = 1: Data | |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write | |
| 6 | E | MPU | Operation enable signal. Falling edge triggered. | |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation. | |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. | |
| 15 | LED+ | Power Supply | Power supply for LED Backlight (+5.0V via on - board resistor) | |
| 16 | LED - | Power Supply | Ground for Backlight |
推荐使用2.54mm间距的引脚作为LCD连接器。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | - 20 | - | +70 | ⁰C |
| Storage Temperature Range | Tst | Absolute Max | - 30 | - | +80 | ⁰C |
| Supply Voltage | VDD | 4.7 | 5.0 | 5.5 | V | |
| Supply Current | IDD | Ta = 25°C, VDD = 5.0V | - | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | VDD - V0 | Ta = 25°C | - | 4.5 | - | V |
| “H” Level input | Vih | 2.2 | - | VDD | V | |
| “L” Level input | Vil | 0 | - | 0.6 | V | |
| “H” Level output | Voh | 2.4 | - | - | V | |
| “L” Level output | Vol | - | - | 0.4 | V | |
| Backlight Supply Voltage | Vled | - | - | 5.0 | - | V |
| Backlight Supply Current | Iled | Vled = 5.0V | - | 20 | - | mA |
| Viewing Angle – Vertical (top) | AV | Cr ≥3 | - | 20 | - | ⁰ |
| Viewing Angle – Vertical (bottom) | AV | Cr ≥3 | - | 50 | - | ⁰ |
| Viewing Angle – Horizontal (left) | AH | Cr ≥3 | - | 30 | - | ⁰ |
| Viewing Angle – Horizontal (right) | AH | Cr ≥3 | - | 30 | - | ⁰ |
| Contrast Ratio | Cr | 3 | 5 | - | - | |
| Response Time (rise) | Tr | - | - | 150 | 250 | ms |
| Response Time (fall) | Tf | - | - | 150 | 250 | ms |
这些特性决定了模块在不同环境下的显示效果和性能表现。
通过一系列的命令和延时操作,完成模块的8位初始化,确保模块能够正常工作。例如,使用 command 函数发送指令,write 函数写入数据,init 函数进行初始化设置。
同样,4位初始化也有相应的函数和操作步骤,通过 Nybble 函数来处理4位数据的传输。
该模块经过了多项质量测试,包括高温存储、低温存储、高温操作、低温操作、高温高湿操作、热冲击抗性、振动测试和静电测试等。这些测试确保了模块在不同环境下的可靠性和稳定性。
在使用LCD/LCM时,需要注意一些事项,具体可参考www.newhavendisplay.com/specs/precautions.pdf 。同时,关于保修信息和条款条件,可以访问http://www.newhavendisplay.com/index.php?main_page=terms 。
总的来说,NHD - 0216K1Z - FSA - FBW - L字符液晶显示模块具有丰富的功能和良好的性能,适用于多种电子设备的显示需求。各位电子工程师在设计时,可以根据实际需求合理选择和使用这款模块。大家在使用过程中遇到过哪些问题呢?欢迎在评论区分享交流。
