探索NHD - 0216K1Z - FSO - FBW - L字符液晶显示模块
在电子设计领域,液晶显示模块是人机交互的重要组件。今天,跟大家分享一款来自Newhaven Display的NHD - 0216K1Z - FSO - FBW - L字符液晶显示模块,它在众多应用场景中都能发挥出色的作用。
文件下载:NHD-0216K1Z-FSO-FBW-L.pdf
模块概述
NHD - 0216K1Z - FSO - FBW - L是一款2行16字符的液晶显示模块。从型号上看,“NHD”代表Newhaven Display;“0216”表示2行16字符;“K1Z”是具体型号;“F”代表半透反射型;“SO”是侧面橙色LED背光;“F”表示FSTN(+);“B”是6:00视角;“W”意味着宽温度范围( - 20°C~ + 70°C);“L”代表低功耗20mA,并且该模块符合RoHS标准。
功能与特性
基本参数
机械与电气规格
机械尺寸
机械厚度方面,无背光时T1为8.6mm,T2为9.5mm;带矩阵背光时T1为8.6mm。
引脚说明
Pin No. Symbol External Connection Function Description
1 VSS Power Supply Ground
2 VDD Power Supply Supply Voltage for logic (+5.0V)
3 V0 Adj Power Supply Power supply for contrast (approx. 0.5V)
4 RS MPU Register select signal. RS = 0: Command, RS = 1: Data
5 R/W MPU Read/Write select signal, R/W = 1: Read R/W: = 0: Write
6 E MPU Operation enable signal. Falling edge triggered.
7 - 10 DB0 – DB3 MPU Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation.
11 - 14 DB4 – DB7 MPU Four high order bi - directional three - state data bus lines.
15 LED+ Power Supply Power supply for LED Backlight (+5.0V via on - board resistor)
16 LED - Power Supply Ground for Backlight
电气特性
Item Symbol Condition Min. Typ. Max. Unit
Operating Temperature Range Top Absolute Max - 20 - + 70 ⁰C
Storage Temperature Range Tst Absolute Max - 30 - + 80 ⁰C
Supply Voltage VDD 4.7 5.0 5.5 V
Supply Current IDD Ta = 25°C, VDD = 5.0V - 1.5 2.5 mA
Supply for LCD (contrast) VDD - V0 Ta = 25°C - 4.5 - V
“H” Level input Vih 2.2 - VDD V
“L” Level input Vil 0 - 0.6 V
“H” Level output Voh 2.4 - - V
“L” Level output Vol - - 0.4 V
Backlight Supply Voltage Vled - - 5.0 - V
Backlight Supply Current Iled Vled = 5.0V - 20 - mA
光学特性
Viewing Angle – Vertical (top) AV Cr ≥3 - 20 -
Viewing Angle – Vertical (bottom) AV Cr ≥3 - 50 -
Viewing Angle – Horizontal (left) AH Cr ≥3 - 30 -
Viewing Angle – Horizontal (right) AH Cr ≥3 - 30 -
Contrast Ratio Cr 3 5 - -
Response Time (rise) Tr - - 150 250 ms
Response Time (fall) Tf - - 150 250 ms
初始化程序
8位初始化
通过一系列指令完成模块的唤醒、功能设置、显示和光标设置等操作。例如,通过多次发送0x30指令唤醒模块,然后设置8位2行显示模式等。
4位初始化
与8位初始化类似,但在数据传输时采用4位方式。先发送低4位数据,再发送高4位数据。
质量信息与注意事项
质量测试
该模块经过了多种测试,包括高温存储、低温存储、高温操作、低温操作、高温高湿操作、热冲击抗性、振动测试和静电测试等,确保其在不同环境下的可靠性。
注意事项
使用时需注意避免冷凝现象,部分测试需在25⁰C,0%RH环境下存储4小时后进行,振动测试在产品本身进行而非在容器内。同时,可查看官网(www.newhavendisplay.com/specs/precautions.pdf )获取使用LCDs/LCMs的具体注意事项,以及(http://www.newhavendisplay.com/index.php?main_page=terms )了解保修信息和条款。
NHD - 0216K1Z - FSO - FBW - L字符液晶显示模块凭借其丰富的功能、良好的电气和光学特性以及可靠的质量,在电子设计中具有广泛的应用前景。各位工程师在实际设计中,不妨考虑这款模块,说不定能为你的项目带来意想不到的效果。大家在使用过程中遇到过哪些问题呢?欢迎在评论区分享交流。
