在电子设计领域,液晶显示模块是人机交互中常用的组件。今天我们来详细了解一下Newhaven Display公司的NHD - 0216K1Z - FSO - GBW - L字符液晶显示模块。
文件下载:NHD-0216K1Z-FSO-GBW-L.pdf
NHD - 0216K1Z - FSO - GBW - L这个型号包含了丰富的信息:
Newhaven Display International, Inc.位于2511 Technology Drive, Suite 101, Elgin IL, 60124,联系电话是847 - 844 - 8795,传真为847 - 844 - 8796,官网是www.newhavendisplay.com,技术邮箱是nhtech@newhavendisplay.com,销售邮箱是nhsales@newhavendisplay.com。
该产品文档有多次修订,从2007年10月5日的初始版本发布,到后续在用户指南格式、背光、光学、引脚输出、机械图纸等方面进行更新。
该模块具有2行×16字符的显示能力,能够满足基本的文本显示需求。
内置SPLC780D或ST7066U控制器,为显示提供了稳定的控制。
采用 + 5.0V电源供电,驱动方式为1/16 duty,1/5 bias,并且符合RoHS标准。
文档中给出了详细的机械图纸,包括不同背光情况下的厚度:无背光时厚度为4.6mm,边缘背光时为13.5mm,矩阵背光时为8.6mm(部分数据缺失)。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for logic (+5.0V) |
| 3 | V0 | Adj Power Supply | Power supply for contrast (approx. 0.5V) |
| 4 | RS | MPU | Register select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write |
| 6 | E | MPU | Operation enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED+ | Power Supply | Power supply for LED Backlight (+5.0V via on - board resistor) |
| 16 | LED - | Power Supply | Ground for Backlight |
推荐的LCD连接器为2.54mm间距引脚,文档中未提及背光连接器的匹配信息。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | - 20 | - | +70 | ⁰C |
| Storage Temperature Range | Tst | Absolute Max | - 30 | - | +80 | ⁰C |
| Supply Voltage | VDD | 4.7 | 5.0 | 5.5 | V | |
| Supply Current | IDD | Ta = 25°C, VDD = 5.0V | - | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | VDD - V0 | Ta = 25°C | - | 4.5 | - | V |
| “H” Level input | Vih | 2.2 | - | VDD | V | |
| “L” Level input | Vil | 0 | - | 0.6 | V | |
| “H” Level output | Voh | 2.4 | - | - | V | |
| “L” Level output | Vol | - | - | 0.4 | V | |
| Backlight Supply Voltage | Vled | - | - | 5.0 | - | V |
| Backlight Supply Current | Iled | Vled = 5.0V | - | 20 | - | mA |
| Viewing Angle – Vertical (top) | AV | Cr ≥2 | - | 25 | - | ⁰ |
| Viewing Angle – Vertical (bottom) | AV | Cr ≥2 | - | 70 | - | ⁰ |
| Viewing Angle – Horizontal (left) | AH | Cr ≥2 | - | 30 | - | ⁰ |
| Viewing Angle – Horizontal (right) | AH | Cr ≥2 | - | 30 | - | ⁰ |
| Contrast Ratio | Cr | - | 2 | - | - | |
| Response Time (rise) | Tr | - | - | 120 | 150 | ms |
| Response Time (fall) | Tf | - | - | 120 | 150 | ms |
模块内置SPLC780D和ST7066U控制器,其详细规格可分别从http://www.newhavendisplay.com/app_notes/SPLC780D.pdf和http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载。同时还给出了显示字符的地址代码。
文档中给出了内置字体表,通过不同的位组合对应不同的字符显示。
代码中包含了命令发送、数据写入和初始化函数,通过设置端口、控制信号和延时来完成初始化操作。
同样有命令发送、数据写入和初始化函数,不过在数据传输时采用4位方式,通过移位和分两次传输数据。
产品进行了多项质量测试,包括高温存储、低温存储、高温运行、低温运行、高温高湿运行、热冲击抵抗、振动测试和静电测试等,每种测试都有相应的条件和注意事项。
使用LCDs/LCMs的注意事项可在www.newhavendisplay.com/specs/precautions.pdf查看,保修信息和条款可访问http://www.newhavendisplay.com/index.php?main_page=terms。
在实际设计中,电子工程师需要根据这些详细的信息来合理使用该液晶显示模块,确保其性能和稳定性。大家在使用过程中遇到过哪些问题呢?欢迎交流分享。
