字符液晶显示模块NHD - 0212WH - AYYH - JT产品解析
一、产品概述
NHD - 0212WH - AYYH - JT是Newhaven Display International, Inc.推出的一款字符液晶显示模块。该模块具有2行12字符的显示能力,内置ST7066U控制器,采用+5.0V电源供电,具备1/16 duty、1/5 bias的特性,并且符合RoHS标准。
文件下载:NHD-0212WH-AYYH-JT#.pdf
二、产品关键参数与特性
(一)引脚说明与接线图
Pin No. Symbol External Connection Function Description
1 VSS Power Supply Ground
2 VDD Power Supply Supply Voltage for logic (+5.0V)
3 V0 Adj Power Supply Power supply for contrast (approx. 0.8V)
4 RS MPU Register select signal. RS = 0: Command, RS = 1: Data
5 R/W MPU Read/Write select signal, R/W = 1: Read R/W: = 0: Write
6 E MPU Operation enable signal. Falling edge triggered.
7 - 10 DB0 – DB3 MPU Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation.
11 - 14 DB4 – DB7 MPU Four high order bi - directional three - state data bus lines.
15 A Power Supply Power supply for LED Backlight (+4.2V)
推荐的LCD连接器为1.27mm间距引脚,不过文档中未提及背光连接器的适配信息。
(二)电气特性
Item Symbol Condition Min. Typ. Max. Unit
Operating Temperature Range Top Absolute Max - 20 - +70 ⁰C
Storage Temperature Range Tst Absolute Max - 30 - +80 ⁰C
Supply Voltage VDD 4.5 5.0 5.5 V
Supply Current IDD Ta = 25°C, VDD = 5.0V 0.5 1.0 2.0 mA
Supply for LCD (contrast) VDD - V0 Ta = 25°C 4.1 4.2 4.3 V
“H” Level input Vih 0.7*VDD - VDD V
“L” Level input Vil VSS - 0.6 V
“H” Level output Voh 3.9 - VDD V
“L” Level output Vol 0 - 0.4 V
Backlight Supply Voltage Vled - 4.0 4.2 4.7 V
Backlight Supply Current Iled Vled = 4.2V 32 40 48 mA
(三)光学特性
Viewing Angle – Top Cr ≥ 2 - 20 -
Viewing Angle – Bottom - 40 -
Viewing Angle – Left - 30 -
Viewing Angle – Right - 30 -
Contrast Ratio Cr - 3 - -
Response Time (rise) Tr - - 150 200 ms
Response Time (fall) Tf - - 150 200 ms
三、指令集与时序特性
(一)指令表
该模块提供了丰富的指令集,用于控制显示、光标等操作。例如: Instruction Instruction code Description 270 KHZ Execution time (fosc = )
Clear Display 0 0 0 0 0 0 0 0 0 0 1 Write “20H” to DDRAM and set DDRAM address to “00H” from AC 1.52ms
Return Home 0 0 0 0 0 0 0 0 0 1 - Set DDRAM Address to “00H” from AC and return cursor to its original position if shifted. The contents of DDRAM are not changed. 1.52ms
(二)时序特性
  1. 写数据(MPU到ST7066U)
    • Enable Cycle Time (Tc):1200ns
    • Enable Pulse Width (TPW):460ns
    • Enable Rise/Fall Time (TR, TF):最大25ns
    • Address Setup Time (TAS):0ns
    • Address Hold Time (TAH):10ns
  2. 读数据(ST7066U到MPU)
    • Enable Pulse Width (TPW):480ns
    • Enable Rise/Fall Time (TR, TF):25ns
    • Data Setup Time (TDDR):320ns
    • Data Hold Time (TH):10ns
四、初始化程序
(一)8位初始化
void command(char i)
    P1 = i; D1 = 0; R_W = 0; //put data on output Port //D/I = LOW: send instruction //R/W - LOW: Write
    E = 1;
    Delay(1); //enable pulse width >= 300ns
    E = 0; //Clock enable: falling edge
void write(char i)
    P1 = i; DI = 1; RW = 0; //put data on output Port //D/I = HIGH : send data //R/W - LOW: Write
    E = 1;
    Delay(1); E = 0; //enable pulse width >= 300ns //Clock enable: falling edge
void init()
    Delay(30); Delay(100); command(0x30); E = 0; command(0x30); Delay(10); command(0x30);
    //Wait >40 msec after power is applied //command 0x30 = Wake up //must wait 5ms, busy flag not available //command 0x30 = Wake up #2 //must wait 160us, busy flag not available //command 0x30 = Wake up #3
    Delay(10); command(0x38); command(0x10);
    //must wait 160us, busy flag not available //Function set: 8 - bit/2 - line //Set cursor
    command(0x0c); command(0x06);
    //Display ON; Cursor ON //Entry mode set
(二)4位初始化
    P1 = i; //put data on output Port
    D1 = 0; //D/I = LOW : send instruction
    R_W = 0; Nybble(); //R/W - LOW: Write //Send lower 4 bits
    i = i < < 4; P1 = i; Nybble(); //put data on output Port //Send upper 4 bits //Shift over by 4 bits
void write(char i)
    P1 = i; Dl = 1; RW = 0; //put data on output Port //D/I = HIGH: send data //R/W - LOW: Write
    Nybble(); i = i < < 4; P1 = i; //Clock lower 4bits //Shift over by 4 bits //put data on output Port
    Nybble(); //Clock upper 4 bits
void Nybble()
    E = 1;
void init()
    P1 = 0; P3 = 0;
    Delay(100); P1 = 0x30; //Wait >40 msec after power is applied //put 0x30 on the output port
    Delay(30); Nybble(); //must wait 5ms, busy flag not available //command 0x30 = Wake up
    Delay(10); Nybble(); //command 0x30 = Wake up #2 //must wait 160us, busy flag not available
    Nybble(); Nybble(); Delay(10); command(0x28); Delay(10); command(0x06); command(0x0F); P1 = 0x20; command(0x10);
    //can check busy flag now instead of delay //command 0x30 = Wake up #3 //put 0x20 on the output port //must wait 160us, busy flag not available //Function set: 4 - bit interface //Function set: 4 - bit/2 - line //Set cursor //Entry Mode set //Display ON; Blinking cursor
五、质量信息
该模块进行了多项质量测试,包括高低温存储、高低温操作、高温高湿操作、热冲击抵抗、振动测试和静电测试等。例如,高温存储测试在+80⁰C下进行48小时,低温存储测试在 - 30⁰C下进行48小时。这些测试确保了模块在不同环境条件下的可靠性。
六、总结
NHD - 0212WH - AYYH - JT字符液晶显示模块具有丰富的功能和良好的性能,适用于多种需要字符显示的应用场景。电子工程师在设计使用该模块时,需要充分了解其引脚功能、电气特性、指令集和时序要求,合理进行初始化编程,以确保模块正常工作。同时,通过质量测试信息可以对模块的可靠性有更深入的了解,从而更好地应用于实际项目中。大家在使用过程中有没有遇到过类似模块的一些特殊问题呢?欢迎在评论区分享交流。
  • 相关推荐
  • 热点推荐
