在电子设备的设计中,显示模块是不可或缺的组成部分,它直接影响着用户与设备之间的交互体验。今天,我们将深入探讨Newhaven Display公司的NHD-0216KZW-AG5 OLED显示模块,详细了解其特性、接口、指令以及使用中的注意事项。
文件下载:NHD-0216KZW-AG5.pdf
NHD-0216KZW-AG5是一款具有2行16字符显示能力的OLED显示模块。从其型号可以解读出很多关键信息:“NHD”代表Newhaven Display;“0216”表示2行16字符;“KZW”表明是OLED类型;“A”为特定型号;“G”代表发光颜色为绿色;“5”则意味着需要+5V的电源供应。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for OLED and logic |
| 3 | NC | - | No Connect |
| 4 | RS | MPU | Register select signal. RS=0: Command; RS=1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W=1: Read; R/W: =0: Write |
| 6 | E | MPU | Operation enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. Not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | NC | - | No Connect |
| 16 | NC | - | No Connect |
| 3 - 11 | NC | - | No Connect |
| 12 | SCL | MPU | Serial Clock signal |
| 13 | SDO | MPU | Serial Data output signal |
| 14 | SDI | MPU | Serial Data input signal |
| 16 | /CS | MPU | Active LOW Chip Select signal |
| 不同的MPU接口需要不同的跳线设置,如下表所示: | MPU Interface | L_PS_H | J80_J68 | L_CS_H | JCS | L_SHL_H |
| 6800 - MPU Parallel (default) | H | J68 | L | X | H | |
| 8080 - MPU Parallel | H | J80 | L | X | H | |
| Serial MPU | L | X | Open | Short | H |
这里的“X”表示不关心该跳线状态。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | TOP | Absolute Max | -40 | - | +80 | ⁰C |
| Storage Temperature Range | TST | Absolute Max | -40 | - | +85 | ⁰C |
| Supply Voltage | VDD | - | 4.8 | 5.0 | 5.3 | V |
| Supply Current | IDD | TOP = 25°C, VDD = 5.0V 50% Checkerboard | - | 31 | 46.5 | mA |
| “H” Level input | VIH | - | 0.8 * VDD | - | VDD | V |
| “L” Level input | VIL | - | VSS | - | 0.2 * VDD | V |
| “H” Level output | VOH | - | 0.8 * VDD | - | VDD | V |
| “L” Level output | VOL | - | VSS | - | 0.2 * VDD | V |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | ||
| Optimal Viewing Angles | Top | ϕY+ | 80 | - | - | ⁰ | ||
| Bottom | ϕY- | 80 | - | - | ⁰ | |||
| Left | θX- | 80 | - | - | ⁰ | |||
| Right | θX+ | 80 | - | - | ⁰ | |||
| Contrast Ratio | CR | - | 10,000:1 | - | - | - | ||
| Response Time | Rise | TR | - | - | 10 | - | µs | |
| Fall | TF | - | - | 10 | - | µs | ||
| Brightness 2,3 | LV | VDD = 5.0V, TOP = 25°C | 100 | 120 | - | cd/m² | ||
| Lifetime 1 | - | 50% Checkerboard | 80,000 | 100,000 | - | Hrs. |
需要注意的是,亮度与VDD有关,使用较低电压时亮度会变暗;为避免残留图像,建议使用屏幕保护程序。
模块提供了一系列指令,用于控制显示内容和操作,例如:
每个指令都有特定的代码和执行时间,在执行指令时,只有Busy Flag读取指令可以执行,当Busy Flag为“0”时,才能发送新的指令。
当DL设置为8位模式时,显示模块通过DB7 - DB0与MPU接口。
当DL设置为4位模式时,仅通过DB7 - DB4与MPU接口,每个指令需要分两次操作发送,先发送4个高阶位,再发送4个低阶位,完成整个8位指令后需要检查Busy Flag。
不同的MPU接口(6800 - MPU并行、8080 - MPU并行、串行接口)有各自的时序要求,设计时需要严格按照这些要求进行操作。
模块提供了多种字体表可供选择,包括英语/日语、西欧表1、英语/俄语和西欧表2。通过Function Set指令中的FT1和FT0位可以选择不同的字体表,在操作过程中更改字体表会立即将当前显示的数据转换为新字体表对应的字符。
Character Generator RAM(CGRAM)用于生成自定义的5x8字符图案,共有8个可用地址(0x00 - 0x08)。要将自定义字符显示在屏幕上,需要先将光标移动到所需的DDRAM位置,然后写入字符数据0x00 - 0x07。
初始化步骤与8位模式类似,但在Function Set等指令的发送上有所不同,需要分多次发送4位数据。
模块经过了一系列的质量测试,包括高温存储、低温存储、高温操作、低温操作、高温/湿度存储、热冲击抵抗、振动测试和静电测试等。在使用OLED/LCD/LCM时,还需要参考www.newhavendisplay.com/specs/precautions.pdf中的注意事项。
NHD-0216KZW-AG5 OLED显示模块具有丰富的功能和良好的性能,适用于各种需要字符显示的电子设备。在设计过程中,工程师需要根据具体需求选择合适的接口方式、字体表和指令,严格按照初始化序列进行操作,并注意电气和光学特性的要求。同时,了解模块的质量测试和使用注意事项,有助于确保设备的稳定性和可靠性。你在使用类似显示模块时遇到过哪些问题呢?欢迎在评论区分享。
