在电子设计领域,液晶显示模块是不可或缺的重要组件,它为用户提供了直观的信息展示界面。今天我们就来深入了解一款名为NHD - 0216SZ - FL - YBW的字符液晶显示模块。
NHD - 0216SZ - FL - YBW由Newhaven Display International, Inc.生产。其型号各部分含义丰富:“NHD - ”代表Newhaven Display;“0216 - ”表示该模块有2行,每行可显示16个字符;“SZ - ”为特定型号;“F - ”代表半透反射;“L - ”是指采用黄/绿色LED背光;“Y - ”表示STN正性 - 黄/绿色;“B - ”代表6:00最佳视角;“W - ”意味着宽温度范围,并且该模块符合RoHS标准。
该模块具备2行×16字符的显示能力,能够清晰地展示所需信息。
内置ST7066U控制器,为模块的稳定运行提供了有力支持。用户可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载其详细规格说明。
采用+5.0V电源供电,工作时具有1/16 duty、1/5 bias的特性,同时符合RoHS标准,更加环保。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for logic (+5.0V) |
| 3 | V0 | Adj Power Supply | Supply Voltage for contrast (approx. 0.5V) |
| 4 | RS | MPU | Register Select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED+ | Power Supply | Backlight Anode (+5.0V via on - board resistor) |
| 16 | LED - | Power Supply | Backlight Cathode (Ground) |
推荐使用2.54mm间距的引脚作为LCD连接器。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | TOP | Absolute Max | - 20 | - | +70 | ⁰C |
| Storage Temperature Range | TST | Absolute Max | - 30 | - | +80 | ⁰C |
| Supply Voltage | VDD | - | 4.8 | 5.0 | 5.2 | V |
| Supply Current | IDD | VDD = 5.0V | 1.0 | 1.5 | 2.0 | mA |
| Supply for LCD (contrast) | VLCD | TOP = 25°C | 4.3 | 4.5 | 4.7 | V |
| “H” Level input | VIH | - | 0.7*VDD | - | VDD | V |
| “L” Level input | VIL | - | VSS | - | 0.6 | V |
| “H” Level output | VOH | - | 3.9 | - | VDD | V |
| “L” Level output | VOL | - | VSS | - | 0.4 | V |
| Backlight Supply Voltage | VLED | - | 4.8 | 5.0 | 5.2 | V |
| Backlight Supply Current | ILED | VLED = 5.0V | 120 | 150 | 180 | mA |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | ||
| Optimal Viewing Angles | Top | ϕY+ | Cr ≥ 2 | - | 40 | - | ⁰ | |
| Bottom | ϕY - | - | 60 | - | ⁰ | |||
| Left | θX - | - | 60 | - | ⁰ | |||
| Right | θX+ | - | 60 | - | ⁰ | |||
| Contrast Ratio | CR | - | 2 | 5 | - | - | ||
| Response Time | Rise | TR | TOP = 25°C | - | 120 | 150 | ms | |
| Fall | TF | - | 120 | 150 | ms |
DDRAM地址有着明确的规定,为数据的存储和读取提供了清晰的指引。同时,模块提供了丰富的指令集,用于控制显示、设置模式等操作。例如,“Clear Display”指令可将“20H”写入DDRAM并将DDRAM地址从AC设置为“00H”,执行时间为1.52ms。
从MPU向ST7066U写入数据时,有着严格的时序要求,如Enable Cycle Time(Tc)为1200ns,Enable Pulse Width(TPW)为140ns等。
从ST7066U向MPU读取数据时,同样有相应的时序参数,像Data Setup Time(TDDR)为100ns等。
通过一系列指令和延时操作,实现模块的8位初始化,包括唤醒模块、设置功能、显示和光标模式等。
与8位初始化类似,但在数据传输上采用4位模式,通过分两次传输4位数据来完成操作。
该模块经过了多项严格的质量测试,如高温存储(+80⁰C,48hrs)、低温存储( - 30⁰C,48hrs)、高温运行(+70⁰C,48hrs)、低温运行( - 20⁰C,48hrs)、高温高湿运行(+40⁰C,90% RH,48hrs)、热冲击抗性、振动测试和静电测试等。
使用LCDs/LCMs时,可参考www.newhavendisplay.com/specs/precautions.pdf中的预防措施。同时,关于保修信息和条款可查看http://www.newhavendisplay.com/index.php?main_page=terms 。
NHD - 0216SZ - FL - YBW字符液晶显示模块以其丰富的功能、稳定的性能和严格的质量测试,为电子工程师在设计显示界面时提供了一个可靠的选择。在实际应用中,工程师们需要根据具体需求,合理运用其特性,以实现最佳的显示效果。大家在使用这款模块的过程中,有没有遇到过什么特别的问题呢?欢迎在评论区分享交流。
