在电子设备中,液晶显示模块是人机交互的重要组成部分。Newhaven Display International推出的NHD - 0220AZ - FL - GBW字符液晶显示模块,以其出色的性能和广泛的适用性,受到了众多电子工程师的青睐。本文将对该模块进行详细的技术剖析,帮助工程师们更好地了解和使用这款产品。
NHD - 0220AZ - FL - GBW这个型号包含了丰富的信息:
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for logic (+5.0V) |
| 3 | V0 | Adj Power Supply | Power supply for contrast (approx. 0.4V) |
| 4 | RS | MPU | Register select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write |
| 6 | E | MPU | Operation enable signal. Falling edge triggered. |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation. |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED+ | Power Supply | Power supply for LED Backlight (+5.0V via on - board resistor) |
| 16 | LED - | Power Supply | Ground for Backlight |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | - 20 | - | + 70 | ⁰C |
| Storage Temperature Range | Tst | Absolute Max | - 30 | - | + 80 | ⁰C |
| Supply Voltage | VDD | 4.7 | 5.0 | 5.5 | V | |
| Supply Current | IDD | Ta = 25°C, VDD = 5.0V | - | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | VDD - V0 | Ta = 25°C | - | 4.6 | - | V |
| “H” Level input | Vih | 2.2 | - | VDD | V | |
| “L” Level input | Vil | 0 | - | 0.6 | V | |
| “H” Level output | Voh | 2.4 | - | - | V | |
| “L” Level output | Vol | - | - | 0.4 | V | |
| Backlight Supply Voltage | Vled | - | - | 5.0 | - | V |
| Backlight Supply Current | Iled | Vled = 5.0V | - | 150 | 300 | mA |
| Viewing Angle – Vertical (top) | AV | Cr ≥2 | - | 25 | - | ⁰ |
| Viewing Angle – Vertical (bottom) | AV | Cr ≥2 | - | 70 | - | ⁰ |
| Viewing Angle – Horizontal (left) | AH | Cr ≥2 | - | 30 | - | ⁰ |
| Viewing Angle – Horizontal (right) | AH | Cr ≥2 | - | 30 | - | ⁰ |
| Contrast Ratio | Cr | - | 2 | - | - | |
| Response Time (rise) | Tr | - | - | 120 | 150 | ms |
| Response Time (fall) | Tf | - | - | 120 | 150 | ms |
内置SPLC780D控制器,其详细规格可从http://www.newhavendisplay.com/app_notes/SPLC780D.pdf下载。
| 该模块提供了一系列指令,用于控制显示、光标等操作,以下是部分指令示例: | Instruction | RS | R/W | DB7 | DB6 | Instruction Code | DB5 | DB4 | DB3 | DB2 | DB1 | DBO | Description | Execution time (fosc = 270KHz) |
| Clear Display | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | Write "20H" to DDRAM and set DDRAM address to "00H" from AC | 1.52ms | ||
| Return Home | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | Set DDRAM address to "00H" from AC and return cursor to its original position if shifted. The contents of DDRAM are not changed. | 1.52ms |
| Characteristics | Symbol | Limit | Unit | Test Condition | ||
| Min. | Typ. | Max. | ||||
| E Cycle Time | to | 500 | ns | An E | ||
| E Pulse Width | tW | 230 | ns | Pin E | ||
| E Rise/Fall Time | tR.tF | 20 | ns | Pin E | ||
| Address Setup Time | tsP1 | 40 | ns | Pins: RS, RW, E | ||
| Address Hold Time | HD1 | 10 | ns | Pins: RS, RW, E | ||
| Data Setup Time | tsP2 | 80 | ns | Pins: DB0 - DB7 | ||
| Data Hold Time | HD2 | 10 | ns | Pins: DB0 - DB7 |
| E Cycle Time | to | 500 | ns | Pin E | ||
| Address Setup Time | tsp | Pins: RS, RW, E | ||||
| Address Hold Time | 40 | Pins: RS, RW, E | ||||
| Data Setup Time | to | 120 | ||||
| Data Hold Time | 5.0 | ns | An DB0 - DB7 |
void command(char i) {
P1 = i; //put data on output Port
D_I = 0; //D/I = LOW : send instruction
R_W = 0; //R/W = LOW:Write
E = 1;
Delay(1); //enable pulse width >= 300ns
E = 0; //Clock enable: falling edge
void write(char i) {
E = 0;
D_I = 1; //D/I = HIGH : send data
R_W = 0; //R/W = LOW: Write
E = 1;
void init() {
E = 0;
Delay(100); //Wait >15 msec after power is applied
command(0x30); //command 0x30 = Wake up
Delay(30); //must wait 5ms, busy flag not available
command(0x30); //command 0x30 = Wake up #2
Delay(10); //must wait 160us, busy flag not available
command(0x30); //command 0x30 = Wake up #3
command(0x38); //Function set: 8-bit/2-line
command(0x10); //Set cursor
command(0x0c); //Display ON; Cursor ON
command(0x06); //Entry mode set
Nybble(); //Send lower 4 bits
i = i < < 4; //Shift over by 4 bits
Nybble(); //Send upper 4bits
R_W = 0; //R/W = LOW : Write
Nybble(); //Clock lower 4 bits
Nybble(); //Clock upper 4 bits
void Nybble() {
E = 1;
void init() {
P1 = 0;
P3 = 0;
P1 = 0x30; //put 0x30 on the output port
Nybble(); //command 0x30 = Wake up
Nybble(); //command 0x30 = Wake up #2
Nybble(); //command 0x30 = Wake up #3
Delay(10); //can check busy flag now instead of delay
P1 = 0x20; //put 0x20 on the output port
Nybble(); //Function set: 4-bit interface
command(0x28); //Function set: 4-bit/2-line
command(0x10);
command(0x0F); //Set cursor
command(0x0F); //Display ON; Blinking cursor
command(0x06); //Entry Mode set
| Test Item | Content of Test | Test Condition | Note |
| High Temperature storage | Endurance test applying the high storage temperature for a long time. | +80⁰C , 48hrs | 2 |
| Low Temperature storage | Endurance test applying the low storage temperature for a long time. | - 30⁰C , 48hrs | 1,2 |
| High Temperature Operation | Endurance test applying the electric stress (voltage & current) and the high thermal stress for a long time. | +70⁰C 48hrs | 2 |
| Low Temperature Operation | Endurance test applying the electric stress (voltage & current) and the low thermal stress for a long time. | - 20⁰C , 48hrs | 1,2 |
| High Temperature / Humidity Operation | Endurance test applying the electric stress (voltage & current) and the high thermal with high humidity stress for a long time. | +40⁰C , 90% RH , 48hrs | 1,2 |
| Thermal Shock resistance | Endurance test applying the electric stress (voltage & current) during a cycle of low and high thermal stress. | 0⁰C,30min -> 25⁰C,5min -> 50⁰C,30min = 1 cycle 10 cycles | |
| Vibration test | Endurance test applying vibration to simulate transportation and use. | 10 - 55Hz , 15mm amplitude. 60 sec in each of 3 directions X,Y,Z For 15 minutes | 3 |
| Static electricity test | Endurance test applying electric static discharge. | VS = 800V, RS = 1.5kΩ, CS = 100pF One time |
使用LCDs/LCMs时的具体注意事项可参考www.newhavendisplay.com/specs/precautions.pdf。同时,关于保修信息和条款可访问http://www.newhavendisplay.com/index.php?main_page=terms 。
Newhaven NHD - 0220AZ - FL - GBW字符液晶显示模块在显示能力、电气特性、光学特性等方面都表现出色。通过对其引脚、指令、时序特性以及初始化程序的了解,工程师们可以更好地将其应用到实际项目中。在使用过程中,遵循质量测试和使用注意事项,能够确保模块的稳定运行。大家在实际应用中是否遇到过类似模块的问题呢?欢迎在评论区分享交流。
