深入解析NHD-0220DZ-FSW-FBW字符液晶显示模块
在电子设备的设计中,液晶显示模块是不可或缺的重要组件。今天,我们就来详细了解一下Newhaven Display International推出的NHD - 0220DZ - FSW - FBW字符液晶显示模块。
文件下载:NHD-0220DZ-FSW-FBW.pdf
一、产品概述
1. 型号含义
NHD - 0220DZ - FSW - FBW这个型号包含了丰富的信息。“NHD”代表Newhaven Display;“0220”表示该模块有2行,每行可显示20个字符;“DZ”是具体的型号;“F”代表半透反射型;“SW”表示侧面白色LED背光;“F”为FSTN(+);“B”表示6:00最佳视角;“W”代表宽温度范围,并且该产品符合RoHS标准。
2. 产品特性
  • 显示能力:具备2行×20字符的显示能力,能够清晰展示所需信息。
  • 内置控制器:采用ST7066U控制器,为显示功能提供稳定支持。
  • 电源要求:采用+5.0V电源供电,工作时具有1/16 duty,1/5 bias的特性。
二、引脚分配与功能
1. 引脚分配
Pin No. Symbol External Connection Function Description
1 VSS Power Supply Ground
2 VDD Power Supply Supply Voltage for logic (+5.0V)
3 V0 Adj Power Supply Supply Voltage for contrast (approx. 0.7V)
4 RS MPU Register Select signal. RS = 0: Command, RS = 1: Data
5 R/W MPU Read/Write select signal, R/W = 1: Read R/W = 0: Write
6 E MPU Operation Enable signal. Falling edge triggered.
7 - 10 DB0 – DB3 MPU Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation.
11 - 14 DB4 – DB7 MPU Four high order bi - directional three - state data bus lines.
15 LED+ Power Supply Backlight Anode (+5.0V via on - board resistor)
16 LED- Power Supply Backlight Cathode (Ground)
2. 推荐连接器
推荐使用2x8 2.54mm间距的连接器,确保连接的稳定性和可靠性。
三、电气与光学特性
1. 电气特性
Item Symbol Condition Min. Typ. Max. Unit
Operating Temperature Range T OP Absolute Max -20 - +70 ⁰C
Storage Temperature Range T ST Absolute Max -30 - +80 ⁰C
Supply Voltage V DD - 4.7 5.0 5.3 V
Supply Current I DD V DD = 5.0V 1.0 2.0 2.5 mA
Supply for LCD (contrast) V LCD T OP = 25°C 4.1 4.3 4.5 V
“H” Level input V IH - 0.7*V DD - V DD V
“L” Level input V IL - V SS - 0.6 V
“H” Level output V OH - 3.9 - V DD V
“L” Level output V OL - V SS - 0.4 V
Backlight Supply Voltage V LED - 4.8 5.0 5.2 V
Backlight Supply Current I LED V LED = 5.0V 20 30 40 mA
2. 光学特性
Optimal Viewing Angles Top ϕY+ CR ≥ 2 - 40 -
Bottom ϕY- - 60 -
Left θX- - 60 -
Right θX+ - 60 -
Contrast Ratio CR - 2 5 - -
Response Time Rise T R T OP = 25°C - 150 250 ms
Fall T F - 200 300 ms
四、控制器信息
模块内置ST7066U控制器,其详细规格可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载。同时,文档中还给出了DDRAM地址分配情况,方便工程师进行数据存储和读取操作。
五、指令表与时序特性
1. 指令表
文档中详细列出了各种指令的代码、执行时间和功能描述,例如清屏指令、归位指令、显示开关控制指令等。这些指令是实现显示功能的基础,工程师需要根据实际需求合理使用。
2. 时序特性
  • 写数据时序:从MPU向ST7066U写数据时,涉及到使能周期时间(Tc)、使能脉冲宽度(TPW)、使能上升/下降时间(TR,TF)等参数,这些参数的合理设置对于数据的准确传输至关重要。
  • 读数据时序:从ST7066U向MPU读数据时,同样有相应的时序要求,如数据建立时间(TDDR)等。
六、初始化程序
1. 8位初始化
给出了8位初始化的示例代码,包括命令发送、数据写入和初始化函数。在初始化过程中,需要注意各个步骤的延时时间,以确保模块正常启动。例如,在电源接通后需要等待大于40ms,发送唤醒命令后也需要相应的延时。
2. 4位初始化
同样提供了4位初始化的示例代码,与8位初始化不同的是,4位初始化需要分两次发送数据,先发送低4位,再发送高4位。
七、质量信息与注意事项
1. 质量测试
对模块进行了多项质量测试,如高温存储、低温存储、高温运行、低温运行、高温高湿运行、热冲击抵抗、振动测试和静电测试等。这些测试确保了模块在不同环境条件下的可靠性和稳定性。
2. 注意事项
使用LCD/LCM时,需要注意避免冷凝现象,具体的预防措施可参考www.newhavendisplay.com/specs/precautions.pdf。同时,关于产品的保修信息和条款可访问http://www.newhavendisplay.com/index.php?main_page=terms。
在实际设计中,电子工程师需要根据这些特性和要求,合理选择和使用NHD - 0220DZ - FSW - FBW字符液晶显示模块,以确保设备的性能和稳定性。大家在使用过程中是否遇到过类似模块的兼容性问题呢?欢迎在评论区分享你的经验。
  • 相关推荐
  • 热点推荐
