在电子设备的设计中,液晶显示模块是不可或缺的重要组成部分。今天我们就来深入了解一下Newhaven Display International公司的NHD - 0220JZ - FSB - GBW字符液晶显示模块。
了解产品名称的含义,能让我们迅速掌握其主要特性。NHD - 0220JZ - FSB - GBW这个名称中:
| Pin No. | Symbol | External Connection | Function Description |
| 1 | Vss | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply voltage for logic (+5.0V) |
| 3 | V0 | Power Supply | Power supply for contrast (approx. 0.4V) |
| 4 | RS | MPU | Register select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W = 0: Write |
| 6 | E | MPU | Operation enable signal. Falling edge triggered. |
| 7 - 10 | DB0 - DB3 | MPU | Four low order bi - directional three - state data bus lines. These four are no used during 4 - bit operation. |
| 11 - 14 | DB4 - DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED+ | Power Supply | Power supply for LED Backlight (+5.0 via on - board resistor) |
| 16 | LED - | Power Supply | Ground for backlight |
推荐使用2.54mm间距的引脚作为LCD连接器,不过文档中未提及背光连接器的匹配信息。大家在实际设计时,要根据这些引脚功能正确连接电路,避免出现错误。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | Top | Absolute Max | - 20 | - | + 70 | ⁰C |
| Storage Temperature Range | Tst | Absolute Max | - 30 | - | + 80 | ⁰C |
| Supply Voltage | VDD | 4.7 | 5.0 | 5.5 | V | |
| Supply Current | IDD | Ta = 25°C, VDD = 5.0V | - | 1.5 | 2.5 | mA |
| Supply for LCD (contrast) | VDD - V0 | Ta = 25°C | - | 4.6 | - | V |
| “H” Level input | Vih | 2.2 | - | VDD | V | |
| “L” Level input | Vil | 0 | - | 0.6 | V | |
| “H” Level output | Voh | 2.4 | - | - | V | |
| “L” Level output | Vol | - | - | 0.4 | V | |
| Backlight Supply Voltage | Vled | - | - | 5.0 | - | V |
| Backlight Supply Current | Iled | Vled = 5.0V | - | 60 | - | mA |
这些电气参数是设计电源电路和信号处理电路的重要依据,大家在设计时一定要严格按照这些参数来选择合适的元器件。
| Viewing Angle – Vertical (top) | AV | Cr ≥2 | - | 25 | - | ⁰ |
| Viewing Angle – Vertical (bottom) | AV | Cr ≥2 | - | 70 | - | ⁰ |
| Viewing Angle – Horizontal (left) | AH | Cr ≥2 | - | 30 | - | ⁰ |
| Viewing Angle – Horizontal (right) | AH | Cr ≥2 | - | 30 | - | ⁰ |
| Contrast Ratio | Cr | - | 2 | - | - | |
| Response Time (rise) | Tr | - | - | 120 | 150 | ms |
| Response Time (fall) | Tf | - | - | 120 | 150 | ms |
光学特性决定了显示效果,我们在设计时要根据实际应用场景来考虑这些参数,比如在户外强光环境下,可能需要更高的对比度和更广的视角。
文档中给出了详细的指令表,通过不同的RS、R/W和数据位组合,可以实现各种操作,如写入数据、返回主页、显示开关等。同时,还给出了显示字符的地址码,这对于在模块上显示特定字符非常重要。大家在编程时,要根据这些指令和地址码来实现所需的显示功能。
文档给出了8位初始化的示例程序,主要步骤包括:
4位初始化程序与8位初始化类似,但在发送数据时需要分两次发送4位数据。主要步骤包括:
大家在实际应用中,可以根据自己的需求选择合适的初始化方式。
该模块经过了多种质量测试,包括高温存储、低温存储、高温操作、低温操作、高温高湿操作、热冲击、振动和静电测试等。测试条件和时间都有明确规定,如高温存储测试在 + 80⁰C下进行48小时等。这些测试确保了模块在不同环境下的可靠性。
在使用LCDs/LCMs时,要注意避免出现冷凝现象,部分测试需要在25⁰C,0%RH下存储4小时后进行,振动测试是对产品本身进行,而非在容器内进行。同时,可以通过链接www.newhavendisplay.com/specs/precautions.pdf查看使用LCD的注意事项,通过http://www.newhavendisplay.com/index.php?main_page=terms 了解保修信息和条款。
总之,NHD - 0220JZ - FSB - GBW字符液晶显示模块是一款功能丰富、性能稳定的显示模块。在设计过程中,我们要充分了解其各项特性和参数,合理进行电路设计和编程,以确保模块能正常工作并达到预期的显示效果。大家在使用过程中遇到问题,欢迎一起交流探讨。
