void command(char i) {
P1 = i; //put data on output Port
D_I = 0; //D/I = LOW : send instruction
E = 1;
Delay(1);
RW = 0; //R/W = LOW:Write
Delay(1); //enable pulse width >= 300ns
E = 0; //Clock enable: falling edge
void write(char i) {
D_I = 1; //D/I = HIGH : send data
RW = 0; //R/W = LOW : Write
E = 1;
Delay(1);
void init() {
E = 0;
Delay(100); //Wait >40 msec after power is applied
command(0x30); //command 0x30 = Wake up
Delay(30); //must wait 5ms, busy flag not available
command(0x30); //command 0x30 = Wake up #2
Delay(10); //must wait 160us, busy flag not available
command(0x30); //command 0x30 = Wake up #3
command(0x38); //Function set: 8 - bit/2 - line
command(0x10);
command(0x0c); //Set cursor
command(0x06); //Entry mode set
7.2 4位初始化
RW = 0;
Nybble(); //R/W = LOW: Write
i = i < < 4; //Shift over by 4 bits
Nybble(); //Send upper 4 bits
RW = 0; //R/W = LOW: Write
Nybble(); //Clock lower 4 bits
Nybble(); //Clock upper 4 bits
void Nybble() {
E = 1;
void init() {
P1 = 0;
P3 = 0;
P1 = 0x30; //put 0x30 on the output port
Nybble(); //command 0x30 = Wake up
Nybble(); //command 0x30 = Wake up #2
Nybble(); //command 0x30 = Wake up #3
Delay(10); //can check busy flag now instead of delay
P1 = 0x20; //put 0x20 on the output port
Nybble(); //Function set: 4 - bit interface
command(0x28); //Function set: 4 - bit/2 - line
command(0x10); //Set cursor
command(0x0F); //Display ON; Blinking cursor
command(0x06); //Entry Mode set
