在电子设计领域,液晶显示模块是不可或缺的组件,它为设备提供了直观的信息展示界面。今天,我们将深入探讨Newhaven Display International公司的NHD - 0420AZ - FL - GBW - 33V3字符液晶显示模块,了解其特性、参数以及使用方法。
文件下载:NHD-0420AZ-FL-GBW-33V3.pdf
NHD - 0420AZ - FL - GBW - 33V3是一款4行20字符的液晶显示模块,内置ST7066U或等效控制器,采用3.3V电源供电,符合RoHS标准。其型号各部分含义如下:
模块的机械绘图信息属于Newhaven Display International公司的专有财产,未经许可不得复制、再现和披露。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground |
| 2 | VDD | Power Supply | Supply Voltage for Logic (+3.3V) |
| 3 | V0 | Power Supply | Supply Voltage for Contrast (approx. 0V) |
| 4 | RS | MPU | Register Select signal. RS = 0: Command, RS = 1: Data |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W = 0: Write |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. |
| 7 - 10 | DB0 - DB3 | MPU | For low order bi - directional three - state data bus lines. Not used during 4 - bit operation. |
| 11 - 14 | DB4 - DB7 | MPU | Four high order bi - directional three - state data bus lines. |
| 15 | LED+ | Power Supply | Backlight Anode (15mA @ 3V) |
| 16 | LED - | Power Supply | Backlight Cathode (Ground) |
推荐使用2.54mm间距的引脚作为LCD连接器。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | TOP | Absolute Max | - 20 | - | +70 | ⁰C |
| Storage Temperature Range | TST | Absolute Max | - 30 | - | +80 | ⁰C |
| Supply Voltage | VDD | - | 3.1 | 3.3 | 3.5 | V |
| Supply Current | IDD | VDD = 3.3V | 0.5 | 1.5 | 3.0 | mA |
| Supply for LCD (contrast) | VLCD | TOP = 25°C | 3.1 | 3.3 | 3.5 | V |
| “H” Level input | VIH | - | 0.7 * VDD | - | VDD | V |
| “L” Level input | VIL | - | VSS | - | 0.6 | V |
| “H” Level output | VOH | - | 0.75 * VDD | - | VDD | V |
| “L” Level output | VOL | - | VSS | - | 0.2 * VDD | V |
| Backlight Supply Current | ILED | - | - | 15 | 20 | mA |
| Backlight Supply Voltage | VLED | ILED = 15mA | 2.8 | 3.0 | 3.3 | V |
需要注意的是,背光源的LED由电流驱动,驱动电压仅作参考,必须选择合适的驱动电压以确保背光源电流低于最大额定值。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | ||
| Optimal Viewing Angles | Top | ϕY+ | CR ≥ 2 | - | 40 | - | ° | |
| Bottom | ϕY - | - | 60 | - | ° | |||
| Left | θX - | - | 60 | - | ° | |||
| Right | θX+ | - | 60 | - | ° | |||
| Contrast Ratio | CR | - | 2 | 5 | - | - | ||
| Response Time | Rise | TR | TOP = 25°C | - | 150 | 250 | ms | |
| Fall | TF | - | 200 | 300 | ms |
这些光学特性决定了模块在不同视角和环境下的显示效果,工程师在设计时需要根据实际应用场景进行考虑。
| 模块内置ST7066U控制器,可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载其详细规格。DDRAM地址分配如下: | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 13 | 14 | |
| 00 01 02 03 04 05 06 | 07 08 | 09 | 0A 0B 0C 0D 0E 0F 10 11 12 13 | |||||||||||
| 40 41 42 43 44 45 46 | 47 48 | 49 | 4A 4B 4C 4D 4E 4F 50 51 52 53 | |||||||||||
| 14 15 16 17 18 19 1A 1B 1C 1D 1E | 1F | 20 | 21 |
| 模块提供了一系列命令,用于控制显示、设置模式等操作。以下是部分常见命令: | Instruction | Instruction code | Description | 270 KHZ Execution time (fosc = | |||||||||
| RS | R/W DB7 DB6 DB5 DB4 DB3 DB2 DB1 DB0 | ||||||||||||
| Clear Display | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | Write “20H” to DDRAM and set DDRAM address to “00H” from AC | 1.52ms | |
| Return Home | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | - | Set DDRAM Address to “00H” from AC and return cursor to its original position if shifted. The contents of DDRAM are not changed. | 1.52ms | |
| Entry mode Set | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 1 | I/D | SH | Sets cursor move direction and specifies display shift. These parameters are performed during data write and read. | 37µs | |
| Display ON/ OFF control | 0 | 0 | 0 | 0 | 0 | 0 | 1 | D | C | B | D = 1: Entire display on C = 1: Cursor on B = 1: Blinking cursor on | 37µs |
工程师可以根据需要选择合适的命令来实现不同的显示效果。
| Enable Cycle Time | Pin E | ns | ||||
| TR,TF | Pin E | 25 | ||||
| TAS | Address Setup Time | Pins: RS,RW,E | ||||
| Address Hold Time | Pins: RS,RW,E | - | ||||
| Data Setup Time | 80 | ns | ||||
| Pins: DB0 - DB7 | 10 |
| Tc | Pin E | ns | ||||
| TPW | Enable Pulse Width | Pin E | 480 | |||
| TR,TF | Pin E | - | 25 | ns | ||
| TAS | 0 | - | ns | |||
| TAH | Pins: RS,RW,E | 10 | ns | |||
| TDDR | Data Setup Time | Pins: DB0 - DB7 | 320 | |||
| 10 | ns |
了解这些时序特性对于正确读写数据至关重要,在设计电路时需要严格按照这些参数进行设置。
void command(char i)
P1 = i; //put data on output Port
D_I = 0;
D_I = 0; //D/I = LOW : send instruction
R_W = 0; E = 1; //R/W = LOW:Write
Delay (1);
Delay(1); //enable pulse width >= 300ns
E = 0; //Clock enable:falling edge
void write(char i)
P1 = i; D_I = 1; R_W = 0; //put data on output Port //D/I = HIGH : send data //R/W = LOW:Write
E = 1;
Delay (1);
void init()
E = 0;
Delay(100); //Wait >40 msec after power is applied
Delay (100);
command (0x30); //command 0x30 = Wake up
Delay (30);
Delay(30); //must wait 5ms, busy flag not available
command (0x30); //command 0x30 = Wake up #2
Delay (10);
Delay(10); //must wait 160us, busy flag not available
command(0x30); //command 0x30 = Wake up #3
command (0x30);
Delay (10);
command (0x38);
command(0x38); //Function set: 8 - bit/2 - line
command (0x10); //Set cursor
command (0x0c);
command(0x0c); //Display ON; Cursor ON
command (0x06); //Entry mode set
D_I = 0;
R_W = 0; Nybble(); i = i < < 4; //R/W = LOW:Write //Send lower 4 bits //Shift over by 4 bits
P1 = i;
Nybble(); //Send upper 4 bits
void write(char i)
P1 = i;
R_W = 0; Nybble(); i = i < < 4; P1 = i; D_I = 1; //D/I = HIGH : send data //R/W = LOW: Write //Clock lower 4 bits //Shift over by 4 bits
Nybble (); //Clock upper 4 bits
void Nybble()
E = 1;
Delay (1);
void init()
P1 = 0; P3 = 0;
Delay (100);
P1 = 0x30; //put 0x30 on the output port
P1 = 0x30;
Delay (30);
Nybble(); //command 0x30 = Wake up
Delay (10);
Nybble(); //command 0x30 = Wake up #2
Delay (10);
Nybble ();
Nybble(); //command 0x30 = Wake up #3
Delay(10); //can check busy flag now instead of delay
Delay (10);
P1 = 0x20; //put 0x20 on the output port
P1 = 0x20;
Nybble(); //Function set: 4 - bit interface
Nybble ();
command (0x28);
command(0x28); //Function set: 4 - bit/2 - line
command (0x0F);
command(0x0F); //Display ON; Blinking cursor
command (0x06); //Entry Mode set
| 模块经过了多项质量测试,包括高温存储、低温存储、高温操作、低温操作、高温高湿操作、热冲击抗性、振动测试和静电测试等。测试条件和注意事项如下: | Test Item | Content of Test | Test Condition | Note |
| High Temperature storage | Endurance test applying the high storage temperature for a long time. | +80⁰C , 48hrs | 2 | |
| Low Temperature storage | Endurance test applying the low storage temperature for a long time. | -30⁰C , 48hrs | 1,2 | |
| High Temperature Operation | Endurance test applying the electric stress (voltage & current) and the high thermal stress for a long time. | +70⁰C 48hrs | 2 | |
| Low Temperature Operation | Endurance test applying the electric stress (voltage & current) and the low thermal stress for a long time. | -20⁰C , 48hrs | 1,2 | |
| High Temperature / Humidity Operation | Endurance test applying the electric stress (voltage & current) and the high thermal with high humidity stress for a long time. | +40⁰C , 90% RH , 48hrs | 1,2 | |
| Thermal Shock resistance | Endurance test applying the electric stress (voltage & current) during a cycle of low and high thermal stress. | 0⁰C,30min -> 25⁰C,5min -> 50⁰C,30min = 1 cycle 10 cycles | ||
| Vibration test | Endurance test applying vibration to simulate transportation and use. | 10 - 55Hz , 15mm amplitude. 60 sec in each of 3 directions X,Y,Z For 15 minutes | 3 | |
| Static electricity test | Endurance test applying electric static discharge. | VS = 800V, RS = 1.5kΩ, CS = 100pF One time |
