NHD - 0220FZ - FSW - GBW - P - 33V3是Newhaven Display International, Inc.生产的一款字符液晶显示模块。从其型号可以解读出丰富的信息:
文件下载:NHD-0220FZ-FSW-GBW-P-33V3.pdf
该模块具有2行×20字符的显示能力,内置ST7066U控制器,采用+3.3V电源供电,工作模式为1/16 duty,1/5 bias。
| 详细的引脚分配如下表所示: | Pin No. | Symbol | External Connection | Function Description |
| 1 | VSS | Power Supply | Ground | |
| 2 | VDD | Power Supply | Supply Voltage for logic (+3.3V) | |
| 3 | V0 | Adj. Power Supply | Supply Voltage for contrast (approx. 0 V) | |
| 4 | RS | MPU | Register Select signal. RS = 0: Command, RS = 1: Data | |
| 5 | R/W | MPU | Read/Write select signal, R/W = 1: Read R/W: = 0: Write | |
| 6 | E | MPU | Operation Enable signal. Falling edge triggered. | |
| 7 - 10 | DB0 – DB3 | MPU | Four low order bi - directional three - state data bus lines. These four are not used during 4 - bit operation. | |
| 11 - 14 | DB4 – DB7 | MPU | Four high order bi - directional three - state data bus lines. | |
| 15 | LED+ | Power Supply | Backlight Anode (15mA @3V) | |
| 16 | LED - | Power Supply | Backlight Cathode (Ground) | |
| 17 | VSS | |||
| 18 | VDD | |||
| 19 | V0 | |||
| 20 | RS | |||
| 21 | RW | |||
| 22 | E | |||
| 23 - 26 | DB4 - DB7 | |||
| 27 | LED+ | |||
| 28 | LED - |
推荐使用1.27mm间距的引脚作为LCD连接器。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | TOP | Absolute Max | - 20 | - | +70 | ⁰C |
| Storage Temperature Range | TST | Absolute Max | - 30 | - | +80 | ⁰C |
| Supply Voltage | VDD | - | 3.0 | 3.3 | 3.6 | V |
| Supply Current | IDD | VDD = 3.3V | 0.5 | 1.0 | 2.0 | mA |
| Supply for LCD (contrast) | VLCD | TOP = 25°C | 3.1 | 3.3 | 3.5 | V |
| “H” Level input | VIH | - | 0.7 * VDD | - | VDD | V |
| “L” Level input | VIL | - | VSS | - | 0.6 | V |
| “H” Level output | VOH | - | 0.75 * VDD | - | VDD | V |
| “L” Level output | VOL | - | VSS | - | 0.2 * VDD | V |
| Backlight Supply Voltage | VLED | - | 2.8 | 3.0 | 3.2 | V |
| Backlight Supply Current | ILED | VLED = 3.0V | 7 | 15 | 20 | mA |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | |
| Optimal Viewing Angles | Top | ϕY+ | CR ≥ 2 | - | 40 | - | ° |
| Bottom | ϕY - | - | 60 | - | ° | ||
| Left | θX - | - | 60 | - | ° | ||
| Right | θX+ | - | 60 | - | ° | ||
| Contrast Ratio | CR | - | 2 | 5 | - | ||
| Response Time | Rise | TR | TOP = 25°C | - | 150 | 250 | ms |
| Fall | TF | - | 200 | 300 | ms |
模块内置ST7066U控制器,详细的规格说明可从http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载。
| 模块提供了丰富的指令集,用于控制显示操作,例如清屏、光标移动、显示开关等。以下是部分指令示例: | Instruction | Instruction code | Description | 270 KHZ Execution time (fosc = ) |
| Clear Display | 0 0 0 0 0 0 0 0 0 1 | Write “20H” to DDRAM and set DDRAM address to “00H” from AC | 1.52ms | |
| Return Home | 0 0 0 0 0 0 0 0 1 - | Set DDRAM Address to “00H” from AC and return cursor to its original position if shifted. The contents of DDRAM are not changed. | 1.52ms | |
| Entry mode Set | 0 0 0 0 0 0 0 1 I/D SH | Sets cursor move direction and specifies display shift. These parameters are performed during data write and read. | 37µs |
void command(char i)
P1 = i; //put data on output Port
D_I = 0; //D/I = LOW : send instruction
RW = 0; //R/W = LOW: Write
E = 1;
Delay(1); //enable pulse width >= 300ns
E = 0; //Clock enable: falling edge
void write(char i)
D_I = 1; //D/I = HIGH : send data
RW = 0; //R/W = LOW : Write
E = 1;
void init()
E = 0;
Delay(100); //Wait >40 msec after power is applied
command(0x30); //command 0x30 = Wake up
Delay(30); //must wait 5ms, busy flag not available
command(0x30); //command 0x30 = Wake up #2
Delay(10); //must wait 160us, busy flag not available
command(0x30); //command 0x30 = Wake up #3
command(0x38); //Function set: 8 - bit/2 - line
command(0x10); //Set cursor
command(0x0c); //Display ON; Cursor ON
command(0x06); //Entry mode set
RW = 0;
Nybble(); //Send upper 4 bits
i = i < < 4; //Shift over by 4 bits
Nybble(); //Send lower 4 bits
void write(char i)
RW = 0;
Nybble(); //Clock upper 4 bits
Nybble(); //Clock lower 4 bits
void Nybble()
E = 1;
void init()
P1 = 0; P3 = 0;
P1 = 0x30; //put 0x30 on the output port
Nybble(); //command 0x30 = Wake up
Nybble(); //command 0x30 = Wake up #2
Nybble(); //command 0x30 = Wake up #3
Delay(10); //can check busy flag now instead of delay
P1 = 0x20; //put 0x20 on the output port
Nybble(); //Function set: 4 - bit interface
command(0x28); //Function set: 4 - bit/2 - line
command(0x0F); //Display ON; Blinking cursor
command(0x06); //Entry Mode set
该模块经过了多项质量测试,包括高温存储、低温存储、高温运行、低温运行、高温高湿运行、热冲击抗性、振动测试和静电测试等,以确保其在不同环境下的可靠性。
使用LCD/LCM时的详细注意事项可在www.newhavendisplay.com/specs/precautions.pdf查看。同时,保修信息和条款可访问http://www.newhavendisplay.com/index.php?main_page=terms 。
在实际应用中,电子工程师可以根据这些特性和参数,合理地将NHD - 0220FZ - FSW - GBW - P - 33V3模块集成到自己的项目中。你在使用这款模块时,有没有遇到过一些特殊的问题呢?欢迎在评论区分享。
