在电子设计领域,显示模块的设计与应用至关重要。今天,我们来深入了解Newhaven Display推出的NHD - 1.5 - Breakout,这是一款专门为1.5英寸彩色OLED玻璃设计的breakout板。
文件下载:NHD-1.5-BREAKOUT.pdf
NHD - 1.5 - Breakout是Newhaven Display International, Inc.旗下的产品,其对角线尺寸为1.5英寸。该公司位于Elgin IL,联系电话为847 - 844 - 8795,传真为847 - 844 - 8796,邮箱为nhtech@newhavendisplay.com和nhsales@newhavendisplay.com,官方网站是www.newhavendisplay.com。
它是专门为1.5英寸彩色OLED玻璃(NHD - 1.5 - 128128G)设计的breakout板,板载有升压电路(FAN5331SX)。同时,还提供了跳线选项,可绕过升压电路,直接提供(V_{cc})。并且,该产品属于开源硬件,方便开发者进行二次开发。
从硬件布局来看,它有OLED显示屏、用户界面、LED驱动器、LED驱动电源指示灯以及3.5mm的安装孔等。
| Pin No. | Symbol | External Connection | Function Description |
| 1 | GND | Power Supply | Ground |
| 2 | 3V3 | Power Supply | Supply Voltage for OLED Logic (+3.3V) |
| 3 | DRV_VDD | Power Supply | Supply Voltage for boost converter (+5V) to drive OLED panel voltage (VCC). (Should be no connect if using pin 4 to apply external VCC) |
| 4 | N.C./VCC | - | No Connect by default. Can be configured for external VCC (+13V). (refer to On - Board Jumper Options table below) |
| 23 - 26 | GND | Power Supply | Ground |
| 5 | SHDN# | MPU | Active LOW Shutdown control pin for boost converter (pulled HIGH via on - board 10kΩ resistor) |
| 6 | GPIO0 | MPU | See command 0xB5 (can be treated as a no connect) |
| 7 | GPIO1 | MPU | See command 0xB5 (can be treated as a no connect) |
| 8 | RES# | MPU | Active LOW Reset signal |
| 9 | D/C# | MPU | Register Select signal. LOW: Command. HIGH: Data |
| 10 | CS# | MPU | Active LOW Chip Select signal |
| 11 | BS1 | MPU | MPU interface select signal |
| 12 | BS0 | MPU | MPU interface select signal |
| 13 | R/W# | MPU | 6800 mode : Read/Write signal. LOW: Write. HIGH: Read 8080 mode : Active LOW Write signal |
| 14 | E/RD# | MPU | 6800 mode : Enable signal. Falling edge triggered 8080 mode : Active LOW Read signal |
| 15 | D0/SCK | MPU | Parallel interface : |
| 16 | D1/SDIN | MPU | 8 - bit bi - directional data bus Serial interface : D0 = Serial Clock signal (SCK) D1 = Serial Data Input signal (SDIN) |
| 17 | D2 | MPU | |
| 18 | D3 | MPU | |
| 19 | D4 | MPU | |
| 20 | D5 | MPU | |
| 21 | D6 | MPU | |
| 22 | D7 | MPU |
| Bus Interface | D7 | D6 | D5 | D4 | D3 | D2 | D1 | D0 | E | R/W | BS0 | BS1 | CS# | D/C# | RES# | GPIO1 | GPIO0 |
| 8 - bit 6800 | D[7:0] | E | R/W | 1 | 1 | CS# | D/C# | RES# | NC | NC | |||||||
| 8 - bit 8080 | D[7:0] | RD# | WR# | 0 | 1 | CS# | D/C# | RES# | NC | NC | |||||||
| 4 - wire SPI | 0 | NC | SDIN | SCK | 0 | 0 | 0 | 0 | CS# | D/C# | RES# | NC | NC | ||||
| 3 - wire SPI | 0 | NC | SDIN | SCK | 0 | 0 | 1 | 0 | CS# | 0 | RES# | NC | NC |
这里“X”表示不关心,“NC”表示不连接,“1”表示VDD,“0”表示VSS。大家在实际设计中,要根据具体的接口类型来正确连接引脚,你是否遇到过因为引脚连接错误而导致的问题呢?
| R10 | R11 | Description |
| Open | Close | (default) Boost converter circuit (+5V on pin 3) is used to provide VCC to OLED Glass. |
| Close | Open | Boost converter circuit (pin 3) is not used. |
| User must apply VCC (+13V) externally to (pin 4). | ||
| OLED logic is still powered from 3V3 (pin 2). | ||
| This method allows for minimum current drain. |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | T OP | Absolute Max | -40 | - | +70 | ⁰C |
| Storage Temperature Range | T ST | Absolute Max | -40 | - | +85 | ⁰C |
| Supply Voltage for OLED Logic | 3V3 | - | 2.8 | 3.0 | 3.5 | V |
| Supply Voltage for Boost Circuit | DRV_VDD | - | - | 5.0 | 5.5 | V |
| Supply Voltage for OLED Panel | V CC | - | 12.5 | 13.0 | 13.5 | V |
需要注意的是,不建议在未连接显示屏的情况下给板卡供电,否则可能会损坏升压电路,Newhaven Display对此类损坏导致的PCB故障不承担责任。
该板专门设计用于驱动和引出NHD - 1.5 - 128128G的信号,你可以从http://www.newhavendisplay.com/specs/NHD - 1.5 - 128128G.pdf下载其规格书。
| Test Item | Content of Test | Test Condition | Note |
| High Temperature storage | Test the endurance of the display at high storage temperature. | +85⁰C, 240 Hrs. | 2 |
| Low Temperature storage | Test the endurance of the display at low storage temperature. | -40⁰C, 240 Hrs. | 1,2 |
| High Temperature Operation | Test the endurance of the display by applying electric stress (voltage & current) at high temperature. | +70⁰C, 240 Hrs. | 2 |
| Low Temperature Operation | Test the endurance of the display by applying electric stress (voltage & current) at low temperature. | -40⁰C, 240 Hrs. | 1,2 |
| High Temperature / Humidity Operation | Test the endurance of the display by applying electric stress (voltage & current) at high temperature with high humidity. | +60⁰C, 90% RH, 120 Hrs. | 1,2 |
Note 1: No condensation to be observed. Note 2: Conducted after 2 hours of storage at 25⁰C, 0%RH.
使用OLEDs/LCDs/LCMs的注意事项可参考www.newhavendisplay.com/specs/precautions.pdf,保修信息可查看http://www.newhavendisplay.com/index.php?main_page=terms。
总之,NHD - 1.5 - Breakout是一款功能丰富、设计灵活的breakout板,在彩色OLED显示模块的设计中具有很大的应用潜力。你在使用类似的breakout板时,有没有什么独特的经验或遇到过什么挑战呢?欢迎在评论区分享。
