探秘NHD - 0420H1Z - FSW - GBW - 3V3字符液晶显示模块
一、模块概述
NHD - 0420H1Z - FSW - GBW - 3V3是Newhaven Display International推出的一款字符液晶显示模块。从其型号就能获取不少关键信息:“0420”表明该模块有4行,每行可显示20个字符;“H1Z”代表特定型号;“F”意味着它是半透反射型;“SW”表示采用侧面白色LED背光;“G”代表STN - 灰度;“B”是6:00视角;“W”说明具备宽温度范围( - 20°C到 + 70°C);“3V3”则表示逻辑电源和背光电源均为3.3V,并且该模块符合RoHS标准。
文件下载:NHD-0420H1Z-FSW-GBW-3V3.pdf
二、功能与特性
显示规格
该模块拥有4行×20字符的显示能力,能满足一般信息显示需求。
内置控制器
内置SPLC780D或ST7066U控制器,可通过链接http://www.newhavendisplay.com/app_notes/SPLC780D.pdf和http://www.newhavendisplay.com/app_notes/ST7066U.pdf下载其详细规格。
电源与电气特性
采用 + 3.0V电源供电,工作在1/16 duty、1/4 bias模式,且符合RoHS标准。
三、引脚说明与接线图
Pin No. Symbol External Connection Function Description
1 Vss Power Supply Ground
2 VDD Power Supply Supply voltage for logic (+3.3V)
3 V0 Power Supply Power supply for contrast (approx. 0.3V)
4 RS MPU Register select signal. RS = 0: Command, RS = 1: Data
5 R/W MPU Read/Write select signal, R/W = 1: Read R/W = 0: Write
6 E MPU Operation enable signal. Falling edge triggered.
7 - 10 DB0 - DB3 MPU Four low order bi - directional three - state data bus lines. Not used during 4 - bit operation.
11 - 14 DB4 - DB7 MPU Four high order bi - directional three - state data bus lines.
15 LED+ Power Supply Power supply for LED Backlight (+3.3V)
16 LED - Power Supply Ground for backlight
推荐使用2.54mm间距的引脚作为LCD连接器。
四、电气与光学特性
电气特性
Item Symbol Condition Min. Typ. Max. Unit
Operating Temperature Range Top Absolute Max - 20 - + 70 ⁰C
Storage Temperature Range Tst Absolute Max - 30 - + 80 ⁰C
Supply Voltage VDD 3.0 3.3 3.5 V
Supply Current IDD Ta = 25°C, VDD = 3.3V - 4.0 5.0 mA
Supply for LCD (contrast) VDD - V0 Ta = 25°C - 3.0 - V
“H” Level input Vih 2.2 - VDD V
“L” Level input Vil 0 - 0.6 V
“H” Level output Voh 2.4 - - V
“L” Level output Vol - - 0.4 V
Backlight Supply Voltage Vled - - 3.3 - V
Backlight Supply Current Iled Vled = 3.3V - 12 - mA
光学特性
Viewing Angle – Vertical (top) AV Cr ≥2 - 25 -
Viewing Angle – Vertical (bottom) AV Cr ≥2 - 70 -
Viewing Angle – Horizontal (left) AH Cr ≥2 - 30 -
Viewing Angle – Horizontal (right) AH Cr ≥2 - 30 -
Contrast Ratio Cr - 2 - -
Response Time (rise) Tr - - 120 150 ms
Response Time (fall) Tf - - 120 150 ms
五、初始化程序
8位初始化
void command(char i)
    P1 = i;
    D_I = 0; //D/I = LOW : send instruction
    R_W = 0; //R/W = LOW: Write
    E = 1;
    Delay(1); //enable pulse width >= 300ns
    E = 0; //Clock enable: falling edge
void write(char i)
    P1 = i;
    D_I = 1; //D/I = HIGH : send data
    R_W = 0; //R/W = LOW : Write
    E = 1;
void init()
    E = 0;
    Delay(100); //Wait >15 msec after power is applied
    command(0x30); //command 0x30 = Wake up
    Delay(30); //must wait 5ms, busy flag not available
    command(0x30); //command 0x30 = Wake up #2
    Delay(10); //must wait 160us, busy flag not available
    command(0x30); //command 0x30 = Wake up #3
    Delay(10);
    command(0x38); //Function set: 8-bit/2-line
    command(0x10); //Set cursor
    command(0x0c); //Display ON; Cursor ON
    command(0x06); //Entry mode set
4位初始化
    P1 = i;
    Nybble(); //Send lower 4 bits
    i = i < < 4; //Shift over by 4 bits
    P1 = i;
    Nybble(); //Send upper 4 bits
void write(char i)
    P1 = i;
    R_W = 0; //R/W = LOW:Write
    Nybble(); //Clock lower 4 bits
    P1 = i;
    Nybble(); //Clock upper 4 bits
void Nybble()
    E = 1;
void init()
    P1 = 0;
    P3 = 0;
    E = 0;
    P1 = 0x30;
    Nybble(); //command 0x30 = Wake up
    Nybble(); //command 0x30 = Wake up #2
    Nybble(); //command 0x30 = Wake up #3
    Delay(10);
    P1 = 0x20;
    Nybble(); //Function set: 4-bit interface
    command(0x28); //Function set: 4-bit/2-line
    command(0x0F); //Display ON; Blinking cursor
    command(0x06); //Entry Mode set
六、质量信息与注意事项
质量测试
Test Item Content of Test Test Condition Note
High Temperature storage Endurance test applying the high storage temperature for a long time. +80⁰C , 48hrs 2
Low Temperature storage Endurance test applying the low storage temperature for a long time. - 30⁰C , 48hrs 1,2
High Temperature Operation Endurance test applying the electric stress (voltage & current) and the high thermal stress for a long time. +70⁰C 48hrs 2
Low Temperature Operation Endurance test applying the electric stress (voltage & current) and the low thermal stress for a long time. - 20⁰C , 48hrs 1,2
High Temperature / Humidity Operation Endurance test applying the electric stress (voltage & current) and the high thermal with high humidity stress for a long time. +40⁰C , 90% RH , 48hrs 1,2
Thermal Shock resistance Endurance test applying the electric stress (voltage & current) during a cycle of low and high thermal stress. 0⁰C,30min -> 25⁰C,5min -> 50⁰C,30min = 1 cycle 10 cycles
Vibration test Endurance test applying vibration to simulate transportation and use. 10 - 55Hz , 15mm amplitude. 60 sec in each of 3 directions X,Y,Z For 15 minutes 3
Static electricity test Endurance test applying electric static discharge. VS = 800V, RS = 1.5kΩ, CS = 100pF One time
注意事项
使用该模块时,需注意无冷凝现象,部分测试需在25⁰C、0%RH环境下存储4小时后进行,振动测试在产品本身而非容器内进行。同时,可访问www.newhavendisplay.com/specs/precautions.pdf查看使用LCD/LCM的预防措施,保修信息和条款可查看http://www.newhavendisplay.com/index.php?main_page=terms 。
各位电子工程师在使用这款模块时,是否有遇到过一些特殊的问题呢?不妨在评论区分享交流。
