探索NHD - 1.69 - Breakout:1.69英寸彩色OLED玻璃breakout板
探索NHD - 1.69 - Breakout:1.69英寸彩色OLED玻璃 breakout板
作为电子工程师,我们总是在寻找能够提升项目性能和功能的优质硬件。今天,就来和大家详细聊聊Newhaven Display International推出的NHD - 1.69 - Breakout板,它专为1.69英寸彩色OLED玻璃设计,具有诸多独特的功能和特点。
文件下载:NHD-1.69-BREAKOUT.pdf
一、产品概述
NHD - 1.69 - Breakout是一款用于1.69英寸彩色OLED玻璃(NHD - 1.69 - 160128G)的breakout板。它具有以下显著特点:
  • 尺寸与规格:对角线尺寸为1.69英寸,为小型显示应用提供了合适的尺寸选择。
  • 板载升压电路:配备FAN5331SX升压电路,并且提供跳线选项,可绕过升压电路,直接提供(V_{cc})。
  • 开源硬件:开源的特性为开发者提供了更多的灵活性和可定制性,方便进行二次开发。
二、引脚说明
该板的引脚功能丰富,涵盖了电源、控制和数据传输等多个方面。以下是主要引脚的详细说明: Pin No. Symbol External Connection Function Description
1 GND Power Supply Ground
2 3V3 Power Supply Supply Voltage for OLED Logic (+3.3V)
3 DRV_VDD Power Supply Supply Voltage for boost converter (+5V) to drive OLED panel voltage (VCC). (Should be no connect if using pin 4 to apply external VCC)
4 N.C./VCC - No Connect by default. Can be configured for external VCC (+14V). (refer to On - Board Jumper Options table below)
5 SHDN# MPU Active LOW Shutdown control pin for boost converter (pulled HIGH via on - board 10kΩ resistor)
6 RESETB Active LOW Reset signal
7 WRB 6800 mode : Read/Write signal. LOW: Read. HIGH: Write 8080 mode : Active LOW Write signal
8 RDB 6800 mode : Enable signal. Falling edge triggered 8080 mode : Active LOW Read signal
9 CSB Active LOW Chip Select signal
10 RS Register Select signal. LOW: Command. HIGH: Data
11 - 19 D9 - D17 MPU Parallel interface: 9 - bit Bi - directional data bus (D17~D9) 8 - bit Bi - directional data bus (D17~D10) Serial Interface: D17: Synchronous Clock signal (SCL) D16: Serial Data Input signal (SDI) D15: Serial Data Output signal (SDO) RGB interface: 6 - bit RGB color signals (D17~D12)
20 PS MPU Parallel/Serial select. HIGH: Parallel. LOW: Serial
21 CPU MPU Interface select. HIGH: 6800 interface. LOW: 8080 interface
22 ENABLE MPU Data Enable signal
23 DOTCLK MPU Dot Clock signal
24 HSYNC MPU Horizontal Sync signal
25 VSYNC MPU Vertical Sync signal
26 N.C. - No Connect
大家在设计电路时,要根据具体的应用场景和需求,合理使用这些引脚。比如,在选择接口模式时,就需要根据引脚的功能来进行配置。
三、MPU接口引脚分配总结
该板支持多种接口模式,不同模式下的引脚分配有所不同。以下是EIM = 1(默认)和EIM = 0时的接口引脚分配情况:
EIM = 1(默认)
Interface Bus PS CPU DFM1 DFM0 D17 D16 D15 D14 D13 D12 D11 D10 D9 RS CSB RDB WRB RESETB
4 - wire SPI 0 X X X SCL SDI NC 0 0 0 0 0 0 RS CSB 0 0 RESETB
9 - bit 8080 1 0 1 0 D8 D7 D6 D5 D4 D3 D2 D1 D0 RS CSB RDB WRB RESETB
8 - bit 8080 1 0 1 1 D7 D6 D5 D4 D3 D2 D1 D0 0 RS CSB RDB WRB RESETB
9 - bit 6800 1 1 1 0 D8 D7 D6 D5 D4 D3 D2 D1 D0 RS CSB E R/W RESETB
8 - bit 6800 1 1 1 1 D7 D6 D5 D4 D3 D2 D1 D0 0 RS CSB E R/W RESETB
EIM = 0
Interface Bus RIM1 RIM0 D17 D16 D15 D14 D13 D12 D11 D10 D9 VSYNC HSYNC DOTCLK ENABLE
6 - bit RGB 1 0 D5 D4 D3 D2 D1 D0 0 0 0 VSYNC HSYNC DOTCLK ENABLE
这里需要注意的是,DFM1、DFM0寄存器设置为16h,EIM、RIM1、RIM0寄存器设置为14h,“X”表示不关心,“NC”表示不连接,“1”表示VDD,“0”表示VSS。大家在实际应用中,要根据所选的接口模式正确设置这些寄存器。
四、板载跳线选项
板载跳线提供了两种设置方式,可根据实际需求进行选择:
默认跳线设置
R10打开,R11闭合(默认),此时升压电路(引脚3上的+5V)用于为OLED玻璃提供VCC。
跳线选项#1 - 为OLED面板提供外部电源电压(VCC)
R10闭合,R11打开,此时不使用升压电路(引脚3),用户必须将VCC(+14V)外部施加到引脚4。这种方法可以实现最小电流消耗,而OLED逻辑仍然由3V3(引脚2)供电。
大家在选择跳线设置时,要综合考虑电源需求和功耗等因素。比如,如果对功耗要求较高,就可以考虑使用跳线选项#1。
五、电气特性
该板的电气特性如下: Item Symbol Condition Min. Typ. Max. Unit
Operating Temperature Range T OP Absolute Max -40 - +70 ⁰C
Storage Temperature Range T ST Absolute Max -40 - +85 ⁰C
Supply Voltage for OLED Logic 3V3 - 2.8 3.0 3.3 V
Supply Voltage for Boost Circuit DRV_VDD - - 5.0 5.5 V
Supply Voltage for OLED Panel V CC - 13.5 14.0 14.5 V
需要注意的是,不建议在未连接显示器的情况下给板供电,否则可能会损坏升压电路,Newhaven Display对由此造成的PCB故障不承担责任。
六、兼容OLED玻璃
该板专门设计用于驱动和引出NHD - 1.69 - 160128G的信号。大家可以从http://www.newhavendisplay.com/specs/NHD - 1.69 - 160128G.pdf下载其规格说明。
七、质量信息与注意事项
质量测试
该板经过了一系列的质量测试,包括高温存储、低温存储、高温操作、低温操作以及高温/高湿度操作等测试,以确保其在不同环境下的性能和可靠性。
注意事项
在使用OLEDs/LCDs/LCMs时,需要遵循相关的预防措施,可参考www.newhavendisplay.com/specs/precautions.pdf。同时,关于保修信息,可查看http://www.newhavendisplay.com/index.php?main_page=terms的条款和条件。
总的来说,NHD - 1.69 - Breakout板为1.69英寸彩色OLED玻璃的应用提供了一个便捷、灵活的解决方案。大家在使用过程中,要充分了解其功能和特点,根据实际需求进行合理设计和配置。你在使用类似的breakout板时,遇到过哪些问题呢?欢迎在评论区分享你的经验。
  • 相关推荐
  • 热点推荐
