在电子设备的显示领域,OLED显示模块以其独特的优势逐渐崭露头角。今天,我们就来详细探讨一下Newhaven Display International公司的NHD - 0420CW - AG3字符OLED显示模块,看看它在设计和性能上有哪些值得关注的地方。
文件下载:NHD-0420CW-AG3.pdf
NHD - 0420CW - AG3是一款4行20字符的OLED显示模块,型号各部分都有其特定含义:
该模块具有以下显著特点:
| 并行接口共有20个引脚,各引脚功能明确: | Pin No. | Symbol | External Connection | Function Description |
| 1 | V SS | Power Supply | 接地 | |
| 2 | V DD | Power Supply | 为OLED和逻辑电路提供电源,2.8V工作时V DD = 2.8V,5V工作时V DD = 5V | |
| 3 | REGV DD | Power Supply | 内部5V I/O调节器选择信号,2.8V工作时REGV DD = 0V,5V工作时REGV DD = 5V | |
| 4 | D/C | MPU | 数据/命令选择信号,D/C = 0为命令,D/C = 1为数据 | |
| 5 | R/W | MPU | 读/写选择信号,R/W = 1为读,R/W = 0为写 | |
| 6 | E | MPU | 操作使能信号,下降沿触发 | |
| 7 - 10 | DB0 – DB3 | MPU | 四个低阶双向三态数据总线,4位操作时不使用 | |
| 11 - 14 | DB4 – DB7 | MPU | 四个高阶双向三态数据总线 | |
| 15 | /CS | MPU | 低电平有效芯片选择信号 | |
| 16 | /RES | MPU | 低电平有效复位信号 | |
| 17 - 19 | BS0 – BS2 | MPU | MPU接口选择信号 | |
| 20 | V SS | Power Supply | 接地 |
| 串行接口同样有20个引脚,部分引脚功能与并行接口类似,不同之处在于: | Pin No. | Symbol | External Connection | Function Description |
| 7 | SCLK | MPU | 串行时钟信号 | |
| 8 | SDI | MPU | 串行数据输入信号 | |
| 9 | SDO | MPU | 串行数据输出信号 |
| I²C接口的引脚也有其特点,例如: | Pin No. | Symbol | External Connection | Function Description |
| 4 | SA0 | MPU | 从地址选择信号 | |
| 7 | SCL | MPU | 串行时钟信号 | |
| 8 | SDA IN | MPU | 串行数据输入 | |
| 9 | SDA OUT | MPU | 串行数据输出,需与SDA IN(引脚8)连接 |
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit |
| Operating Temperature Range | T OP | Absolute Max | -40 | - | +85 | ⁰C |
| Storage Temperature Range | T ST | Absolute Max | -40 | - | +90 | ⁰C |
| Supply Voltage for logic | V DD | - | 2.4 | 2.8 | 5.5 | V |
| Supply Voltage for I/O Regulator | REGV DD | V DD = 5V | 4.4 | 5.0 | 5.5 | V |
| Supply Current | I DD | - | - | 70 | 135 | mA |
| Sleep Mode Current | (I DD ) SLEEP | - | - | 2 | 5 | mA |
| “H” Level input | V IH | - | 0.8 * V DD | - | V DD | V |
| “L” Level input | V IL | - | V SS | - | 0.2 * V DD | V |
| “H” Level output | V OH | - | 0.9 * V DD | - | V DD | V |
| “L” Level output | V OL | - | V SS | - | 0.1 * V DD | V |
从这些数据可以看出,该模块在较宽的温度范围内都能正常工作,并且对电源电压的要求也有一定的灵活性。
| Item | Symbol | Condition | Min. | Typ. | Max. | Unit | ||
| Optimal Viewing Angles | Top | ϕY+ | Cr ≥ 10,000:1 | 80 | - | - | ⁰ | |
| Bottom | ϕY- | 80 | - | - | ⁰ | |||
| Left | θX- | 80 | - | - | ⁰ | |||
| Right | θX+ | 80 | - | - | ⁰ | |||
| Contrast Ratio | Cr | 10,000:1 | - | - | - | |||
| Response Time | Rise | Tr | - | - | 10 | - | µs | |
| Fall | Tf | - | - | 10 | - | µs | ||
| Brightness | 50% checkerboard | 120 | 150 | - | cd/m² | |||
| Lifetime | Ta = 25°C, 50% checkerboard | 60,000 | - | - | Hrs |
其优秀的光学特性,如高对比度、快速响应时间和较长的使用寿命,使得显示效果更加清晰、稳定。
该模块内置US2066控制器,详细的规格说明可从http://www.newhavendisplay.com/app_notes/US2066.pdf下载。
模块的命令集分为基本命令集、扩展命令集和OLED命令集。
不同的接口(6800 - 系列并行接口、8080 - 系列并行接口、串行接口和I²C接口)都有各自的时序要求。以6800 - 系列并行接口为例,时钟周期时间(写周期)最小为400ns,地址建立时间最小为13ns等。了解这些时序特性对于正确设计电路和编写驱动程序至关重要。
模块提供了多种ROM字体表,如ROM A、ROM B和ROM C,不同的ROM可以显示不同的字符和符号,满足不同的显示需求。
文档中给出了示例程序代码,包括命令发送、数据写入、初始化和输出显示等功能。通过这些代码,我们可以快速了解如何控制该显示模块。例如,“command”函数用于发送命令,“data”函数用于发送数据,“init”函数用于初始化模块,“output”函数用于输出显示内容。
该模块经过了多项质量测试,包括高温存储、低温存储、高温操作、低温操作、高温高湿度操作、热冲击抗性、振动测试和静电测试等。测试条件和评估标准明确,确保了模块的可靠性和稳定性。
使用OLEDs/LCDs/LCMs时,可参考www.newhavendisplay.com/specs/precautions.pdf中的注意事项。同时,关于保修信息和条款可访问http://www.newhavendisplay.com/index.php?main_page=terms。
总之,NHD - 0420CW - AG3字符OLED显示模块在设计和性能上都有出色的表现,无论是显示效果、接口兼容性还是可靠性,都能满足许多电子设备的需求。电子工程师在设计相关产品时,可以根据实际需求充分利用该模块的特点,实现理想的显示功能。你在使用类似显示模块时遇到过哪些问题呢?欢迎在评论区分享。
